Go to Post It is not necessary to draw 200 amps to move a robot through a two minute match. Rule of thumb is you robot should be able to compete for three matches without a battery change. - Al Skierkiewicz [more]
Unread 02-21-2018, 08:39 AM
Leonardo Denega's Avatar
Leonardo Denega Leonardo Denega is offline
FRC #6957 (LMCA)
Leonardo Denega is an unknown quantity at this point
pic: Rookie team 6957 teaser
Unread 02-21-2018, 08:40 AM
#JusticeforPinecone
Re: pic: Rookie team 6957 teaser
The robot looks really good! Do you have at least 6" of area on each side of your frame gap for bumpers?
College Mentor of Team 5254, HYPE - Helping Youth Pursue Excellence (2015-Present)
frc5254.win
Unread 02-21-2018, 09:06 AM
Nick Lawrence's Avatar
Nick Lawrence Nick Lawrence is offline
Commander Canada
FRC #3940 (CyberTooth, AndyMark)
Nick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond repute
Great looking robot!
Did you guys make an AM14U out of flat steel pieces, and then weld flanges on to it? What thickness is it?
-Nick
Alumnus of 1503 Spartonics
Founding Mentor of 5406 Celt-X
Lead Mechanical Design Mentor of 3940 CyberTooth
Emceeing events since 2013 - come say hi!
Success doesn't always equate to match wins. It's about the wins off the field.
Unread 02-21-2018, 11:10 AM
AriMB's Avatar
AriMB AriMB is offline
The Philadelphian emigrant
AKA: Ari Meles-Braverman
FRC #5987 (Galaxia)
AriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond repute
Looks very nice. How much does the robot weigh? I imagine an all steel robot is going to weigh quite a lot.
How are you liking the rack and pinion? Are you powering your climber through it? How is the pinion handling that load?
Also can you post a video of your elevator running? I'm not quite sure I understand how it works.
Studying MechE at the Technion - Israel Institute of Technology
2017-present: FIRST Israel CSA/FTAA
2017-present: FRC 5987 Technical Mentor 18isr2 18isr4 18isrcmp 18carv
2012-2016: FRC 423 Member 15njtab 15padre 16paphi
Unread 02-21-2018, 11:17 AM
Hjelstrom's Avatar
Hjelstrom Hjelstrom is offline
FRC #0987 (High Rollers)
Hjelstrom has a reputation beyond reputeHjelstrom has a reputation beyond reputeHjelstrom has a reputation beyond reputeHjelstrom has a reputation beyond reputeHjelstrom has a reputation beyond reputeHjelstrom has a reputation beyond reputeHjelstrom has a reputation beyond reputeHjelstrom has a reputation beyond reputeHjelstrom has a reputation beyond reputeHjelstrom has a reputation beyond reputeHjelstrom has a reputation beyond repute
Looking good! This is a new rookie team in Las Vegas. We got to see their bot on Saturday and it is actually mostly made of titanium!!
Unread 02-21-2018, 08:16 PM
FRC #6957 (LMCA)
on that picture it actually doesn't, but thats a old picture, we've changing somethings.
Unread 02-21-2018, 08:17 PM
FRC #6957 (LMCA)
-Nick
We are actually using titanium sheets and they are 0.06 in thick
Unread 02-21-2018, 08:22 PM
FRC #6957 (LMCA)
Now it is around 75 pounds right now, because we were looking for a simple design.
rack and pinion are working well, sometimes it can get out of t's way, but not a problem. Yeah we are doing it and we have tested it climbing with other robot on top (system is not on that picture). They are handling well also, the only thing to be careful now on that system are the versas because if we force them on the wrong way they can brake.
we didn't take so many videos of the system
Unread 02-21-2018, 08:28 PM
FRC #6957 (LMCA)
that's right!
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
