OCCRA
Go to Post This year's theme is "It will be neat if it works!" - s_forbes [more]
  #31   Spotlight this post!
Unread 08-14-2018, 10:58 AM
Jared Russell's Avatar
Jared Russell Jared Russell is offline
4933T15
FRC #0254 (The Cheesy Poofs), FRC #0341 (Miss Daisy)
Jared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond repute
Re: Rubber Belting
We always lap welded the belts on 341. Once you practice a few times, it's dead simple. We didn't even use a hot plate - just a wooden fixture the width of the belt, a metal plate to press down on top, and a pair of heat guns.
  #32   Spotlight this post!
Unread 08-14-2018, 11:00 AM
Clint Ott's Avatar
Clint Ott Clint Ott is offline
Mentor
AKA: Clint Ott
FRC #1619
Clint Ott has a reputation beyond reputeClint Ott has a reputation beyond reputeClint Ott has a reputation beyond reputeClint Ott has a reputation beyond reputeClint Ott has a reputation beyond reputeClint Ott has a reputation beyond reputeClint Ott has a reputation beyond reputeClint Ott has a reputation beyond reputeClint Ott has a reputation beyond reputeClint Ott has a reputation beyond reputeClint Ott has a reputation beyond repute
Re: Rubber Belting
Originally Posted by IndySam View Post
There's lots of videos out there that show you how to do it.
McMaster kit.
https://www.mcmaster.com/#belt-welding-kits/=1e57vo0
The MM clamp is expensive but there are cheaper alternatives.
We've used the same kit McMaster sells the last to years (on loan from a sponsor) and have had pretty good success. We didn't use it as a conveyor but rather as a low profile power transfer for our collectors in 2017 and 2018.
As far as the belt material goes, for some reason we had better success with the orange MM flat belt than the black belt sold by Vex. Probably user error.
  #33   Spotlight this post!
Unread 08-14-2018, 02:42 PM
BSV BSV is offline
Lead Mentor
AKA: Travis
FRC #2723 (Team Rocket)
Rookie Year: 2011
BSV has much to be proud ofBSV has much to be proud ofBSV has much to be proud ofBSV has much to be proud ofBSV has much to be proud ofBSV has much to be proud ofBSV has much to be proud ofBSV has much to be proud ofBSV has much to be proud of
Re: Rubber Belting
How about something like this?
http://www.grifiti.com/band-joes.html
One of our FTC teams used it a couple of years ago for transferring plastic balls to a shooter (but ended up using surgical tubing because they needed a little more thickness). They seemed pretty strong.
  #34   Spotlight this post!
Unread 08-16-2018, 07:59 PM
fargus111111111's Avatar
fargus111111111 fargus111111111 is offline
ME who pretends to code
AKA: Tim W
FRC #0343 (Metal in Motion)
Rookie Year: 2010
fargus111111111 is a splendid one to beholdfargus111111111 is a splendid one to beholdfargus111111111 is a splendid one to beholdfargus111111111 is a splendid one to beholdfargus111111111 is a splendid one to beholdfargus111111111 is a splendid one to behold
Re: Rubber Belting
Originally Posted by Billfred View Post
Correct--torque is transferred by the friction between the belt and the pulley.
Round belts are also available, which is what I've used in the past. Mostly because, for the longest time since they started appearing in robots, urethane flat belts were only available in orange and we were building robots on the campus of a college that feels a certain way about orange. With access to a lathe, pulleys weren't particularly tough to groove.
343 has used said orange belts frequently, we see no problem with color, in fact, we liked it so much that we decided to buy orange plastic for our printer and orange LEDs for looking pretty.
I didn't break it... this time.
play is the highest form of research-Einstein
  #35   Spotlight this post!
Unread 08-16-2018, 08:17 PM
AKA: Tim W
Rookie Year: 2010
Re: Rubber Belting
In all seriousness though, 343 has used the round poly-cord belts (which is the same material, different shape) many times for intakes and frequently used PVC pipe with tape or wheel rubber material "flanges" to keep the belts in place. We have yet to have major tension or slipping problems but we do usually mount one end on a slide (similar to what you would do for a chain) to make it easy to tension and usually for an intake getting it as tight as you can by hand is more than enough. We usually want the belt to slip before the motor stalls if there is something caught in the intake.
Side note: I have not paid enough attention to notice if someone from 5172 Gators has posted here but I know they have a great affinity for this stuff.
  #36   Spotlight this post!
Unread 08-17-2018, 07:19 AM
risho900 risho900 is offline
FRC #6897 (Astraea Robotics)
Rookie Year: 2015
risho900 will become famous soon enough
Re: Rubber Belting
How do you adapt the PVC to a shaft or the motor or something?
  #37   Spotlight this post!
Unread 08-17-2018, 10:21 AM
frcguy's Avatar
frcguy frcguy is offline
Sitting behind a Toughbook
AKA: Nicholas Dal Porto
FRC #0190 (Gompei and the H.E.R.D.)
Rookie Year: 2012
frcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond repute
My team in high school always 3D printed a cap and epoxied it inside the end of the tube. Worked well and you can fit almost any shaft style that way.
Team 5940: 2015-2018 | Team 190: 2018-present
Volunteer: 2016-present
Event Travel Spreadsheet
  #38   Spotlight this post!
Unread 08-17-2018, 12:30 PM
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
Re: Rubber Belting
Back in the day we used to take blocks of Delrin and throw them on a lathe and make our own caps for this sort of thing, 3D printers have made that a lot easier.
2005-2008: FRC 703 Phoenix - Robot Driver
2009-2016: FRC 703 Phoenix - Mentor
2017-????: FRC 5712 Gray Matter - Mentor
  #39   Spotlight this post!
Unread 08-17-2018, 12:40 PM
BumblingBuilder's Avatar
BumblingBuilder BumblingBuilder is offline
Red is fast
AKA: Matthew
FRC #6844 (Provotypes)
Rookie Year: 2014
BumblingBuilder is a name known to allBumblingBuilder is a name known to allBumblingBuilder is a name known to allBumblingBuilder is a name known to allBumblingBuilder is a name known to allBumblingBuilder is a name known to all
Re: Rubber Belting
My team used silicone rubber bands for our 2017 gear conveyor system, and they worked great. We were originally going to use the flat poly belts, but they weren't gripping on the gear like we wanted.
Just as a warning, they do snap, and we found no effective way to patch them. Between our practice and competition robots, we probably broke around 10 bands, and a lot more on prototypes. But other than that I really did like these belts. If you do use any type of band, just make sure to make them easily accessible as to replace them in the event they snap.
2014-17: FRC 2169 Mechanical/CAD, Head of Mechanical (2017), FTC 7897 Mechanical (2014), FLL, KTC (KING TeC Challenge), and FTC mentor
2018, 2020-: BYU Civil Engineering Major, FRC 6844 Mentor
  #40   Spotlight this post!
Unread 08-17-2018, 01:14 PM
RoboChair's Avatar
RoboChair RoboChair is offline
He who fixes with hammers #tsimfd
AKA: Devin Castellucci
FRC #1678 (Citrus Circuits and 5458 Digital Minds)
RoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond repute
Re: Rubber Belting
Figured I should drop this here. We do have a good method for flat belt welding that I need to get video of, it's pretty simple.
https://youtu.be/fYKsIe-yMrA
Enjoy!
12 Years and counting! Over a third of my life has been spent with FRC.
  #41   Spotlight this post!
Unread 08-17-2018, 01:15 PM
nuclearnerd's Avatar
nuclearnerd nuclearnerd is offline
Speaking for myself, not my team
AKA: Brendan Simons
FRC #5406 (Celt-X)
Rookie Year: 2014
nuclearnerd has a reputation beyond reputenuclearnerd has a reputation beyond reputenuclearnerd has a reputation beyond reputenuclearnerd has a reputation beyond reputenuclearnerd has a reputation beyond reputenuclearnerd has a reputation beyond reputenuclearnerd has a reputation beyond reputenuclearnerd has a reputation beyond reputenuclearnerd has a reputation beyond reputenuclearnerd has a reputation beyond reputenuclearnerd has a reputation beyond repute
Re: Rubber Belting
1.25" OD x 0.065" wall aluminum tubes are *really* close to fitting over a Vex versahub and/or 1/2" hex bearing. Take a little sandpaper to the ID and you'll be able to press one in. Then you can run run a hex shaft through the middle and drive it however you like.
Alternatively this which is close to the same thing, or 3D printing if the torque is low.
  #42   Spotlight this post!
Unread 08-17-2018, 01:33 PM
Chris is me's Avatar
on a break
AKA: Pinecone
no team (formerly FRC 3929, 228, 2791)
Re: Rubber Belting
Originally Posted by nuclearnerd View Post
1.125" OD x 0.065" wall aluminum tubes are *really* close to fitting over a Vex versahub and/or 1/2" hex bearing. Take a little sandpaper to the ID and you'll be able to press one in. Then you can run run a hex shaft through the middle and drive it however you like.
Do you mean 1.25" OD? (would be just under 1.125" ID)
Sort-of looking for a new team in or near Chicago; PM me if you have a lead.
Mentor: 3929 (2018)
Mentor / Drive Coach: 228 (2016-17) - 2016 RIDE Winner &
Consultant: 2170 (2017)
College Mentor: 2791 (2010-15) Build Photos - 2013 WPI Finalists, 2012 BAE Finalists
Student: 1714 (2009) - 2009 MN 10K Lakes Winners
  #43   Spotlight this post!
Unread 08-17-2018, 01:37 PM
Lil' Lavery Lil' Lavery is offline
Hungry Dawgs Run Faster
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Lil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond repute
Send a message via AIM to Lil' Lavery
Re: Rubber Belting
PVC end caps can be adapted to either accept a shaft directly (via hex broach or keyway broach) for light load applications or to have a bolt circle for an AndyMark or Vex hub (or even a direct sprocket mount). The latter option is particularly easy if you have a rotary table, but can also be done by match drilling if you are careful about piloting the hub into the center (preferably drilling the center hole with a lathe).
That being said, we haven't built a PVC roller system in several years, so our previous design metholodoly is a bit outdated compared to what we'd do if we were to build one in 2019 (likely 3D print).
Being correct doesn't mean you don't have to explain yourself.
  #44   Spotlight this post!
Unread 08-17-2018, 01:49 PM
AKA: Brendan Simons
FRC #5406 (Celt-X)
Rookie Year: 2014
Re: Rubber Belting
whoops, yep. Fixed.
  #45   Spotlight this post!
Unread 08-17-2018, 02:03 PM
Tom Line's Avatar
Tom Line Tom Line is offline
Don't lay blame. Fix probems.
FRC #1718 (The Fighting Pi)
Rookie Year: 1999
Tom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond repute
Re: Rubber Belting
Back in our no-money days we did exactly what you suggested. The first time we drilled it on our drill press and installed a hub - and a year or two later we hex broached them. We also used oil-lite bushings in them from mcmaster quite successfully when we wanted idlers.
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
