OCCRA
Go to Post You guys must sponsor that one team on The Fosters! - Tyler Olds [more]
Unread 03-22-2018, 10:04 AM
Legator91's Avatar
Legator91 Legator91 is offline
AKA: Ryan Legato
FRC #0067 (HOT Team)
Legator91 has much to be proud ofLegator91 has much to be proud ofLegator91 has much to be proud ofLegator91 has much to be proud ofLegator91 has much to be proud ofLegator91 has much to be proud ofLegator91 has much to be proud ofLegator91 has much to be proud ofLegator91 has much to be proud of
2018 HOTBOT
A little late this year, but here is the 2018 HOTBOT!
Brief summary below. Feel free to ask questions for more detail.
Drivetrain:
-4 mini CIM
-2 775 Redline(with custom mini CIM conversion)
-Ball Shifter
Manipulator:
-2 stage elevator. Powered by 1 775 Pro into a Versa. Using spectra cable for the pulley system.
-The wrist is powered by a bag motor going into a Versa.
-The arm/roller system can actuate to open and close around a cube using pneumatics.
-Roller system uses bag motors, with belt reduction.
Climber:
-Ball screws drive the climber up and down.
-2 775 Pros into 5:1 Versas to power the ball screws.
Ramp:
-775 Redline into a 120:1 Versa. + 22:60 from versa to sprocket + 2:1 on the pulley system.
-Versa ratchet slice used to prevent back drive. It is actuated by a servo motor.
-Ramp sides are forced open by surgical tubing under tension.
https://drive.google.com/file/d/14-7...ew?usp=sharing
https://drive.google.com/open?id=1id...P-R1qVhw6-Ijjp
https://drive.google.com/open?id=1EF...yTBsorhOuOa_AV
https://drive.google.com/open?id=1qO...oFC9ESw9Rlik_C
https://drive.google.com/open?id=1Sb...spVKp7Vc3QFCrD
https://drive.google.com/open?id=1bS...XSoNGN1paT10eN
Michigan Tech: 2010 - 2014
University of Michigan: 2015 - Present
Mentor (FRC 67): 2015 - Present
Mentor (FRC 3771, 4363): 2011 - 2012
Student (FRC 67): 2007 - 2010
2010 World Champs (294, 67, 177)
2009 World Champs (111, 67, 971)
Unread 03-22-2018, 10:06 AM
Brian M's Avatar
Brian M Brian M is online now
Design Lead
FRC #1360 (Orbit Robotics)
Brian M has a reputation beyond reputeBrian M has a reputation beyond reputeBrian M has a reputation beyond reputeBrian M has a reputation beyond reputeBrian M has a reputation beyond reputeBrian M has a reputation beyond reputeBrian M has a reputation beyond reputeBrian M has a reputation beyond reputeBrian M has a reputation beyond reputeBrian M has a reputation beyond reputeBrian M has a reputation beyond repute
Re: 2018 HOTBOT
What drove (Get it!??) you guys to use 4 Minicim + 2 Redline drivetrain, seems like an unusual setup. Was 6 minicim not hip enough?
2016 - Rah Cha Cha Ruckus Winners (3015 & 4039)
2017 - Industrial Design (Durham), Entrepreneurship (McMaster), Quality Award (Ontario DCMPS)
2018 - Georgian District Winner (1305 & 6864) + Innovation in Control, York District Winner (1325 & 6140) + Chairmans Award, Ont DCMP Excellence in Engineering
Unread 03-22-2018, 10:17 AM
Legator91's Avatar
AKA: Ryan Legato
Re: 2018 HOTBOT
This robot had a bit of a weight issue. We made several changes to reduce weight. One was taking out 2 of the mini CIM's, and replacing them with 775's. I'm not sure on the exact amount.
One cool thing to note. The ratio is set so the free speed of the 775 is below that of the CIM. This was done due to worries about over heating. At normal driving speeds the 775 will not be under load, but the fan will spin to cool the motor.
Unread 03-22-2018, 11:04 AM
Barngirl425's Avatar
Barngirl425 Barngirl425 is offline
AKA: Amanda Cullen
FRC #0548 (Robostangs)
Barngirl425 has a brilliant futureBarngirl425 has a brilliant futureBarngirl425 has a brilliant futureBarngirl425 has a brilliant futureBarngirl425 has a brilliant futureBarngirl425 has a brilliant futureBarngirl425 has a brilliant futureBarngirl425 has a brilliant futureBarngirl425 has a brilliant futureBarngirl425 has a brilliant futureBarngirl425 has a brilliant future
Send a message via AIM to Barngirl425
Re: 2018 HOTBOT
Loved seeing you guys play at Milford. Looking forward to seeing you guys at states in a few weeks!
2008-2012 - Team 2458 Team Lead
2017 - Team 548 Mentor
Life is a runaway train you cant wait to jump on - Sugarland
A dream is just a dream, a goal is a dream with a plan and a deadline
Unread 03-22-2018, 11:37 AM
Breakaway3937's Avatar
Breakaway3937 Breakaway3937 is offline
WFFA 2016
AKA: Brian "Robo" Jones
FRC #3937 (Breakaway)
Breakaway3937 is a glorious beacon of lightBreakaway3937 is a glorious beacon of lightBreakaway3937 is a glorious beacon of lightBreakaway3937 is a glorious beacon of lightBreakaway3937 is a glorious beacon of light
Re: 2018 HOTBOT
We have the same setup. We do it as well because of weight and have never had an issue after two years. I think it is a great setup and very robust.
"There is no luck. It is only when preparation meets opportunity."
Unread 03-22-2018, 12:36 PM
Type's Avatar
Type Type is offline
AKA: AJ
FRC #3452 (GreengineerZ)
Rookie Year: 2016
Type has much to be proud ofType has much to be proud ofType has much to be proud ofType has much to be proud ofType has much to be proud ofType has much to be proud ofType has much to be proud ofType has much to be proud ofType has much to be proud of
Re: 2018 HOTBOT
This year my team switches to 8 775s and resulted with what feels like twice the power of our 4 cim drivetrain from last year, but still being 3 lbs lighter, able to run at a higher top speed with our tripping breakers and have a ton of pushing power (which we try to avoid).
775s are amazing things...
3452- Lead Builder/ Pit Boss
*My posts do not reflect the opinion of my team*
Unread 03-22-2018, 12:43 PM
Mike Schreiber's Avatar
FRC #0067 (The HOT Team)
Re: 2018 HOTBOT
We had originally planned to do 6 miniCIMs. Our contingency plan for the season had always been go to 4 CIMs if we have a weight problem, but realizing we were so overweight so late made that an issue to get the electrical panel rework done in time. This fix is about the same weight as 4 CIMs (including the speed controllers). Total savings compared to 6 minis was 1.9 lbs. This was a bit of a risk, because we had done literally no testing of 775s in the drive. We figured the failure mode was a burned up 775 which means we'd be driving around with 4 miniCIMs - didn't seem too bad. This drive has been rock solid and after finals at both Southfield and Milford our 775s were cold. This game doesn't seem too tough on drivetrains yet but based on our results so far I would run this again next year.
We also originally planned a faster elevator (2 motors with less reduction) and faster lift (which we did end up with at Milford, but not for Southfield), but weight concerns didn't allow for it.
Other cool stuff:
Round tube elevator - 1.5 x .063" round tube is ~21% lighter than equivalent 2 x 1 x .063" Spectra cord used for the elevator is super light. Pulleys are made of delrin on comp bot, but practice bot ones are 3D printed and holding up just fine.
0.63" 5052 aluminum sheet metal chassis - includes a tunnel (really meant for ground clearance) which allows us to use a .063" lexan belly pan that is stiffened by the bends.
3D printed pulleys and belted reduction in the intake were used avoid another versaplanetary.
Reason we were saving all that weight:
Our ramp weighs 14 lbs (not including the winch that lifts it) and is 46.5" wide x 37.5" long
Mike Schreiber
Kettering University ('09-'13) University of Michigan ('14-'18)
Unread 03-22-2018, 12:48 PM
Brian M's Avatar
Design Lead
Re: 2018 HOTBOT
Oh thats pretty cool, so basically the power of the 775 only kicks in when you need it?
Unread 03-22-2018, 01:12 PM
Legator91's Avatar
AKA: Ryan Legato
Re: 2018 HOTBOT
Yes. They are really only used for acceleration. As Mike mentioned above, they have been cold after matches. No issues with over heating.
Unread 03-22-2018, 01:55 PM
juju_beans's Avatar
juju_beans juju_beans is offline
FRC #3647 (Millennium Falcons)
Rookie Year: 2016
juju_beans is a name known to alljuju_beans is a name known to alljuju_beans is a name known to alljuju_beans is a name known to alljuju_beans is a name known to alljuju_beans is a name known to all
Re: 2018 HOTBOT
Do you have a close up picture of the 775 in drivetrain setup? What ratio are you using?
It worked in the CAD!
CNC Router and HSMWorks Series
Unread 03-22-2018, 03:03 PM
Re: 2018 HOTBOT
https://drive.google.com/open?id=1q_...9Izp5t1RVq722Y
Don't have one of the actual parts, this is the CAD model. This pilots into the 3 CIM ball shifter just like a CIM would. 12:48 in the pulley reduction and a 12 tooth pinion on the output shaft. We're running 11 tooth pinions on the mini CIMs.
The rest of the DT is the 2.16 spread ball shifter (no 3rd stage) to a 24t output pulley which drives the 42t pulley on the 4" wheels.
Mike Schreiber
Unread 03-22-2018, 03:20 PM
Petitioning the UN to ban Lythgoe
Re: 2018 HOTBOT
Hey Mike, next year use the Zebra Camo version?
Unread 03-22-2018, 06:34 PM
Legator91's Avatar
AKA: Ryan Legato
Re: 2018 HOTBOT
You mean like this?
https://drive.google.com/open?id=0B2...WTJGT lY4TkZB
We highly considered doing this. You wouldn't really see it with bumpers on though. In the end I think it was a weight issue again. The car camo vinyl is much thicker and about 3-4 times the weight. It does look cool though!
Unread 03-22-2018, 07:30 PM
Re: 2018 HOTBOT
You mean like this?
Yup, that looks similar to the first time I saw your practice bot.
It's a good look
Unread 03-22-2018, 07:49 PM
Kevin Ainsworth's Avatar
FRC #2451 (Pwnage)
Kevin Ainsworth has a reputation beyond reputeKevin Ainsworth has a reputation beyond reputeKevin Ainsworth has a reputation beyond reputeKevin Ainsworth has a reputation beyond reputeKevin Ainsworth has a reputation beyond reputeKevin Ainsworth has a reputation beyond reputeKevin Ainsworth has a reputation beyond reputeKevin Ainsworth has a reputation beyond reputeKevin Ainsworth has a reputation beyond reputeKevin Ainsworth has a reputation beyond reputeKevin Ainsworth has a reputation beyond repute
Re: 2018 HOTBOT
Originally Posted by Type View Post
This year my team switches to 8 775s and resulted with twice the power of our 4 cim drivetrain from last year, but still being 3 lbs lighter, able to run at a higher top speed with our tripping breakers and have a ton of pushing power (which we try to avoid).
They do not have 2X the power of 4 cims, the battery cannot provide enough power to use their full potential. The main advantage is weight if all other things are equal.
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
