OCCRA
Go to Post Work hard. Then work even harder. Work until there is nothing left to work on, then work more. - RoboChair [more]
CD-Media
Unread 11-02-2018, 02:22 PM
andrew.bell andrew.bell is offline
VRC #54065
andrew.bell is an unknown quantity at this point
Vex Coding Studio: Pneumatics
I am currently working on a robot for this years vex competition, and my team is using pneumatics. However we have been having trouble coding because we are using vex coding studio and a V5 brain, but the ports don't show up in the coding software. The ports are labeled A, B, C, D, E, F, G, and H; but none of them appear while I'm coding. Any advice?
Unread 11-02-2018, 02:50 PM
Katie_UPS's Avatar
Katie_UPS Katie_UPS is offline
Made in Wisconsin
AKA: Katie Widen
Katie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond repute
Re: Vex Coding Studio: Pneumatics
A quick search on the VEX forum found this result:
Programming Single Acting Pneumatics
While CD is a good resource, the VEX forum is pretty active and full of VEX-specific knowledge. As an added bonus. people like James Pearman - who works on VEX products- are active contributors.
1675->3928->1296->??
Unread 11-02-2018, 03:37 PM
Wingus&Dingus Wingus&Dingus is offline
FRC #7498 (Wingus & Dingus)
Wingus&Dingus is an unknown quantity at this point
VCS, and V5 hardware for that matter, is best described as work in progress. The link provided above is of no use to you since it's for the earlier EDR Cortex controller however VEX Forum is the right place to ask.
What language in are you using in VCS? Modkit, VEX C++, C++ Pro?
With VEX C++ you're not given access to edit the robot-config.h file so you have to declare your port usage in the .cpp file. With C++ Pro you can just edit the robot-config.h file. For Modkit there is no hope.
Add this line
vex::digital_out actuator_name( Brain.ThreeWirePort.A);
In your code
actuator_name.set(true);
actuator_name.set(false);
Here's the VCS C++ API document - latest release that I know of and it's old.
https://docs.google.com/document/d/1...oQEU5r-sk/edit
There's also a VCS documentation website here and it has a hamburger menu! https://help.vexcodingstudio.com/index.html
If you're programming in C++ just switch to using PROS. Search VEX Forum.
Unread 11-02-2018, 04:45 PM
Katie_UPS's Avatar
Made in Wisconsin
AKA: Katie Widen
Oh bananas, I totally missed that the question wasn't for VCS - good catch.
Unread 11-05-2018, 02:17 PM
VRC #54065
Thanks for the advice, it's working.
Powered by vBulletin®
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
