OCCRA
Go to Post We all change, and we need to make sure that we can grow and change together in a positive way. Keep close the people who are capable of doing this with you, and you will surround yourself with the tools for success. - Jaine Perotti [more]
CD-Media
  #31   Spotlight this post!
Unread 10-03-2018, 07:50 PM
JohnSchneider's Avatar
JohnSchneider JohnSchneider is offline
FRC #3310 (Black Hawk Robotics)
Rookie Year: 2010
JohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond repute
Re: Blockading Rule Reform
Originally Posted by BrennanB View Post
You do have to move to block effectively unless your robot can't turn. Hitting a corner of a robot that you can not push still will rotate them out of the way and they no longer have the benefit of their wheel friction helping them as much.
If there was no skill involved in playing this defense, more people would have played it, as you can see, it was pretty effective at some of the highest level of play. It's also pretty important to note that drivers make mistakes all the time, there is no flawless match where nothing could have been improved. You always can find an error and work with it.
I should clarify that I don't disagree that it is difficult to get around this defense due to the choke point, and I want to loop back to my original point. I believe that there is skill in playing defense well enough to prevent a team from passing through that choke point. You can find plenty of poor defense in this area that is less than effective. The point that is important is that there is an probable inconsistency with level of driving skills, where if you have a weak enough driver that has low ability as the defended robot, they may be the benefactor of a blockading foul/counting from the ref, while a more skilled driver (like 3310) may be able to avoid them (as shown with the positioning errors on the two clips I linked) and thus it makes it harder to call blockading consistently, which is a problem worth addressing in my opinion.
It is possible to construct a blue robot such that it cannot be turned in that situation. In fact it's quite easy to do, look up 1817.
It is not hard to call blockading this year. If the defending alliance has a robot in between the switch and an opposing robot is trying to get through and is impeded, then its blockading. Regardless of driver skill. It is an attempt to stop a required flow of the game. Its cut and dry.
  #32   Spotlight this post!
Unread 10-03-2018, 08:02 PM
jtrv's Avatar
jtrv jtrv is offline
AKA: Justin
FRC #5254 (HYPE)
Team Role: Team Spirit / Cheering
Rookie Year: 2012
jtrv has a reputation beyond reputejtrv has a reputation beyond reputejtrv has a reputation beyond reputejtrv has a reputation beyond reputejtrv has a reputation beyond reputejtrv has a reputation beyond reputejtrv has a reputation beyond reputejtrv has a reputation beyond reputejtrv has a reputation beyond reputejtrv has a reputation beyond reputejtrv has a reputation beyond repute
There is a reason these lanes are not protected zones.
2791 - 2012-17 | 340 - 2018 | 5254 - 2018-*
My opinions do not reflect those of my team(s).
  #33   Spotlight this post!
Unread 10-03-2018, 08:04 PM
BrennanB's Avatar
BrennanB BrennanB is offline
🥛Milk🥛
AKA: Brennan Bibic
FRC #4476 (W.A.F.F.L.E.S.)
Team Role: Coach
BrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond repute
Okay. Lets suppose you are correct, show me a match where a team played defense against a competent driver where the defender was positioned in between the switch wall and the alliance wall, and the defender completely destroys the offense.
Since as you say there isn't much to pulling off successful defense, it should be relatively easy to find a good match showcasing this.
I've shown you plenty of evidence showing that you can get through that defense, can you show me one where the defender prevented the robot from scoring for a very long period of the match? 30s+?
Brennan Bibic - 2014 DLF - Drive Coach
“Skills are cheap. Passion is priceless.”Gary Vaynerchuk
FRC|> 2009-2012 (K-Botics #2809) -> 2013-2019 (W.A.F.F.L.E.S. Community Robotics #4476)
FLL|> 2006-2019 (W.A.F.F.L.E.S. #105)
VRC|> 2010-2013, 2015-2016 (W.A.F.F.L.E.S. #4476)
SLFF|> 2013-2019 (The Breakfast Company)
  #34   Spotlight this post!
Unread 10-03-2018, 08:24 PM
pkrishna3082's Avatar
pkrishna3082 pkrishna3082 is offline
love/hate relationship with swerve
AKA: Parthiv Krishna
FRC #3082 (Chicken Bot Pie) and FTC #13471 Mentor (Vortechs)
Team Role: Leadership
Rookie Year: 2016
pkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond repute
What is defense if not "an attempt to stop a required flow of a game"?
“Screws fall out all the time. The world is an imperfect place.”
2010-2011: FLL 11083, 13873 (Minnetonka Silver) - Programmer
2016-: FRC 3082 (Chicken Bot Pie) - Engineering Captain, Driver, Programming Lead
2017-: FTC 13471 (Minnetonka) - Founding Mentor
  #35   Spotlight this post!
Unread 10-03-2018, 09:40 PM
GeeTwo GeeTwo is offline
Somebody Else
AKA: Gus Michel II
Rookie Year: 2013
As I originally read it, and continue to read it, the rule as written this year and most recent years was written to explicitly allow robot-on-robot defense, but to prohibit "zone" defense of all instances of a type of goal or game piece source of which there are at least two. (Additionally the 2018 rule prohibited multiple robots colluding in shutting down the exchange.) It's the clear-to-defense but sometimes subtle-to-referes difference between assigning each robot a role to defend against another robot (and perhaps double teaming), vice assigning a robot to defend each portal, or two robots to defend the exchange. Honestly, it's hard to imagine how one would shut down all access to cubes (except late in a match) or quarantine an alliance's robots to a useless zone without pinning, but either would certainly require "zone defense".
In any case, the key point is - are each of the defending robots defending against a specific robot doing anything at all (perfectly allowed), or are multiple robots working against any of the robots of the other alliance acquiring game pieces from a given type of source, or scoring them in a specific type of "goal" (not allowed)?
[Quoting brennonbrimhall]: We design a new robot every year, but we can't forget that we also design a new team every year as folks come and go.
  #36   Spotlight this post!
Unread 10-03-2018, 10:35 PM
TJP123 TJP123 is offline
AKA: Tom Pospeshil
FRC #0503 (Frog Force)
Team Role: Coach
Rookie Year: 2012
TJP123 has a brilliant futureTJP123 has a brilliant futureTJP123 has a brilliant futureTJP123 has a brilliant futureTJP123 has a brilliant futureTJP123 has a brilliant futureTJP123 has a brilliant futureTJP123 has a brilliant futureTJP123 has a brilliant futureTJP123 has a brilliant futureTJP123 has a brilliant future
I don't have a dog in this fight, but here's one. Blue robot traps red inside the zone for over 20s. Red gave up and went around or it could have gone on all day.
  #37   Spotlight this post!
Unread 10-03-2018, 10:41 PM
AKA: Tom Pospeshil
Team Role: Coach
Rookie Year: 2012
No it isn't. If there's only one robot doing this impeding it can never be blockading, not in that part of the field anyway. Making them go the long way around isn't stopping them from scoring, it's just slowing them down.
  #38   Spotlight this post!
Unread 10-04-2018, 12:07 AM
Donut's Avatar
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Donut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond repute
As you note this is just good defense, red had total access to the opposing switch (which they eventually went to) and portals, and they could have gone around the switch. We did the same thing in 2017 with airships and you wouldn't believe how many teams spent 30 seconds ramming into us instead of going the long way around. FIRST needs to have smaller field elements if this type of D is bad for the game. I personally think it fits the NFL lineman analogy well, if my robot is good enough to block yours I can keep you from doing something all day (also similar in the NFL, good DBs can jam WRs at the line with no penalty if within 5 yards of the LOS, and on some plays can literally shut them down the whole play as a result). And it takes a fairly high skill level to execute this correctly, there were a lot of teams who tried the same thing and could not strafe and position their robot effectively so teams slipped by after a few seconds.
I am all for multi-robot blockading penalties, but expanding it to single robots handicaps all defense imo.
FRC Team 498 (Glendale, AZ), Student: 2004 - 2007
FRC Team 498 (Glendale, AZ), Mentor: 2008 - 2011
FRC Team 167 (Iowa City, IA), Mentor: 2012 - 2014
FRC Team 2662 (Tolleson, AZ), Lead Mentor: 2014 - Present
  #39   Spotlight this post!
Unread 10-04-2018, 12:40 AM
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is offline
Registered Muser
no team (AndyMark)
Rookie Year: 2013
Cothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond repute
One more aspect to throw into this thread.
I think there should be some clearly defined differences between 2-on-1 pinning and blockading. If 2 robots push an opposing robot into the corner of the field, that should be considered pinning. Might be difficult to communicate or call for 2 simultaneous pinning fouls, but I still think that distinction needs to be made. 2 robots working together to pin down 1 opposing robot is a fair sight different from an alliance working together to shut down a major part of the game.
"It's taking longer than expected, which was to be expected."
  #40   Spotlight this post!
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
The first question to ask when trying to rewrite a rule is: What is this particular rule trying to protect against? The second question is: Is there another method of doing so? The third question is: Does the current punishment fit the crime?
Once those three are answered, you will know both how to start rewriting the rule and why the rule is written the way it is.
Personally, given those three questions... I would say that given the rule existed on a field with no obstructions at all, the second answer is "no", and give what my answers to the first question are, I think the punishment actually doesn't fit the crime. Denying the ability to score points (moving the goal, if you will) is penalized by a "if you screw up something else you lose that match instead". Personally, I'd add a Tech Foul to the Alliance Yellow Card (and I would keep the Alliance Card, because if you have a 10-1-1 and the 10 eggs the 1's on, I want to prevent the 10 from trying that stunt again--they're getting Red the next time, y'see). Not entirely sure I'd put a time limit but that might be a good idea--if so, call it 5 seconds and give yet another thing for the ol' tomahawk chop count to possibly mean.
Past teams:
2003-2007: FRC0330 BeachBots; 2008: FRC1135 Shmoebotics; 2012: FRC4046 Schroedinger's Dragons
  #41   Spotlight this post!
Unread 10-04-2018, 08:37 AM
JeffB JeffB is offline
FRC #5052 (RoboLobos)
Rookie Year: 2014
JeffB has a reputation beyond reputeJeffB has a reputation beyond reputeJeffB has a reputation beyond reputeJeffB has a reputation beyond reputeJeffB has a reputation beyond reputeJeffB has a reputation beyond reputeJeffB has a reputation beyond reputeJeffB has a reputation beyond reputeJeffB has a reputation beyond reputeJeffB has a reputation beyond reputeJeffB has a reputation beyond repute
Code:
Defended driver skill level: 1/10
Defenders driver skill level: 5/10
Defenders easily block the defended driver and prevent them from scoring.
Blockading is called against the defenders.
Code:
Defended driver skill level: 10/10
Defenders struggle to block the defended robot, there is a 5 second
slowdown on the defended robot but they are able to make it through.
Blockade is not called here, as the robot could make it through.
In both cases, the actions of the red robots were identical, the only difference is that the blue robot was able to make it through due to driver skill alone. I don't think it's a good idea to make rules that encourage weak driving from the defender, and discourage good defense from defenders.
Code:
Don’t collude with your partners to shut down major parts of game play. Two or more
ROBOTS may not isolate or close off any major component of MATCH play from an ALLIANCE.
Violation: RED CARD for the offending ROBOT(S). TECHNICAL FOUL
Let me know what you think!
For the first part, I'd wholly disagree. You've presented a hypothetical that doesn't really represent what we're seeing in the situation discussed. Robots with basic drive skills can drive forward and backward leaving their robot in a sideways position. A driver with excellent skill will still have a harder time moving around that robot, especially given the sideways positioning. If you want to avoid providing incentive to poor driving skill, you wouldn't want to enable a blockade as seen at Chezy. Weakening the rule enables poor driving making a larger impact.
For the last part, I'm not sure how it makes sense. If you're assigning a red card for the alliance, there are exactly zero point values that have any actual value. Winning by 1 or 1000 results in the same win. Why assign a foul of any kind? It doesn't change anything. I'd agree with the red card as it closes a loophole many teams have considered using. But, I don't see the point in adding insult to injury with a foul beyond that.
Any thoughts I share are meant to be my interpretation of rules/events/intents. They shouldn't be viewed as anything even approaching an official viewpoint.
  #42   Spotlight this post!
Unread 10-04-2018, 08:48 AM
Rookie Year: 2014
I'd agree that it's cut and dry. However, it's in the opposite direction of what you're suggesting. It's cut and dry that blockading requires two robots. The case you described only has one.
It's very difficult to call blockading this year. Here are some things for you to consider before providing a counterpoint:
1) blockading MUST include multiple robots
2) those robots MUST be working together
3) their actions MUST be shutting down some aspect of game play in a way that goes beyond what one would consider reasonable defense
4) there are very few places two robots can perform this task in this year's game without putting themselves at risk of drawing other fouls
5) as blockading asks for a judgement call on intent, it needs to be fairly clear both robots are intending to take the action it appears they're taking. For example, if one is "in the way" but clearly focusing their efforts on scoring in the scale/switch, it's very difficult to state "their scoring was a decoy, they intended to block access."
Blockading is historically difficult to call for these reasons. In fact, there was once a discussion with a mentor from your team and a mentor from one of your alliance partners where in frustration, a remark along the lines of "if it's that hard to call, then it isn't a rule at all" was thrown out.
If it were as cut and dry as you believed, this wouldn't be a debate. Unfortunately, the grey area exists somewhere else entirely. The part you're worried about is entirely within the realm of legitimate defense. As you suggested, I'll point towards 1817. The strategy you listed was a cornerstone of their defensive prowess this season.
  #43   Spotlight this post!
Unread 10-04-2018, 08:53 AM
BrennanB's Avatar
🥛Milk🥛
AKA: Brennan Bibic
Team Role: Coach
I understand your point, but where it falls through I think (and the point that people seem to be sticking on) is that it's really not that easy to play defense, even in that choke point for the average team/below average team. It is very difficult to get around choke points for any driver, but the difference is for a weak driver against some match ups it will be impossible, while some drivers can do it significantly easier. Blockading to me is executing a strategy which leaves the opposing alliance zero counter play, no way of still possibly winning. This is why this point was brought up. What may be impossible for one driver is just hard for another.
Hundreds of third picks have been "taught" how to play defense, and do so largely ineffectively. I think you vastly over-estimate average driver skill on defense. Most drivers are very ineffective when it comes to blocking top tier robots (even in choke points), and you can find tons of evidence from any year that will back that up, especially 2013 and 2018 since they have similar choke points. You really don't have to look far to see defense that is not effective. The point that part is trying to make is that there is a measurable skill gap in drivers, and that generally weak defense is not effective vs competent drivers. Therefore if you have weak defender against a weak defended robot, you are more likely to get a call in this situation which benefits the weak driver on the offense robot.
Qualification matches was the main reasoning behind that. Perhaps that's not required however, and that's a good discussion to have.
Thanks for the example. There are some of these that are shown that you can find, but not one where you just sit and literally do nothing and make it impossible to get by (which is what JohnSchneider was arguing) so my apologies. I am looking for an example where a robot sits in that lane, doesn't move at all, and makes it impossible to get by. (tipped over robots in the lane don't count.)
  #44   Spotlight this post!
Unread 10-04-2018, 09:30 AM
philso philso is offline
Mentor
FRC #3103 (Iron Plaid)
philso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond repute
I would argue that the defending robot made a mistake by moving. They could not be pushed. If they had just sat in the middle of the lane it would have been impossible for the offensive robot to get through. You cannot "out skill" an immovable object giving you no possible room to get through.
That is the sort of mistake one would expect a skill level 1 or 2 driver would make. The scenario you pose would require both skill level 1 or 2 robots to be well coordinated, which is consistent with drivers at a higher skill level.
1817 has ranked at #1 and #3 at events in 2014 and has often ranked in the top 10 in recent years. That is not consistent with a team at skill level 1 or 2.
  #45   Spotlight this post!
Unread 10-04-2018, 09:39 AM
Rookie Year: 2014
I'm not suggesting defense is easy. I'm suggesting it's easier than your example suggested. Your example hinges on a need for a weak driver playing defense against a strong driver trying to get around that defense. In those cases, I see your point. In every other scenario, a robot blocking a choke point provides a much greater hindrance than the ~5 seconds you suggest. The rule shouldn't look only at the best case scenario for the offense robot, for lack of a better term. It should consider the majority of cases. Let's not cherry pick examples and instead look at the overall intent. The goal is to prevent two robots from playing defense in a way that prevents teams from playing the game. Unless you're suggesting 3310's driver is a weak driver, you'd have to admit the defense in the end game of finals 3 was two robots working together with choke points to keep 3310 from playing the game. As that's the event that brought up this whole discussion, it's important to note that context.
Are you concerned about games where points scored is the ranking metric rather than RP? FRC seems pretty dedicated to RP as of late. The 2RP are far more value than the ~2 pts/match their average would be affected for tiebreaking would be.
Powered by vBulletin®
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
