OCCRA
Go to Post If only 5% of American entry level workers are proficient in algebra in 2022, I'm moving to Canada. - PVCpirate [more]
Unread 10-09-2017, 08:52 PM
Adam_P's Avatar
Adam_P Adam_P is offline
FRC #3061 (Huskie Robotics)
Adam_P is a jewel in the roughAdam_P is a jewel in the roughAdam_P is a jewel in the rough
CAN bus + RPi
Could I theoretically wire my Raspberry Pi into the CAN bus and read values from Talon SRX's via the Pi and Rio simultaneously? I'm not sure if this makes sense or is even legal but it may help with a odometry project that I'm currently working on.
Unread 10-09-2017, 10:39 PM
MuskieProgramme MuskieProgramme is offline
FRC #6420 (Fire Island Robotics)
MuskieProgramme will become famous soon enough
Re: CAN bus + RPi
Sure, just grap a PICAN Hat for $50 and you'll be set.
Unread 10-10-2017, 01:17 AM
Re: CAN bus + RPi
Ah, the MCP2551 SPI CAN controller. The linux kernel guys tend not to be very happy about it's performance/error handling, but it gets the job done and has a proper socketcan driver.
We've been very happy with the canable as well for debugging (semi truck CAN busses). It seems to just work, and is a USB CAN device with a socketcan driver as well.
Take some time at some point to read the manual at https://www.kernel.org/doc/Documenta...orking/can.txt . It's surprisingly good, and will help you understand CAN bus debugging and what monitoring is available. candump and friends are also very helpful.
