OCCRA
Go to Post This tee-shirt collecting gets kind of addicting, doesn't it? - Chief Hedgehog [more]
Unread 07-08-2018, 01:31 AM
Sahana Kumar Sahana Kumar is offline
FRC #2485
Sahana Kumar is an unknown quantity at this point
Team 2485 Code Release for 2018
Team 2485 has made our 2018 Power Up code public! It was revised at San Diego Regional, Las Vegas Regional, and the Houston World Championships. Some highlights include our autonomous routines which use bezier-spline and clothoid curves, our cascaded PID controllers, and our code to ensure our two-stage arm stayed within frame perimeter. Feel free to let us know if you have any questions.
GitHub Repository
Team 2485 Website
Unread 07-09-2018, 07:24 AM
gerthworm's Avatar
gerthworm gerthworm is offline
Making the 1's and 0's
FRC #1736 (Robot Casserole)
Rookie Year: 2015
gerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond repute
Re: Team 2485 Code Release for 2018
Good work folks, thanks for posting!
A couple questions:
What product was your class
lidar wrapper designed to be used with?
Did you benchmark fastmath against the java built-in libraries, or against any other 3rd party libraries? Would you recommend the general lookup-table approach for teams in the future?
I noticed that your 8 contributors only ever worked on a branch named "master". Have you considered using Gitflow or a similar development branching technique to keep folks's work isolated until it's ready to merge?
Unread 07-16-2018, 11:43 AM
FRC #2485
Our Lidar wrapper should work with most FRC lidars, but we used the lidar lite 3 with it.
We actually didn't check FastMath against anything that existed already, it was relatively quick to write, we wanted to try making something that used a lookup-table already, and it worked well enough for our purposes. We wrote it while trying to diagnose some lag issues with the robot and while it was not the source of the problem, it's more than accurate enough for the purposes of most FRC teams, so we would recommend it for that reason. Now that the season is over and we have more time, we may look into comparing it to other libraries.
We have considered using a development branch, but we don't have an organized enough workflow or enough contributors for it to really help us too much. We tend to write the majority of our code on our driver station computer together, especially as we move further into the season. We've never really ended up with any big problems with just using a master branch, though we may consider having a development branch as our software team continues to grow and more people need to work on our code.
Let us know if we can answer any other questions or you want clarification on any of our answers.
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
