Go to Post Our robot attacked our programmer autonomously. - sanddrag [more]
Go Back   Chief Delphi > FIRST > Rumor Mill
Unread 02-28-2018, 07:18 PM
ctt956's Avatar
ctt956 ctt956 is offline
Mostly Legal Volunteer
Rookie Year: 2016
ctt956 has much to be proud ofctt956 has much to be proud ofctt956 has much to be proud ofctt956 has much to be proud ofctt956 has much to be proud ofctt956 has much to be proud ofctt956 has much to be proud ofctt956 has much to be proud ofctt956 has much to be proud of
Competition Predictions 2018
I enjoyed these threads the past two years, but I haven't seen one yet for this year.
I predict that, during the 2018 season:
G16 (The NULL TERRITORY is safe) will be the most commonly violated rule. ROBOTS obtaining CUBES from the POWER CUBE ZONE will make G22 a close second in the early weeks.
While stacked on a SCALE PLATE, some of the upper POWER CUBES in the stack will slide/fall off and land outside of the FIELD.
A tall ROBOT will tip over and land on a SCALE ARM, moving the PLATE with it, and possibly causing POWER CUBES to fall off of the opposite PLATE.
The Houston Einstein webcast will crash before the finals due to the large viewer spike.
The strategy of an ALLIANCE taking OWNERSHIP of the opposing SWITCH will be a surprisingly effective defense strategy, and will see use in high levels of play.
The Einstein matches, and possibly the division Playoffs, will be more of a SWITCH battle than a SCALE battle once the VAULTS are full, due to execution of the defensive strategy above.
At least one of the Championship winning ALLIANCES will have only 2 climbing ROBOTS or one that climbs and lifts another; LEVITATE will be used for the third climb, allowing a switch/vault bot to play some last-minute defense.
A last-second OWNERSHIP point will change the outcome of an Einstein MATCH.
At least one POWER CUBE will end up on top of the center of the SCALE, blocking one or both RUNG(S).
It will not be uncommon for Playoffs ALLIANCES to have one climbing ROBOT that lifts two, and two switchbots or one switchbot and one scalebot.
A ROBOT will somehow manage to get stuck on top of a POWER CUBE.
FIELD reset will be easy, leading to fast turnaround times unless something needs to be repaired.
What are your predictions? Post them below!
"You know, it's amazing how many things you can take apart with just one ordinary screwdriver!" - Calvin, from Calvin and Hobbes
"There's nothing a little duct tape and surgical tubing can't accomplish." - Sheldon J. Plankton
Unread 03-01-2018, 08:48 AM
Whatever Whatever is offline
FRC #2502
Whatever has a reputation beyond reputeWhatever has a reputation beyond reputeWhatever has a reputation beyond reputeWhatever has a reputation beyond reputeWhatever has a reputation beyond reputeWhatever has a reputation beyond reputeWhatever has a reputation beyond reputeWhatever has a reputation beyond reputeWhatever has a reputation beyond reputeWhatever has a reputation beyond reputeWhatever has a reputation beyond repute
Re: Competition Predictions 2018
The highest non-penalty score will occur in a qualification match this year.
Unread 03-01-2018, 08:55 AM
Brian Maher Fan Club's Avatar
Brian Maher Fan Club Brian Maher Fan Club is offline
School is a pre-robotics activity
AKA: Karan Yadav
FRC #2791 (Shaker Robotics)
Team Role: Driver
Rookie Year: 2016
Brian Maher Fan Club has a brilliant futureBrian Maher Fan Club has a brilliant futureBrian Maher Fan Club has a brilliant futureBrian Maher Fan Club has a brilliant futureBrian Maher Fan Club has a brilliant futureBrian Maher Fan Club has a brilliant futureBrian Maher Fan Club has a brilliant futureBrian Maher Fan Club has a brilliant futureBrian Maher Fan Club has a brilliant futureBrian Maher Fan Club has a brilliant futureBrian Maher Fan Club has a brilliant future
This will happen at a week one event
Team 2791:
2018: Central New York Winners, TVR Finalists, Detroit World Championship Darwin Quarterfinalists, IRI Invite
2017: TVR Winners, NYC Semifinalists, St. Louis World Championship Curie Quarterfinalists, IRI Invite, Ra Cha Cha Ruckus Quarterfinalists, Robot Rumble Winners
2016: TVR Semifinalists, FLR Semifinalists, Robot Rumble Winners, BattleCry Winners
Unread 03-01-2018, 09:58 AM
MikLast's Avatar
MikLast MikLast is offline
Eats Tableau for Breakfast
AKA: Mikal Dieatrick
no team (Volunteer)
MikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond repute
This also will not happen at a FiM event.
Join the FRC Discord!
FRC4513 (Circuit Breakers)
*Student: 2014-2017
*Drive Coach: 2016-2017
Volunteer
A/V: West Valley, PNW DCMP 2018
Unread 03-01-2018, 10:13 AM
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
The most common rule violation will be <G25> (Plates are moved by Power Cubes, not Robots)
We will see the return of the Triple Tortuga this year.
In Week 1, Human Players will try to place Power Cubes onto the field through the bottom of the Exchange.
There will be at least one winning alliance with no climb-capable robots.
Robots will get stuck with regularity on the Platform and the cable protectors
Hi!
Unread 03-01-2018, 10:43 AM
#JusticeforPinecone
Average scores over the season will rise by about 45 points from Week 1 to Week 7.
Two Einstein Alliances will have only 1/3 robots on the field being scale capable.
One of the teams advancing to Einstein finals will get there via the autonomous points tiebreaker, and another will get there via the climbing points tiebreaker.
No matches will be won during Einstein finals by an alliance that controlled the scale for less time, but multiple alliances will win matches during the Einstein round robins where they controlled the scale for less time.
90% of qualification matches during the season will be won by the alliance that controlled the scale for longer.
One alliance in divisional play will control the scale for 0 seconds of teleoperated and win the match.
The Michigan State Championship will be won by a 5th-8th seeded alliance, with no team numbers below 1000 on the winning alliance.
2056 and 195 will not win their respective DCMP's.
No regional in NY will be won by the #1 seed.
College Mentor of Team 5254, HYPE - Helping Youth Pursue Excellence (2015-Present)
frc5254.win
Unread 03-01-2018, 04:55 PM
????????????'s Avatar
???????????? ???????????? is offline
AKA: Aaron Matthews
FRC #1080 (Resurgence Robotics)
Team Role: CAD
Rookie Year: 2017
???????????? will become famous soon enough???????????? will become famous soon enough
CHS in a nutshell...
DISCLAIMER:
The opinions shared here do not reflect the opinions of my team, CD, or FIRST. They merely represent my own thought processes.
Unread 03-01-2018, 04:59 PM
Eugene Fang's Avatar
Eugene Fang Eugene Fang is offline
The Blue Alliance
FRC #0604 (Quixilver)
Eugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond repute
< 20% of Einstein matches will be decided on points earned by the Vault or Power Ups.
#powerupsareatrap
Eugene Fang
2010 Silicon Valley Regional Dean's List Finalist
Various FLL Teams - Student (2000-2006), Mentor (2007-2010)
FRC Team 604 - Student (2007-2010), Mentor/Remote Advisor (2011-Present)
FRC Team 1323 - Mentor/Remote Advisor (2011-2014)
The Blue Alliance | TBA GameDay | TBA Android App | TBA Blog | TBA Swag
Unread 03-01-2018, 07:50 PM
Lemonistic Lemonistic is offline
FRC #0548 (Robostangs)
Rookie Year: 2016
Lemonistic is an unknown quantity at this point
I'm going to second that, if only because it will be easier to call than G16 (null zone is safe).
Other predictions:
If an upset like MSC 2016 occurs, it will be the result of strategic defense and use of Power Ups.
Teams will underestimate the value of the vault and Power Ups (Week 1-3).
Teams will forfeit a climb (Week 1) for a last second ownership change out of habit from 2017, where that one last gear & rotor was worth more than a climb.
Unread 03-01-2018, 09:02 PM
Sir_Fenwick's Avatar
Sir_Fenwick Sir_Fenwick is offline
Change Your Battery
AKA: Jacob Colson
FRC #2883 (Fighting Rednecks Engineering & Design)
Sir_Fenwick is a jewel in the roughSir_Fenwick is a jewel in the roughSir_Fenwick is a jewel in the rough
Robots will get stuck with regularity on... the cable protectors
Yep. I predict a double Tortuga! Triple Tortuga on the cord might be too much to ask for...
Unread 03-01-2018, 10:49 PM
HolyDollar's Avatar
HolyDollar HolyDollar is offline
The Man of Many Buttons
AKA: Lestyn Brooks
FRC #5053 (Lakers)
HolyDollar is a splendid one to beholdHolyDollar is a splendid one to beholdHolyDollar is a splendid one to beholdHolyDollar is a splendid one to beholdHolyDollar is a splendid one to beholdHolyDollar is a splendid one to beholdHolyDollar is a splendid one to behold
The winners of the Detroit Championship will be on the BLUE ALLIANCE.
Thanks to all of our alliance partners from 2017!
FiM Ann Arbor: 6101 (#4 Captain), 5066 (Champions)
FiM Woodhaven (#1 Captain): 1481, 5577 (Champions)
FiM DTE Division (#4 Captain): 6086, 4392
Carson Division: 3494 (#8 Captain), 503, 1018
Unread 03-02-2018, 08:49 AM
wajirock's Avatar
wajirock wajirock is offline
Safety General
AKA: Mohammed W.
wajirock has a reputation beyond reputewajirock has a reputation beyond reputewajirock has a reputation beyond reputewajirock has a reputation beyond reputewajirock has a reputation beyond reputewajirock has a reputation beyond reputewajirock has a reputation beyond reputewajirock has a reputation beyond reputewajirock has a reputation beyond reputewajirock has a reputation beyond reputewajirock has a reputation beyond repute
A Minnesota team will be on the winning alliance of the Detroit Championship.
Unread 03-02-2018, 10:50 AM
TheBoulderite TheBoulderite is offline
Will join FRC team for food.
AKA: Warren Bartlett
Rookie Year: 2015
TheBoulderite has a reputation beyond reputeTheBoulderite has a reputation beyond reputeTheBoulderite has a reputation beyond reputeTheBoulderite has a reputation beyond reputeTheBoulderite has a reputation beyond reputeTheBoulderite has a reputation beyond reputeTheBoulderite has a reputation beyond reputeTheBoulderite has a reputation beyond reputeTheBoulderite has a reputation beyond reputeTheBoulderite has a reputation beyond reputeTheBoulderite has a reputation beyond repute
Looks like 1678, 968, and 3230 are the first alliance to pull off a 4 RP match this year! Congratulations to them.
2015-2017: 1619 (Up-A-Creek Robotics)
1619's Alliance Partners, 2005-2018:
(1583, 1667, 937, 1332, 1158[x2], 1348[x2], 2543, 2261, 1777, 2240, 3648[x2], 2036, 3200, 1410, 3807, 4550[x2], 399, 2594, 4598, 1987, 4153, 624, 4334, 1730, 4593, 3618, 967, 3026, 4499, 3009, 1011[x2], 525, 4028, 3352, 662, 1339, 3309, 1319, 4944, 846, 4610, 148, 5414, 2122, 3145, 1678, 4061, 1723)
Unread 03-02-2018, 11:27 AM
ahartnet's Avatar
ahartnet ahartnet is offline
AKA: Andrew Hartnett
FRC #5414 (Pearadox)
ahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond repute
My prediction is the highest average scores will be in weeks 3 or 4 not in 5 or 6.
Weeks 1 and 2 will have two few robots that can score in the scale. Weeks 5 and 6 will have a more contested scale. Weeks 3 and 4 will be the sweet spot where there's a good number of teams that can effectively score in the scale and they'll be in some matches where they're uncontested.
Team 5414 Pearadox, Mentor (2015-Present) | Website | Facebook
Team 2936 Gatorzillas, Mentor (2011-2014)
Team 1646 Precision Guessworks, Mentor (2006-2008)
Team 451 The Cat Attack, Student Alumni (2005)
Unread 03-03-2018, 02:08 AM
Sean Raia's Avatar
Sean Raia Sean Raia is offline
Software engineer
no team (Anonymous)
Sean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond repute
#powerupsareatrap
Completely agree
Power ups are probably the underdogs best chance but they’re not something top tier alliances will be using regularly in the semis and finals at championships
On the flip side they will be a staple in qualification matches
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
