OCCRA
Go to Post THE GAME PIECES ARE BEARS - JohnSchneider [more]
CD-Media
Unread 07-26-2018, 03:00 PM
fovea1959's Avatar
fovea1959 fovea1959 is offline
Herder of programmers
AKA: Doug Wegscheid
FRC #3620 (The Average Joes)
Rookie Year: 2011
fovea1959 will become famous soon enough
"Team private" libraries when using VSC Alpha
our 2018 code had some non-standard libraries; we made a /lib/ folder in the project, put the jars there, added the folder to the Eclipse build (so eclipse was happy), and listed the folder in build.properties (userLibs=lib/) so that Ant was happy when building.
How do we do this in the brave new world?
Unread 07-26-2018, 03:11 PM
gerthworm's Avatar
gerthworm gerthworm is offline
Making the 1's and 0's
FRC #1736 (Robot Casserole)
Rookie Year: 2015
gerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond repute
Re: "Team private" libraries when using VSC Alpha
Assuming they're publically available in repositories (and not custom-made ones that you build locally on the pc's), here's how we're (attempting) to do it so far:
https://github.com/RobotCasserole173...ild.gradle#L53
Unread 07-26-2018, 03:32 PM
Thad House Thad House is online now
Volunteer, WPILib Contributor
no team (Waiting for 2021)
Rookie Year: 2010
Thad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond repute
If you do want a local file, you can do the following. The root is the root of your project.
Code:
 compile files('lib/something_local.jar')
Put that inside your dependencies block.
All statements made are my own and not the feelings of any of my affiliated teams.
Teams 1510 and 2898 - Student 2010-2012
Team 4488 - Mentor 2013-2016
Co-developer of RobotDotNet, a .NET port of the WPILib.
Unread 07-26-2018, 03:41 PM
fovea1959's Avatar
AKA: Doug Wegscheid
Rookie Year: 2011
that did it.
I see that ctre() wpilib() and navx() are all defined. Is there one for pathfinder?
I can place the pathfinder.jar we have been using in lib/ and call it out, but I don't know how to handle the .so...
Unread 07-26-2018, 03:44 PM
Clayton Yocom's Avatar
Clayton Yocom Clayton Yocom is offline
Programming Mentor
FRC #0027 (RUSH)
Rookie Year: 2011
Clayton Yocom has much to be proud ofClayton Yocom has much to be proud ofClayton Yocom has much to be proud ofClayton Yocom has much to be proud ofClayton Yocom has much to be proud ofClayton Yocom has much to be proud ofClayton Yocom has much to be proud ofClayton Yocom has much to be proud of
You should also be able to create your own repository by adding
Code:
repositories {
    maven { url "file://" + projectDir + "/libs/java" }
And then using maven repository folder structure in the libs/java folder.
Example:
Have your jar in the following folder:
Code:
{project_directory}/libs/java/my/group/id/artifactid/version/artifactid-version.jar
and then add this in your dependencies section of your build.gradle
Code:
compile group: 'my.group.id', name: 'artifactid', version: 'version'
If you also have native dependencies, you can also add the following to your dependencies section as well to pick up those files.
Code:
nativeLib  fileTree(dir: 'libs/native', include: '*.so')
EDIT:
For pathfinder there is a import function as well.
Just put the following in your dependencies section.
Code:
compile pathfinder()
Member of FRC Team 45 TechnoKats : 2011 - 2016
Member of FRC Team 27 Team RUSH : 2017 - Present
Unread 07-26-2018, 03:54 PM
gerthworm's Avatar
Rookie Year: 2015
Between this and the main thread, I'll toss in a suggestion that a useful documentation section could be "Recipies" that shows short snippits of the recommended way of doing some of these advanced-but-somewhat-common actions.
Unread 07-26-2018, 03:56 PM
AustinShalit's Avatar
AustinShalit AustinShalit is offline
AKA: אוסטין
no team (WPILib Suite Developer)
AustinShalit has much to be proud ofAustinShalit has much to be proud ofAustinShalit has much to be proud ofAustinShalit has much to be proud ofAustinShalit has much to be proud ofAustinShalit has much to be proud ofAustinShalit has much to be proud ofAustinShalit has much to be proud ofAustinShalit has much to be proud of
Originally Posted by fovea1959 View Post
that did it.
This will do it:
Code:
pathfinder()
Powered by vBulletin®
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
