OCCRA
Go to Post "Only YOU can prevent G22 infractions." - Qbranch [more]
Unread 01-12-2018, 08:12 PM
Jude99999 Jude99999 is offline
FRC #6911 (SOBOTZ)
Rookie Year: 2018
Jude99999 is an unknown quantity at this point
Exclamation VEX digital ultrasonic range finder issue
I'm trying to use a Vex ultra sonic range to detect obstacle but I can't get any value from the sensor except 0.0
I Instantiated the Ultra sonic object in my code by giving as parameters the ports number where the Range finder is connected
But when I call the method getRangeInches I still got 0.0
Can someone help me ?
Unread 01-12-2018, 08:19 PM
pkrishna3082's Avatar
pkrishna3082 pkrishna3082 is offline
love/hate relationship with swerve
AKA: Parthiv Krishna
FRC #3082 (Chicken Bot Pie) and FTC #13471 Mentor (Minnetonka)
Rookie Year: 2016
pkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond repute
Re: VEX digital ultrasonic range finder issue
Do you have a picture of the wiring we can look at?
“Courage cannot exist in the absence of fear.”
2010-2011: FLL 11083, 13873 (Minnetonka Silver) - Programmer
2016-: FRC 3082 (Chicken Bot Pie) - Engineering Captain, Driver, Programming Lead
2017-: FTC 13471 (Minnetonka) - Founding Mentor
Unread 01-12-2018, 08:24 PM
FRC #6911 (SOBOTZ)
Rookie Year: 2018
no the robot stayed at the school but I get the Output cable connected to DIO port 0 and the Input cable connected to DIO port 1
and instantiated my object like this :
static Ultrasonic rangefinder = new Ultrasonic(0,1);
Robotmap.rangefinder.setAutomaticMode(true);
Unread 01-12-2018, 08:34 PM
Rookie Year: 2016
I am assuming you are talking about this one: https://content.vexrobotics.com/docs...instr-0312.pdf
In that case, the INPUT and OUTPUT cables seem to refer to the input and output to the rangefinder. Those should be swapped on the Rio, since output from rio = input to range finder and vice versa. Your instantiation seems to declare 0 as the Output from the Rio (INPUT to rangefinder) and 1 as the Input to Rio (OUTPUT to rangefinder). I might be mistaken, but maybe try swapping these either in code or in wiring?
Unread 01-12-2018, 08:40 PM
FRC #6911 (SOBOTZ)
Rookie Year: 2018
Yes I'm talking about this one, I tried to swap them a couple of times, tomorrow I will retry.
Ugh this thing is driving me crazy!!!!!!!!!!
Unread 01-13-2018, 09:11 AM
Dave Campbell's Avatar
Dave Campbell Dave Campbell is offline
Miami Valley Planning Committee
FRC #0144 (ROCK Robotics)
Dave Campbell has a reputation beyond reputeDave Campbell has a reputation beyond reputeDave Campbell has a reputation beyond reputeDave Campbell has a reputation beyond reputeDave Campbell has a reputation beyond reputeDave Campbell has a reputation beyond reputeDave Campbell has a reputation beyond reputeDave Campbell has a reputation beyond reputeDave Campbell has a reputation beyond reputeDave Campbell has a reputation beyond reputeDave Campbell has a reputation beyond repute
The WPILib VI we used last year for that exact sensor 'bricked' our roboRio twice. We can not recommend using that sensor with LabView, nor the sensor. For details, PM me and I can have our programmer give you extensive info.
Just to be clear - we love the sensor, VEX products are great, just not how it killed our Rio...
"Great spirits have always encountered violent opposition from mediocre minds." - Albert Einstein
FRC Team #144 Advisor
Unread 01-13-2018, 04:38 PM
FRC #6911 (SOBOTZ)
Rookie Year: 2018
Exclamation ultrasonic range finder issue
Finally I think that the VEX range finder is not compatible with the roborio, so we decided to use an analog range finder from maxbotic
does anyone knows how to calculate the voltage scaling ?
Unread 01-13-2018, 05:16 PM
bgg's Avatar
bgg bgg is offline
FRC #3679
bgg is an unknown quantity at this point
Our students hooked one up today and printed the voltage to the smart dashboard. They put a stack of totes 1 foot in front and reocorded voltage.
Repeat at 2 feet, 3. . .10. They found a linear relationship somewhere around .3v = 1ft.
Unread 01-13-2018, 05:33 PM
FRC #6911 (SOBOTZ)
Rookie Year: 2018
Exclamation Re: VEX digital ultrasonic range finder issue
Ok thanks you.
I found that formula I don't know how to get the Vcc, the supplied voltage
that formula is for calculating the voltage scale factor
[(Vcc/512) = Vi]
Vcc = Supplied Voltage
Vi = Volts per inch (Scaling)
Example 1: Say you have an input voltage of +5.0V the formula would read:
[(5.0V/512) = 0.009766V per inch = 9.766mV per inch]
and that formula for calculating the range
The range formula is:
[(Vm/Vi) = Ri]
Vm = Measured Voltage
Vi = Volts per Inch (Scaling)
Ri = Range in inches
Example 2: To get comfortable with this equation use a known distance by using a ruler. Say the multimeter shows 292.98mV then you use the calculations as follows:
[(292.98mV/9.766mV) = 30 inches]
I don't know how to get supplied voltage
Unread 01-13-2018, 06:18 PM
bgg's Avatar
bgg bgg is offline
FRC #3679
Vcc should be in the neighborhood of 5v.
Unread 01-13-2018, 06:20 PM
FRC #6911 (SOBOTZ)
Rookie Year: 2018
yeah maybe, soon we will get one, I will see .
thank you.
Unread 01-13-2018, 09:20 PM
Tungrus's Avatar
Tungrus Tungrus is offline
Tungrus has a reputation beyond reputeTungrus has a reputation beyond reputeTungrus has a reputation beyond reputeTungrus has a reputation beyond reputeTungrus has a reputation beyond reputeTungrus has a reputation beyond reputeTungrus has a reputation beyond reputeTungrus has a reputation beyond reputeTungrus has a reputation beyond reputeTungrus has a reputation beyond reputeTungrus has a reputation beyond repute
Re: ultrasonic range finder issue
VEX ultra sonic sensor is compatible with roboRIO.
On VEX Cortex the OUTPUT pins must plug into higher port number than the INPUT pins.
Unread 01-14-2018, 06:33 AM
FRC #6911 (SOBOTZ)
Rookie Year: 2018
I tried several times to swap them several, it never worked.
Unread 01-25-2018, 06:05 PM
FRC #6911 (SOBOTZ)
Rookie Year: 2018
Smile Re: ultrasonic range finder issue
Hi CD
I got the Vex rangefinder working, but it only works when I plug it onto the Navx D/IO port.
Anyway the most important, I get it work, thank for your help.
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
