Go to Post There is no charge. We just want to help. We are family… - emnasson303 [more]
  #136   Spotlight this post!
Unread 02-09-2018, 10:46 PM
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
s_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond repute
Re: Week 5: Teething Pains
Originally Posted by Brian M View Post
Why use 2 bearings on that outer block if only 1 contacts the boxtube?
We hadn't made our standoffs at the time. Our final bearing blocks have quite a bit of cheesing added as well.
  #137   Spotlight this post!
Unread 02-11-2018, 10:12 AM
JamesCH95's Avatar
JamesCH95 JamesCH95 is online now
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
JamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond repute
Re: FRC 95 2018 Build Thread
To replace our breaking sheet-metal bearing guide blocks we machined some out of aluminum.
We'd machine all the features, flip it over and machine off our 'hold on' material, then peel them out and deburr.
They're ambidextrous, unlike their sheet metal counterpart.
[img]https://i.imgur.com/ZrW5tCy.jpg[e/img]
We also up-sized our wrist cylinders, to great effect. We were able to remove all of the spring counter-balancing that we had, and I think this wound up lighter than the smaller cylinders with springs. We also changed the combination of stroke lengths with these cylinders to get more interesting wrist positions.
We did a bit of drive practice this weekend. Enough to continue to break things, this time in spectacular fashion.
Nothing really broke, but we did find a spot in the arm system that had a little too much compliance. We're going to stiffen it for competition. We reassembled everything after this episode and kept practicing without incident and without full-throttle turning with the elevator and max extension.
Theory is a nice place, I'd like to go there one day, I hear everything works there.
Maturity is knowing you were an idiot, common sense is trying to not be an idiot, wisdom is knowing that you will still be an idiot.
  #138   Spotlight this post!
Unread 02-11-2018, 01:30 PM
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
An additional practice session. Not our best, not our worst. We're going to work on automating cube acquisition, adding a camera to the chassis and a set of IR sensors to the collector. That is clearly our weakest feature right now.
  #139   Spotlight this post!
Unread 02-11-2018, 07:12 PM
asid61's Avatar
asid61 asid61 is offline
Design Simple
AKA: Anand Rajamani
FRC #1072 (Harker Robotics)
Rookie Year: 2013
I assume you also plan to have a "move elevator to scoring height" button in mind? It seemed like the driver was spending a long time figuring out the height.
Team 1072 2017-present
Team 299 2017
Team 115 2013-2016 (student)
2018 Davis Finalists (w/ 6474 and 3880), 2018 Roebling Winners (w/ 3476, 1323, and 1778)
  #140   Spotlight this post!
Unread 02-12-2018, 06:59 AM
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Indeed we do.
  #141   Spotlight this post!
Unread 02-13-2018, 07:45 AM
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Banner Sensor Testing
We setup a series of three IR Banner sensors to detect when a cube was ready to be picked up by the Chain Maw. Initial testing with the sensors just jumped to the PDP looked really good, but when we wired them into the robot with 6 extra feet of 22awg wire their range dropped nearly in half. Undesirable, but likely workable. If anyone has any suggestions or experience with these sensors we'd love to hear how we could increase the range. The best we can think of is that the PDP was running ~1V higher than the 12V VRM, and the extra voltage helped our range out a bit.
Either way, here is a short clip of how they pick up the cube. With the outer two sensor's reduced range it's a bit conservative in 'square approach' situations, which is a bummer. However, by leveraging the poor detection distance of the cube's corner, or when the cube is at an angle, it will detect angled cubes nicely because they have to be further in the Chain Maw to be successfully collected.
  #142   Spotlight this post!
Unread 02-13-2018, 10:35 AM
asid61's Avatar
Design Simple
AKA: Anand Rajamani
Rookie Year: 2013
Re: Banner Sensor Testing
Have you thought about adding an el cheapo 12V/adjustable buck-boost supply close to the sensors? That could bump it back up to whatever you need.
Team 299 2017
  #143   Spotlight this post!
Unread 02-13-2018, 10:55 AM
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
That is the conclusion that we came to: boosting the voltage will give us more margin on range given the analog nature of the sensor. We ordered a module that will turn 9-36V into regulated 24V and will use this to excite the sensors.
  #144   Spotlight this post!
Unread 02-19-2018, 09:11 PM
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
We've been working really hard the last few days, as I'm sure everyone else has. We're getting pumped for GSDE!
111lbs as he sits. Kepler is the competition robot, Doppler is the practice robot.
Here is our driver trying to tip it over with the ramps mounted. We all almost died laughing afterwards.
  #145   Spotlight this post!
Unread 02-19-2018, 10:13 PM
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Here is a video of Doppler climbing Kepler. A whole 1in of ground clearance and no traction tape on the ramps yet.
https://youtu.be/s3N6641s-eQ
  #146   Spotlight this post!
Unread 02-20-2018, 11:38 AM
wjd13 wjd13 is offline
FRC #4905 (Andromeda One)
Rookie Year: 2015
wjd13 is on a distinguished road
Are you concerned about robots having space to balance on the ramps when they have bumpers on? That's 3 inches that they can't move closer to the scale, plus another 3 inches of bumper weight sticking out the back.
  #147   Spotlight this post!
Unread 02-20-2018, 02:21 PM
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Not really. The rocking observed in the video is because our deck material was too flexible in a few spots. We're going to reinforce it where appropriate to stabilize things.
Also keep in mind that the team platform is somewhat smaller than the field platform, so that part is a little deceiving.
  #148   Spotlight this post!
Unread 02-20-2018, 11:23 PM
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Here is our 1-Take reveal video for Kepler, our 2018 robot.
  #149   Spotlight this post!
Unread 02-20-2018, 11:29 PM
EricDrost's Avatar
EricDrost EricDrost is offline
FRC #1923 (The MidKnight Inventors)
EricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond repute
Thank you for sharing the journey so thoroughly. Definitely helped me break my tunnel vision on a few challenges this build season. Good luck!
MORT Team 11: 2008 - 2015
MKI Team 1923: 2015 - Present
  #150   Spotlight this post!
Unread 02-21-2018, 10:13 AM
The_ShamWOW88's Avatar
The_ShamWOW88 The_ShamWOW88 is offline
Senior Mentor/Coach
The_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to behold
Another great machine and build thread from team 95! Hopefully we'll get to compete with you this season! Good luck!
"The best way to predict the future is design it"
"Striving for excellence through inspiration"
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
