OCCRA
Go to Post I'm definitely not advocating PVC tanks. I'm just saying that if you're going to be an idiot, please be slightly less of an idiot. - FourPenguins [more]
CD-Media
Unread 12-04-2018, 11:46 AM
trycatch's Avatar
trycatch trycatch is offline
FRC #5858
Rookie Year: 2015
trycatch is a name known to alltrycatch is a name known to alltrycatch is a name known to alltrycatch is a name known to alltrycatch is a name known to alltrycatch is a name known to all
Shapeko XL for FRC?
Hey all! So, my plans to get a bigger workspace outside our school have kind of fallen to the wayside for right now, so I'm looking for a CNC that we could actually use in our limited space. I'm looking at a Shapeoko XL right now - I've got a new benchtop toolbox that it could live on and fit perfectly. It's only 1.25HP, which isn't ideal, but in theory I could upgrade the router and have a bit more power for aluminum, right?
Unread 12-04-2018, 12:00 PM
Akash Rastogi's Avatar
Head Coach | Lead Mentor
FRC #5686 (Wirecats)
Re: Shapeko XL for FRC?
Check out this very active discussion in our community for better recommendations:
https://www.chiefdelphi.com/forums/s...hreadid=158505
I suggest reading through it as many people have weighed in on the Shapeoko as an option.
Jim Zondag is my spirit animal.
['18-'xx]: Lead Mentor FRC 5686 (formerly FRC 1059)
['17-'17]: Mentor FRC 2170
['13-'14]: Floating Mentor FRC 11/FRC 2495
['11-'13]: Founding Mentor FRC 3929 - 2012 World Championship Rookie Inspiration Award
['07-'10]: Student/Captain FRC 11 - MORT
Unread 12-04-2018, 07:48 PM
asid61's Avatar
asid61 asid61 is offline
Design Simple
AKA: Anand Rajamani
FRC #1072 (Harker Robotics)
Rookie Year: 2013
You'll never hit the 1.25HP limit. The bigger issue is the plastic rollers that act as guides and the flexbility of the belts and frame. You can do plastic and wood well, but doing bulk aluminum will be a challenge.
3991 was able to run theirs at 15IPM 0.03" DOC slotting aluminum with a 1/8" bit, but they also spent a lot of time reassembling it and tightening stuff down. If you can scrape together the extra money, an Omio X6 or X8 will be better.
Team 1072 2017-present
Team 299 2017
Team 115 2013-2016 (student)
2018 Davis Finalists (w/ 6474 and 3880), 2018 Roebling Winners (w/ 3476, 1323, and 1778)
Unread 12-05-2018, 09:10 AM
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
A few years back, a team I was on used an X-Carve (which is VERY similar in design and function to a Shapeoko) to make a few parts. As asid61 mentioned, you should be able to do wood and plastic (including polycarbonate) without any major issues. With the proper bits, cutting fluid, and VERY slow feed rates, you CAN cut thin aluminum (I wouldn't recommend using it for more than 1/8" thick aluminum), though it's far from an ideal solution.
In the case of our machine, we had some issues holding tolerances on round pockets (IE bearing holes), so I'm not sure I'd build a gearbox with it (though granted, our issues may have been due to bad settings/calibration on our part), but otherwise it's great for cutting parts out of sheets of material, or drilling bit-size holes (rather than pockets).
2005-2008: FRC 703 Phoenix - Robot Driver
2009-2016: FRC 703 Phoenix - Mentor
2017-????: FRC 5712 Gray Matter - Mentor
Unread 12-05-2018, 09:38 AM
Chris is me's Avatar
on a break
AKA: Pinecone
no team (formerly FRC 3929, 228, 2791)
Shapeoko is a neat machine that's great for wood, but it's not going to be rigid enough for aluminum. It's not horsepower that's the limiting factor, but rigidity.
Sort-of looking for a new team in or near Chicago; PM me if you have a lead.
Mentor: 3929 (2018)
Mentor / Drive Coach: 228 (2016-17) - 2016 RIDE Winner &
Consultant: 2170 (2017)
College Mentor: 2791 (2010-15) Build Photos - 2013 WPI Finalists, 2012 BAE Finalists
Student: 1714 (2009) - 2009 MN 10K Lakes Winners
Unread 12-05-2018, 09:43 AM
Ryan Dognaux's Avatar
Ryan Dognaux Ryan Dognaux is offline
The Nature Bot - WOOOO!
FRC #1720 (PhyXTGears)
Ryan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond repute
Send a message via AIM to Ryan Dognaux
If you're wanting to cut aluminum just get an Omio router. It's a little more expensive but an infinitely more useful machine for FRC.
Ryan Dognaux :: Last Name Pronounced 'Doane Yo'
Team 234 Alum: 2002 - 2005 :: Purdue FIRST Member: 2006 - 2009
Team 1646 Mentor: 2007 - 2009 :: Team 357 Mentor: 2009 - 2012
Team 4329 Mentor: 2013 - 2017 :: Team 1720 Mentor: Current
STL Off-Season Event: www.gatewayroboticschallenge.com
Unread 12-05-2018, 09:50 AM
Monochron's Avatar
Monochron Monochron is offline
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
Winston Moy has a variety of videos about getting the Shapeoko to cut aluminum. It takes him a good bit of work. He never really gets into measuring how tight its tolerances are, I suspect they aren't tight enough for things like gearboxes but I honestly don't know.
2018 | Gracious Professionalism x3, Asheville Winners, NCCMP Finalists, NC District - 3rd Rank
2017 | Industrial Design, Gracious Professionalism, NCCMP Winners, NC District - 1st Rank
2016 | Innovation In Controls, Industrial Design, Quality Award, NC District - 4th Rank
Unread 12-05-2018, 03:29 PM
Lil' Lavery Lil' Lavery is online now
Hungry Dawgs Run Faster
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Lil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond repute
Send a message via AIM to Lil' Lavery
He talks about tolerances in his video on adaptive toolpaths. His initial results arenít great, particularly for things like gearboxes. But he didnít run either a finishing pass or spring pass, and he wasnít boring all the way through the piece, both of which may produce tighter tolerances.
https://m.youtube.com/watch?feature=...&v=b-yBVOiJ4dY
Being correct doesn't mean you don't have to explain yourself.
Powered by vBulletin®
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
