Go to Post FIRST is a pretty decent microcosm of real life, those who work hard, accomplish more decent lesson to learn, and FIRST is allowing us to learn it. - Aren_Hill [more]
Unread 02-01-2011, 03:37 PM
sand500 sand500 is offline
FRC #3540 (Wildcat Robotics)
sand500 is an unknown quantity at this point
Joystick POV hat button?
we are using the logitech extreme 3d pro because it has the twist axis. Does anyone know how to program the POV hat buttons? we want to use it to rotate the camera.
Unread 02-01-2011, 05:13 PM
sjspry sjspry is offline
FRC #1984
sjspry has a spectacular aura aboutsjspry has a spectacular aura aboutsjspry has a spectacular aura about
Re: Joystick POV hat button?
They should show up as axis (even though they're just momentary switches). They will either give you -1 or 1 (the Joystick class gives you -1..1, right?).
First two axis should be x and y, third will be the throttle, and if I remember correctly from when I was playing around with my 3D Pro (before it broke), the hat axis should be 4 an 5 (or 3 and 4, if the Joystick class starts enumeration at 0).
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
