OCCRA
Go to Post Sometimes I think all the Game Hint does to us is make us terrible listeners. - Chris is me [more]
CD-Media
Unread 10-13-2018, 08:29 PM
ozdave ozdave is offline
FRC #6072 (Triton Tech)
Rookie Year: 2017
ozdave is an unknown quantity at this point
Talon SRX position hold PID
Hi all
Are there any general recommendations for settings for the PID parameters when using the Talon controlmode.position mode to hold an elevator our an arm in position?
Regards
David
Sent from my SM-N960U using Tapatalk
Unread 10-13-2018, 09:14 PM
asid61's Avatar
asid61 asid61 is offline
Design Simple
AKA: Anand Rajamani
FRC #1072 (Harker Robotics)
Re: Talon SRX position hold PID
Originally Posted by ozdave View Post
Hi all
Regards
David
Use the arbitrary feedforward to help hold it up by applying a static voltage. For an elevator, that's a constant (it's around 0.15 on ours). For an arm, it'll vary with the angle.
Team 1072 2017-present
Team 299 2017
Team 115 2013-2016 (student)
2018 Davis Finalists (w/ 6474 and 3880), 2018 Roebling Winners (w/ 3476, 1323, and 1778)
Unread 10-13-2018, 09:46 PM
GeeTwo GeeTwo is offline
Somebody Else
AKA: Gus Michel II
As far as a general recommendation - provide a counter-spring or counterweight so that the required torque to hold a position is minimal. This will significantly reduce the amount of work your motors need to do both to get to a position, and to hold it. IIRC, the programmers didn't even need to change the PIDs from their default values with the arm 3946 did this year for Bayou thanks mostly to some counter-springs.
Note that even for an elevator, the required current is likely to change to hold a position if the load changes (e.g. cube vs no cube). Unless countered, arms will usually require the greatest current to hold a position where the CoG of the arm is at the same level as the pivot, and decrease roughly as the cosine of the angle from the horizontal.
[Quoting brennonbrimhall]: We design a new robot every year, but we can't forget that we also design a new team every year as folks come and go.
Powered by vBulletin®
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
