OCCRA
Go to Post No one said that this would be easy. And if they did, they were obviously refering to a little red button from Staples and not to FIRST. - artdutra04 [more]
CD-Media
Unread 12-04-2018, 09:40 PM
olidem123's Avatar
olidem123 olidem123 is offline
Student and lead LabVIEW mentor
AKA: Olivier Demers
FRC #5618 (PLS)
Rookie Year: 2015
olidem123 is an unknown quantity at this point
Electric board 5618
This electric board is designed to fit on almost every robot.
CAD files are on this link:
https://www.mediafire.com/file/0x0sa9q35bxs3md/Electric_board_5618.zip/file
PLS 5618 on Facebook and TheBlueAlliance
Our team's program this year (Requires CTRE Phoenix framework and ADIS16448 IMU Library)
Our dashboard
Feel free to contact me for any question
Unread 12-05-2018, 09:47 AM
AriMB's Avatar
AriMB AriMB is offline
The Philadelphian emigrant
AKA: Ari Meles-Braverman
FRC #5987 (Galaxia)
Rookie Year: 2012
AriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond repute
Re: Electric board 5618
What advantages do you see of this design over a board designed specifically for the robot itís going on?
Studying MechE at the Technion - Israel Institute of Technology
2017-present: FIRST Israel CSA/FTAA
2017-present: FRC 5987 Technical Mentor 18isr2 18isr4 18isrcmp 18carv
2012-2016: FRC 423 Member 15njtab 15padre 16paphi
Unread 12-05-2018, 09:56 AM
Unsung FIRST Hero
Chief Robot Inspector
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Oliver, I like that you centrally locate the PDP to minimize wire run length to high current motor controllers.
Please keep in mind that the breakers and wire on the PDP must be visible for inspection when considering your designs.
Al
WB9UVJ
www.wildstang.org
________________________
Knowledge is power. Power UP!
BClarke's Avatar
BClarke BClarke is offline
FRC #1723 (The FBI FIRST Bots of Independence)
Team Role: Mechanical
Rookie Year: 2016
BClarke is an unknown quantity at this point
Originally Posted by BenjaminRowe View Post
Hello, I like this design a lot, is there any way to can release it as a dwg? I don't have any software to open/edit STEP files with
Onshape and Fusion 360 are both free programs that you can use to open and manipulate STEP files.
Unread 12-05-2018, 12:24 PM
philso philso is offline
Mentor
FRC #3103 (Iron Plaid)
philso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond repute
While the design is very compact, it creates some manufacturabilty, serviceability and durability issues. That is always the price one must be willing to pay for using compact arrangements like this. In industry, hinged panels are used only as a last resort.
It would be best if you can make a mock up of your design using sheets of cardboard. Include all the wiring. See how the other team members like working with it; the poeple who will build it, the programmers, the pit crew and Robot Inspectors.
Unless you use very flexilbe wiring and secure the wiring in just the right way, the panels with the motor controllers might become difficult to move.
In your current design, there might not be sufficient bend radius for the 6 AWG wires coming from your battery and breaker, even if you use the very flexible types of wire. It would also be best if the 6 AWG wires could be secured to the panel, especially if you intend for this whole assembly to be removable from the robot.
It would be best to secure the input and output wires of all your motor controllers to the panels that the motor controllers are mounted on. Otherwise, you can damage the wires where they exit the case of the motor controllers as you open and close those panels. Such damage is likely to (initially) manifest it self as intermittent open circuits. Please note that the motor controllers do not have strain reliefs or grommets on any of the wires. Any damaged wires will have to be replaced by opening up the case and soldering on new wires.
Currently, there are no breakers installed in the PDP. Is there sufficient space between the PDP and the motor controllers to accomodate the breakers and the wiring from the motor controller outputs to the motors? Will the wiring be pinched?
How will it be possible to inspect the breakers?
The motor controllers have diagnostic LED's that will not be visible when the panels are in the closed condition. Is this acceptable to your programming team?
The panels that the VRM and PCM are mounted on are not very wide. Is there sufficient access to inspect your wiring and make changes to the wiring if this assembly is mounted on a larger panel? If this assembly is to be removable from the robot, all the wiring to and from the VRM and PCM must be secured to the panels to avoid damage.
Powered by vBulletin®
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
