OCCRA
Go to Post PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part. - dlavery [more]
CD-Media
Unread 11-25-2018, 10:49 PM
dominikWin dominikWin is offline
FRC #1014
Rookie Year: 2015
dominikWin is a glorious beacon of lightdominikWin is a glorious beacon of lightdominikWin is a glorious beacon of lightdominikWin is a glorious beacon of lightdominikWin is a glorious beacon of lightdominikWin is a glorious beacon of light
Badlog data logging framework
Hi everyone,
I wanted to share what I worked on this past season.
After an eventful 2017 year when Team 1014 first deployed a swerve drive bot, we spent months trying to iron out all the kinks. Logging every possible metric we had access to helped tremendously but resulted in some pretty hacked together code. It became clear that we needed a better system that would not only gather data reliably but also allow us to visualize it, and most importantly make it accessible to all team members. So, with memories of matching corrupt CSVs to match videos still fresh in mind I started working on a fix: badlog. In short, we get dynamically generated HTML versions of our data logs. Details and source code are available in the whitepaper.
So what makes badlog good?
Despite having a slight bit of a bias I can confidently say that using badlog as a user in the 2018 season made life easier as a programmer. We set up badlog once at the start of the season, and since then within seconds of every match we get intimidate visualized data. It never broke; it helped catch countless problems, big and small, at every competition; and is as risk-averse as you expect any logging system to be. All of these logs for the season are available online here; as they were during our competitions. Describing a visualization system with text doesn't do it justice, so that last link is a good example of the system.
Badlog has greatly helped our team by being a compelling alternative to conventional FRC logging. It provides useful information, as shown in the examples, and does this well, as shown in the whitepaper. Team 1014 is also making this available to other teams and is more than willing to provide assistance if needed, and with any luck team 1014 won't be the only ones showing off our logs this upcoming season.
Unread 11-26-2018, 01:57 AM
AllenGregoryIV's Avatar
AllenGregoryIV AllenGregoryIV is offline
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Team Role: Coach
AllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond repute
Send a message via AIM to AllenGregoryIV
Re: Badlog data logging framework
This is really cool, I'm excited to look into this more.
Team 647 | Cyber Wolf Corps | Alumni | 2003-2006 | Shoemaker HS
Team 2587 | DiscoBots | Mentor | 2008-2011 | Rice University / Houston Food Bank
Team 3847 | Spectrum | Coach | 2012-20... | St Agnes Academy
LRI | Alamo Regional | 2014-20...
"Competition has been shown to be useful up to a certain point and no further, but cooperation, which is the thing we must strive for today, begins where competition leaves off." - Franklin D. Roosevelt
Unread 11-26-2018, 06:23 AM
gerthworm's Avatar
gerthworm gerthworm is offline
Making the 1's and 0's
FRC #1736 (Robot Casserole)
Rookie Year: 2015
gerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond repute
<3 for highcharts!!!
We've been doing time-series logging for the past couple years and it's repeatedly proved invaluable at finding root cause of issues, and even predicting issues before they happen!
For disk space issues, we log to a 16gb usb drive that we attache to the RIO. Has the added advantage of being able to pull it off the robot to download the log files, though we usually are just using a python script that does an scp operation.
Unread 11-26-2018, 09:22 AM
Andrew Schreiber Andrew Schreiber is offline
Petitioning the UN to ban Lythgoe
Rookie Year: 2000
Andrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond repute
Do you make use of the actual bag files or only the CSVs?
We're working on a similar approach but running into issues with bag files due to the size of the ones output from ROS. (even with compression we're in the multiple GB range)
Unread 11-26-2018, 09:38 AM
FRC #1014
Rookie Year: 2015
Just CSVs, but we don't call them CSVs in case someone tries to open them in excel and gets errors when it finds JSON in the header. Calling them bags is really just because other names were taken from ros and rosbags are the closest thing to this.
Unread 11-26-2018, 10:11 AM
FRC #1014
Rookie Year: 2015
As far as disk space goes we didn't really have any trouble. CSV with truncated decimals is really space efficient even without compression. We created files just under 2MB per match, so we could easily push 50+ matches without any worry. At one point had two separate competitions on the Rio at once and we had 147MB to spare.
So if you log around as much as we did (35-40 data topics) that ends up being around 4 hours to get to 150MB. Since we cut the rate down to 4 updates/s when disabled we can go around two full days on standby.
Unread 11-26-2018, 10:28 AM
Rookie Year: 2000
So... they aren't actually ROS bag files at all just CSV files?
Unread 11-26-2018, 10:41 AM
FRC #1014
Rookie Year: 2015
Huh, looks like my last response got lost but a later one went through. Yeah they are all CSV files (with a JSON header), but not called that in case someone tries to open them in excel or something. Badlog takes a lot of its names from ros and since rosbag is the closest thing we ended up calling them bag files.
Unread 11-26-2018, 10:58 AM
gerthworm's Avatar
Rookie Year: 2015
If you do happen to decide to choose a new file extension in the future for your json+csv format, may I suggest ".badbag", purely because it's fun to say?
Unread 11-26-2018, 11:04 AM
FRC #1014
Rookie Year: 2015
Well badlog doesn't control what you name the files, that's left up to the user. I'm pretty sure you just settled what we'll be using next year though
Unread 11-26-2018, 11:21 AM
Rookie Year: 2000
mmk, I was going to be VERY shocked if you'd flat out stollen the bag file format. Woulda made me happy since it would have just let us drop in our rosbag files
Unread 12-05-2018, 02:07 PM
coderkevin coderkevin is offline
AKA: Kevin Killingsworth
FRC #2357 (System Meltdown)
Team Role: Coach
Rookie Year: 2012
coderkevin is an unknown quantity at this point
Thanks for posting this. I think we'll use some of our dwindling time before kickoff trying it out.
Powered by vBulletin®
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
