OCCRA
Go to Post Be right back, have to go find out just how many tennis rackets I can put on a robot... - Countersteer [more]
  #31   Spotlight this post!
Unread 04-14-2018, 06:18 AM
Caleb Sykes's Avatar
Caleb Sykes Caleb Sykes is offline
Knock-off Dr. Strange
AKA: inkling16
Caleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond repute
Re: paper: Caleb's Event Simulator 2018
I have posted an update which can be used to simulate the Houston divisions based on the preliminary schedules. Huge thanks to Wes Jordan for getting all of the schedules into the same format as the TBA data. Basically the only change to this workbook is that I reference his site instead of TBA.
This workbook will only work with the preliminary schedules on Wes Jordan's site. You will have to switch back to one of my normal simulators when the actual schedules and match results start to be posted.
  #32   Spotlight this post!
Unread 04-14-2018, 09:00 AM
Bryce2471's Avatar
Bryce2471 Bryce2471 is offline
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
Bryce2471 has a reputation beyond reputeBryce2471 has a reputation beyond reputeBryce2471 has a reputation beyond reputeBryce2471 has a reputation beyond reputeBryce2471 has a reputation beyond reputeBryce2471 has a reputation beyond reputeBryce2471 has a reputation beyond reputeBryce2471 has a reputation beyond reputeBryce2471 has a reputation beyond reputeBryce2471 has a reputation beyond reputeBryce2471 has a reputation beyond repute
You must spread some Reputation around before giving it to Caleb Sykes again.
I'm excited to take a look! Thanks for putting this together.
FLL Team Future imagineers
2011-????:
FRC Team Mean Machine
  #33   Spotlight this post!
Unread 04-14-2018, 10:53 AM
AKA: inkling16
I had a bug that caused ranking predictions for teams in surrogate matches to be calculated incorrectly. This should be fixed in the new v7.3.
  #34   Spotlight this post!
Unread 04-21-2018, 04:37 PM
AKA: inkling16
I have posted an update that uses the preliminary schedules for Detroit. Let me know if you notice any issues. Again, very big thanks to Wes Jordan for getting the schedules into a useful format for me.
Same disclaimer as before:
  #35   Spotlight this post!
Unread 05-17-2018, 07:23 PM
AKA: inkling16
I have posted a version 10.1 which can be used for off season events. I got rid of the expiration warning on it even though there is a good chance I will be posting at least one more update in a month or two. No promises though. Subscribe to the thread if you don't want to miss an update.
I have a bunch of changes for this version, some of which may cause bugs, so if you see any please let me know:
  • "Update" now checks if the number of simulations to run is the same before running, and allows re-importing if a different number of simulations are selected
  • Added a "settings" sheet from which you can select the number of simulations to run and whether or not to stop the "Update" macro if no new data is available.
  • Added an "Import Event Keys" macro to the "event keys" tab to look up off season events which haven't been posted as of the publishing of this book
  • Changed seed values to use the seed values each team had going into their event instead of just their most recent seed value. This has no event on off season competitions, but will correctly show teams' seed values for historical events.
  • Added "average rank" to predicted rankings sheet and this is now the default team sort
  • Added ability to "simulate" from any past point in the event. This can be used for example to find what win probabilities would have been predicted by the simulator before the matches actually happened.
  #36   Spotlight this post!
Unread 07-04-2018, 08:21 PM
AKA: inkling16
Here's another update. I wanted to get it out before IRI. This is probably the most changes I've made in an update this year, although many of the changes are behind the scenes. Here are the key changes:
  • Added conditional formatting to predicted ranks
  • Uses park/climb points as second sort ranking criteria instead of total points, added auto points as third order ranking sort
  • Rankings are now generated according to match data instead of being directly pulled from TBA. This allows you to see what the rankings were at different points throughout the event.
  • various code optimizations, re-structuring and cleanup
  • Various bug fixes
  • Shows predicted contributions before event starts by copying seed values
  • Now allows simulations of events which do not have their schedules released yet
When the IRI teams list shows up on TBA, you'll be able to make predicted rankings even without a schedule. Likewise, you can see what each team's predicted rankings would have been before a schedule was created for completed events. With this, I'm finally comfortable jumping more into the "strength of schedule" conversations. All we have to do to tell if a team has a good or a bad schedule is to compare their pre-schedule ranking probabilities with their ranking probabilites after the schedule is released. We would still have to agree on a way to combine the full ranking data change into a single metric (or just accept that no great single summary statistic exists), but at least now each team's strength of schedule can be seen in a personalized way for them. I never cared much for strength of schedule metrics that are basically some variation of subtracting opponent strength from partner strength, because how "good" or "bad" you feel your schedule is depends heavily on your expectations going into the event based on how good your team is. A schedule with 5 guaranteed wins and 5 guaranteed losses is clearly awful for the team looking to seed first, and clearly awesome for the team worried about seeding last.
Here is each team's change in ranking expectations from before the schedule is released to after the schedule is released for Medtronic:
Code:
team	avg rank change	1 seed	Top 4	Top 8	Top 12	Top 15
233	-7.8		+0.0%	+9.2%	+21.7%	+24.9%	+25.7%
1816	+12.6		-0.1%	-3.1%	-11.3%	-20.4%	-26.6%
2052	+0.3		-3.1%	-5.1%	-0.4%	-0.9%	-0.4%
2181	-4.1		+0.1%	+8.3%	+12.3%	+13.8%	+14.6%
2232	+9.9		+0.0%	-1.3%	-4.7%	-9.8%	-13.5%
2239	+11.8		-0.1%	-1.1%	-5.3%	-9.9%	-13.7%
2450	+4.7		+0.0%	-0.6%	-6.9%	-9.9%	-12.4%
2470	+0.9		+0.0%	+0.1%	-0.2%	-1.6%	-2.2%
2480	-9.0		+0.0%	+0.4%	+1.4%	+2.8%	+4.0%
2498	-0.4		+0.0%	-1.2%	-2.6%	-5.0%	-4.6%
2500	+1.2		+0.0%	-0.6%	-1.2%	-3.2%	-4.3%
2501	-4.7		-0.1%	+10.3%	+17.8%	+17.4%	+17.2%
2502	+0.6		-2.7%	-4.9%	-7.7%	-3.0%	-0.7%
2508	+8.0		+0.0%	-0.6%	-4.4%	-10.1%	-12.5%
2509	-11.1		-0.1%	+13.8%	+23.5%	+32.4%	+35.5%
2513	-6.1		+0.0%	+0.1%	+0.9%	+3.2%	+5.2%
2515	-0.1		+0.0%	-0.1%	-0.4%	-1.2%	-1.1%
2518	-4.8		+0.0%	-0.4%	-0.1%	+0.8%	+1.6%
2529	-7.9		+0.0%	+0.0%	+0.9%	+3.6%	+6.2%
2532	-1.0		+0.0%	-0.3%	-0.7%	-1.2%	-1.8%
2545	-1.9		+0.0%	-0.2%	-0.7%	-0.8%	-0.9%
2823	-11.6		+0.3%	+9.8%	+22.2%	+32.1%	+35.7%
2825	+3.8		+0.0%	-0.1%	-1.0%	-1.9%	-3.1%
2846	+10.9		+0.0%	-13.6%	-27.2%	-34.4%	-36.6%
2847	+3.2		+0.0%	+0.0%	-0.5%	-1.9%	-2.4%
2879	-7.6		+0.0%	+1.2%	+5.5%	+10.4%	+15.7%
3018	-8.6		+0.0%	+1.9%	+8.0%	+11.9%	+15.0%
3023	-10.4		+0.0%	+1.7%	+5.8%	+14.2%	+19.1%
3026	+0.8		-0.1%	-1.5%	-5.4%	-7.5%	-8.4%
3038	+5.6		+0.0%	-0.2%	-2.4%	-5.6%	-7.9%
3058	+7.1		-0.2%	-2.6%	-7.7%	-13.9%	-15.3%
3081	-7.7		+0.0%	+0.1%	+1.4%	+5.9%	+9.2%
3102	-2.8		+0.1%	-1.1%	-1.8%	-1.8%	-0.2%
3184	+0.6		-0.3%	-6.9%	-5.0%	-4.3%	-3.9%
3244	-13.3		+0.0%	+2.5%	+11.4%	+20.6%	+26.2%
3278	+11.6		+0.0%	-0.5%	-3.1%	-7.3%	-10.7%
3298	+6.6		+0.0%	-0.3%	-2.8%	-7.3%	-7.7%
3299	-11.8		+0.1%	+10.1%	+24.6%	+33.5%	+35.3%
3407	+13.8		+0.0%	-0.4%	-2.3%	-5.5%	-9.3%
3454	+0.1		+0.0%	-0.6%	-1.4%	-3.1%	-4.5%
3630	+6.4		-0.3%	-5.7%	-14.5%	-19.9%	-21.9%
3745	+0.1		+0.0%	-1.3%	-4.4%	-2.5%	-4.3%
3751	+11.3		+0.0%	-3.9%	-13.1%	-21.4%	-27.3%
3839	+6.8		+0.0%	-4.6%	-9.7%	-14.8%	-18.7%
3840	+9.2		+0.0%	-1.3%	-8.1%	-13.9%	-18.1%
4207	-2.0		+0.0%	+0.2%	-0.7%	-0.9%	+1.1%
4229	-2.9		+0.0%	-0.1%	-0.4%	-0.5%	-0.2%
4536	+3.4		+0.0%	-0.6%	-2.7%	-5.3%	-6.7%
4549	-13.5		+0.0%	+8.0%	+21.8%	+32.8%	+36.9%
4607	-0.5		+0.0%	-0.8%	-3.4%	-3.7%	-1.0%
4664	-4.9		+0.0%	-0.1%	+0.3%	+0.7%	+0.9%
5172	-0.2		+7.9%	+2.1%	+0.4%	+0.3%	+0.2%
5434	+2.8		-1.3%	-15.5%	-17.2%	-12.4%	-9.8%
5637	-17.2		+0.0%	+1.7%	+6.4%	+14.5%	+21.2%
5913	-2.0		+0.0%	+0.1%	-0.1%	-0.7%	-1.5%
5996	+0.3		+0.0%	+0.1%	-0.7%	-1.2%	-1.6%
6709	-7.0		+0.0%	+0.6%	+2.4%	+6.9%	+11.3%
7038	+2.8		+0.0%	-0.2%	-1.5%	-3.2%	-5.2%
7068	+4.0		-0.1%	-0.5%	-2.7%	-5.1%	-7.2%
7180	+7.6		+0.0%	-0.4%	-1.9%	-4.5%	-7.6%
I'll probably make a full workbook that contains something like this for all 2018 events soon.
Huge thanks to Patrick Fairbank and the other developers of Cheesy Arena for creating these awesome pre-generated schedules. Adding pre-event rankings was already a large effort, I'm so grateful I could use these schedules instead of building my own scheduler from scratch.
  #37   Spotlight this post!
Unread 07-10-2018, 03:56 PM
bobcroucher's Avatar
bobcroucher bobcroucher is offline
bobcroucher is a splendid one to beholdbobcroucher is a splendid one to beholdbobcroucher is a splendid one to beholdbobcroucher is a splendid one to beholdbobcroucher is a splendid one to beholdbobcroucher is a splendid one to beholdbobcroucher is a splendid one to behold
You've been busy! As you know, I've been interested and experimenting with this Strength of Schedule stuff for some time. Thanks so much for all your hard work on it. This approach is a really nice solution to this difficult problem. It's a great addition to your "I Can't Live Without It" simulator.
  #38   Spotlight this post!
Unread 07-10-2018, 04:30 PM
AGPapa's Avatar
AGPapa AGPapa is offline
AKA: Antonio Papa
FRC #5895
Rookie Year: 2011
AGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond repute
So your "strength of schedule" metric just compares with one pre-generated schedule? That doesn't seems like a good metric, as there is no guarantee that these pre-generated schedules are fair. It would make more sense to generate hundreds of potential schedules and compare the actual schedule against those.
EDIT:
Perhaps another solution is to keep the same pre-generated schedule, but randomize the order of the teams in it hundreds of times. That way you won't need to create a whole new scheduling algorithm.
Team 2590 Student [2011-2014]
Team 5684 Mentor [2015]
Team 5895 Mentor [2016-]
  #39   Spotlight this post!
Unread 07-10-2018, 04:50 PM
AKA: inkling16
Originally Posted by AGPapa View Post
EDIT:
This is indeed what it currently does, every simulation randomizes the assignment of teams to the schedule indices.
  #40   Spotlight this post!
Unread 07-12-2018, 10:25 PM
AKA: inkling16
I just uploaded a v4.
Changes:
Fixed a bug that didn't reset surrogate assignment to the schedule when a new event is imported. Essentially, this meant that if you ran events with surrogates in different positions, teams would randomly have matches removed
Changed graph color in team lookup to green
This was a crazy bug fix, it took me a couple full days to track down. Running any single event was fine, but when I ran a different event after certain events, the ranking projections would be a little bit off for a few random teams. The affected teams would also change on each new simulation.
Should be all good now though.
  #41   Spotlight this post!
Unread 07-14-2018, 10:01 AM
AKA: inkling16
Another update, primary purpose was to fix handling of DQs.
Updates:
Added bolding and strikethroughs to data import for surrogate and Dqed teams respectively
Covers some special cases for surrogate teams that were not covered previously
Now handles Dqed teams properly
Updated instructions and FAQ
I really hate dealing with surrogates and DQs, they're such a pain. Hopefully I did a good enough job this time that I don't have to think about them again.
  #42   Spotlight this post!
Unread 07-17-2018, 12:00 PM
AGPapa's Avatar
AKA: Antonio Papa
FRC #5895
Rookie Year: 2011
Hey Caleb,
I'm wondering if there is some sort of substantial difference between these schedules and the schedules actually used in FRC. (Maybe you play more of the same teams over and over again in a real schedule?). Would you be able to use the schedule for some 40-team district event as a template and run your simulator on that? (Still with the random team assignments).
For example, compare the simulator probabilities for MAR Hatboro-Horsham with your current random schedule maker to a simulator using the actual schedule as a template.
I don't expect there to be much of a difference, but it would be interesting to see that empirically.
  #43   Spotlight this post!
Unread 07-17-2018, 02:43 PM
AKA: inkling16
Hey Caleb,
Yeah, I could give that a whirl. My guess is that there'll be more variance in the runs with the actual schedule than there will be using the Cheesy Arena schedule, but that's solely based on my uninformed guess that the Cheesy schedules have fewer duplicate partners/opponents than FIRST's schedules.
  #44   Spotlight this post!
Unread 07-22-2018, 03:39 PM
AKA: inkling16
I've uploaded a file in my Miscellaneous Statistics Projects called "pahat schedule comparison.xlsx" that compares the actual schedule versus the cheesy arena schedule for pahat. These ranking projections were done from the point prior to the schedule release, but after finding out that 6667 would not be attending.
The pahat schedules were found by taking the actual pahat schedule and giving each team an index to create a format equivalent to that of the cheesy schedules (see attached). These indices were randomly shuffled among the teams in each simulation, just as in a normal simulation using the cheesy arena schedules.
I don't see any appreciable difference between the two base schedules. I ran both tests using 10000 simulations, so I would expect to see a bit of variation between the trials just by chance, the only two "big" changes of >1% (25 ranking second and 1640 seeding third) did not exceed 1% on subsequent trials. So overall, there may be some negligible differences between the cheesy schedules and the actual schedules, but it isn't nearly enough to concern me considering I have other known sources of error of larger magnitude.
I might do a full analysis soon of the cheesy schedules versus the actual schedules over all 2018 events just out of curiosity.
  #45   Spotlight this post!
Unread 07-22-2018, 06:02 PM
AKA: inkling16
Forgot that you can't attach files here. See the pahat.csv file in Miscellaneous Statistics Projects.
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
