OCCRA
Go to Post Part of FRC and design/engineering is perseverance. Keep your chin up, your thoughts positive, and have respect for your work and the work of your teammates. - Nathan_Fraser [more]
CD-Media
Unread 12-07-2018, 10:38 PM
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Protopipe - Spectrum 3847
We have been working on creating a system to allow us to quickly and easily design mechanisms that let us prototype game tasks.
What we have come up with is called "Protopipe". It's an inexpensive system that lets you 3D print connectors for 1/2" PVC to easily build prototypes, test them, and iterate them. We haven't run it through a season yet so there is almost certainly room for improvement but we thought other teams might like to use it as well.
Blog Post: https://blog.spectrum3847.org/2018/1...ng-system.html
Explanation and Notes: https://goo.gl/3pqA4d
3D Files: https://grabcad.com/library/spectrum-protopipe-1
Spoiler for GIFs of the prototypes:
Unread 12-07-2018, 11:28 PM
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
Re: Protopipe - Spectrum 3847
This is really cool! Reminds me of the "Chaos Tower" toys I had as a kid. Anticipating where and how to build adjust-ability into prototypes was always a weak point in processes I lead -- will definitely consider this in the future if working with a team with ample 3d printer access!
2017: Technical Mentor, FRC 1100, The T-Hawks
2018-2019: Other projects/finally finishing school/maybe some mentor-for-hire work around NE
Unread 12-08-2018, 12:32 AM
Nick.kremer's Avatar
Nick.kremer Nick.kremer is offline
FRC #3512 (Spartatroniks)
Nick.kremer is a splendid one to beholdNick.kremer is a splendid one to beholdNick.kremer is a splendid one to beholdNick.kremer is a splendid one to beholdNick.kremer is a splendid one to beholdNick.kremer is a splendid one to beholdNick.kremer is a splendid one to behold
This looks awesome, thanks so much for sharing this. I can't wait to give it a try, I could really change how we approach prototyping.
Team 3512 : 2013 - Present : CAD/Design Mentor & Co-Drive Coach
Check out Team 3512's Website!
Like us on Facebook!
Unread 12-08-2018, 01:01 AM
chrisrin chrisrin is offline
FRC #4915 (Spartronics)
Rookie Year: 2016
chrisrin is a splendid one to beholdchrisrin is a splendid one to beholdchrisrin is a splendid one to beholdchrisrin is a splendid one to beholdchrisrin is a splendid one to beholdchrisrin is a splendid one to beholdchrisrin is a splendid one to behold
Really cool! I can see how these will make prototype iteration faster.
What have you found to be the advantages of working with PVC vs. 2x4s or aluminum tube (other than cost for that last) for prototyping?
Anyone ever design a system (including some sliding elements for adjustability) like this for 2x4 prototyping?
Unread 12-08-2018, 01:17 AM
Engineering Coach
We didn't add a table of contents but we did address this at the bottom of the document.
Why we didnít choose other options
2x4s or other lumber
  • Prototyping with wood works but making bearings or slides, etc. takes a long time and you have to manually lay it out and drill the holes, etc. 2x4s are often to large for a lot of tasks. Cutting them requires using the miter saw (chop saw) which is more difficult than a simple manual PVC cutter and harder for new students to use. We will still use them for certain things but the pipe is much lighter and faster to work with.
  • Wooden Prototype Examples - https://www.chiefdelphi.com/forums/s...d.php?t=160035
VEX Versatube or 1x1 aluminum
  • Versatube is great but itís not affordable for a lot of fast prototypes. Also you canít just snap things on to versastube, pivots and shafts are also harder.
REV extrusion or 80/20
  • Added benefit of being able to add things in the middle and slide certain things over versatube but definitely more expensive and harder to cut to size than the ĹĒ PVC pipe.
Unread 12-08-2018, 01:34 AM
ngreen ngreen is offline
AKA: Nelson Green
FRC #1108 (Panther Robotics)
ngreen has a reputation beyond reputengreen has a reputation beyond reputengreen has a reputation beyond reputengreen has a reputation beyond reputengreen has a reputation beyond reputengreen has a reputation beyond reputengreen has a reputation beyond reputengreen has a reputation beyond reputengreen has a reputation beyond reputengreen has a reputation beyond reputengreen has a reputation beyond repute
Answered in the document, mainly being the larger sizes were challenging to fit everything in. You likely could do 1x1s (or other sizes) if you want, and would have to fitting out a conversion.
And interesting stuff. Now just sell a standard kit of protopipe fittings (after a year of testing, i guess). Also, how many pieces of each fitting did you find you needed (or which ones were most popular)?
Unread 12-08-2018, 09:58 AM
Engineering Coach
We won't be selling anything, the whole point is it's cheap to make yourself.
For your second question, that depends on the application, look at the examples we provided to see which connectors were used the most in each one. The corner joint is useful as it can be used to connect 2 or 3 pipes so we printed the most of those so far.
Unread 12-08-2018, 02:14 PM
Nick.B Nick.B is offline
FRC #4159 (Cardinalbotics)
Team Role: Student
Rookie Year: 2017
Nick.B is an unknown quantity at this point
4159 worked on a similar system involving tube connectors (Aluminum not 3d printed) over the summer and the start of this year. We had to abandon the project due to time constraints but I really think a lot of the work we did could be converted to your system using 3D printed parts.
This was one of my favorite parts that we worked on.
https://gyazo.com/a7385c0df718f6d871546b03f583e7d1
https://gyazo.com/da875c9541ffa9d0451de04d6db9491f
It will allow 2 tubes to freely pivot between an angle you could set. It uses a shoulder bolt and some CNC milled parts that could be replaced with 3d printed stuff. One interesting application would be the intakes like the madtown design from this year.
Other stuff we worked on/had ideas about:
2 way/3 way fixed connectors
2 way fixed connectors that you could adjust the angle of
Linear/Rotational Motion
Elevator Rigging
More stuff I'm forgetting
I would love to help you guys continue this project and build it into something even larger. I've always thought that more could be done in the area of low cost, rapid prototyping. If you want any CAD files or an explanation of things I've mentioned please lmk.
Unread 12-08-2018, 07:12 PM
Team Role: Student
Rookie Year: 2017
4159 also worked on a tube based prototyping system over the summer/during the fall but unfortunately, the project was abandoned due to time constraints.
One of my favorite concepts we came up with was the idea of a tube connector that could pivot between 2 angles that you can adjust using a shoulder screw.
Pictures v
https://gyazo.com/f51d27de1d7d0dd66dad2db194c968c7
Other concepts include
-Adjustable fixed angle connectors
-2,3 & 4 way 90-degree connectors
-Bushing based sliders
-Cascade/Continuous Elevator rigging
-Adjustable angle connectors that are also bearing mounts
-Hex inserts for the rollers
-More stuff I'm forgetting off the top of my head
We still have all the CAD files and although our system was made for metal I'm sure it can be converted to 3D printable designs. Would you guys be interested in some sort of a collaboration? 4159 would love to help with this project! I can provide CAD files/explanation for our designs as well.
Unread 12-08-2018, 07:32 PM
Engineering Coach
I'm not exactly sure what type of collaboration you are looking for. The entire system is open source, so you are more than welcome to use and modify the system and if you would like publish changes or additional parts, feel free to post links to any additions in this thread.
Unread 12-10-2018, 02:30 PM
Brian Gray's Avatar
Brian Gray Brian Gray is offline
FRC #5256 (The Atomics)
Brian Gray has a reputation beyond reputeBrian Gray has a reputation beyond reputeBrian Gray has a reputation beyond reputeBrian Gray has a reputation beyond reputeBrian Gray has a reputation beyond reputeBrian Gray has a reputation beyond reputeBrian Gray has a reputation beyond reputeBrian Gray has a reputation beyond reputeBrian Gray has a reputation beyond reputeBrian Gray has a reputation beyond reputeBrian Gray has a reputation beyond repute
This is very similar to industrial building systems like Creform or Fast Tube, but it's scaled down to a more practical size for FRC and is within the means of most teams costwise. Nice work!
Unread 12-10-2018, 03:27 PM
GeeTwo GeeTwo is offline
Somebody Else
AKA: Gus Michel II
FWIW, similar pieces are available commercially. I noticed "saddle tees" at Lowe's yesterday when shopping for stanchion materials.
[Quoting brennonbrimhall]: We design a new robot every year, but we can't forget that we also design a new team every year as folks come and go.
Powered by vBulletin®
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
