Go to Post This pic became proof that engineers should never give up thier day jobs! :p - Jay H 237 [more]
Unread 01-13-2018, 11:28 AM
beanieweenie beanieweenie is offline
FRC #5987
beanieweenie is an unknown quantity at this point
RSL connection
Where can our team buy the RSL power input from? (The plastic that connects to the RSL and the cables connect to it)
Unread 01-13-2018, 11:30 AM
forbes's Avatar
forbes forbes is offline
NYC Googler
AKA: Evan Forbes
FRC #0694 (StuyPulse)
forbes has much to be proud offorbes has much to be proud offorbes has much to be proud offorbes has much to be proud offorbes has much to be proud offorbes has much to be proud offorbes has much to be proud offorbes has much to be proud of
Re: RSL connection
Here is one possible source: http://www.andymark.com/product-p/am-2133.htm
Unread 01-13-2018, 11:34 AM
Billfred's Avatar
Billfred Billfred is offline
Eat, Sleep, Break The Streak
AKA: Less Curt Hawkins, More a Paul Heyman Guy
FRC #1293 (Pandamaniacs); FTC #11444 (Garnet Squadron)
Re: RSL connection
Originally Posted by forbes View Post
Basically this. Every team I've been on since those became the signal light has just chopped up a 2-wire or PWM cable to do the job.
William "Billfred" Leverette - Gamecock/Jessica Boucher victim/Taking on some tall orders.
2017: FRC 5402 (Iron Kings) - Mentor, Coach
2018-: FRC 1293 (Pandamaniacs) - Mentor
106 events (more than will fit in a ChiefDelphi signature), 14 seasons, over 70,000 miles, and still on a mission from Bob.
Unread 01-13-2018, 11:38 AM
FRC #5987
Re: RSL connection
Are you sure we can chop a PWM cable? Will it pass the inspection?
Unread 01-13-2018, 11:46 AM
Billfred's Avatar
Re: RSL connection
Read R59, and Table 8-4 below. Last row, emphasis mine:
"SIGNAL LEVEL circuits (i.e. circuits which draw ≤1A continuous and have a source incapable of delivering >1A, including but not limited to roboRIO non-PWM outputs, CAN signals, PCM Solenoid outputs, VRM 500mA outputs and Arduino outputs)" calls for 28 AWG minimum wire size.
am-0693 is 22 (and remember, lower numbers are bigger). AndyMark doesn't post the size of the 2-wire cable (and it would be bad practice to put it on the robot without verifying wire size off something like the insulation), but I've run the cable on RSLs before without incident
Unread 01-13-2018, 11:48 AM
nickbrickmaster's Avatar
nickbrickmaster nickbrickmaster is offline
Not Allowed Near Power Tools
AKA: Nick Schatz
FRC #3184 (Blaze Robotics)
nickbrickmaster has a reputation beyond reputenickbrickmaster has a reputation beyond reputenickbrickmaster has a reputation beyond reputenickbrickmaster has a reputation beyond reputenickbrickmaster has a reputation beyond reputenickbrickmaster has a reputation beyond reputenickbrickmaster has a reputation beyond reputenickbrickmaster has a reputation beyond reputenickbrickmaster has a reputation beyond reputenickbrickmaster has a reputation beyond reputenickbrickmaster has a reputation beyond repute
Re: RSL connection
Yes you can definitely chop up PWM cables. Actually, if you look at the roboRIO port for the RSL, it's actually .3 inches wide (allowing a PWM wire to be put in without cutting up the housing.) I don't like to infer intent, but this seems fairly obvious that the RSL could be powered with a PWM cable.
I have approximate knowledge of many things.
Any man who must say "I am the king" is no true king.
2018 is the year of Minnesota on Einstein.
FRC 3184: 2014-, FTC 10648: 2015-2016
Unread 01-13-2018, 12:24 PM
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Re: RSL connection
Also, being a signal level wire, there is no wire color requirement.
Unread 01-13-2018, 01:45 PM
FRC #5987
Re: RSL connection
Understood, thanks everyone!
Unread 01-13-2018, 02:38 PM
Re: RSL connection
That was exactly the intent.
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
