Go to Post I highly doubt the game has anything to do with water... - rotolomi [more]
  #76   Spotlight this post!
Unread 01-06-2018, 12:45 PM
Azelf482 Azelf482 is offline
FRC #5994
Azelf482 is an unknown quantity at this point
Re: Power-Up Discussion
What if an Alliance activates Force with 2 or 3 cubes when the scale is deactivated, would they still gain ownership points from the scale?
Section 4.3: Power Ups, Table 4-2
"ALLIANCE earns OWNERSHIP points from the SCALE regardless of PLATE position"
  #77   Spotlight this post!
Unread 01-06-2018, 12:46 PM
ATannahill ATannahill is offline
Developing tomorrow's best people
AKA: Alex Tannahill
ATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond repute
Originally Posted by NathanStro View Post
Is the platform considered part of the scale? When climbing you must be "fully supported by the scale" (Table 4-1) But in figure 3-4 the platform is shown as a part of the scale. Does this mean you can be fully supported by the platform?(hint climbing w/o grabbing on to anything)
Thanks.
Section 3.3 lists platforms as part of the scale.
I am a volunteer that reads the manual during kickoff day (and updates and Q&A when available) and I try my best to help people with questions that are posted.
I base my answers off of the game manual, Q&A responses and field tour videos at the time of my post. Rules will probably be modified or clarified between this post and your competition. My post means nothing to event officials. Please keep up with team manual updates and the FRC Q&A.
  #78   Spotlight this post!
Unread 01-06-2018, 12:47 PM
AKA: Alex Tannahill
Can you clarify what you mean by the scale being deactivated? I do not understand or recall that in the manual and I could not find it by looking for the word "deactivated".
  #79   Spotlight this post!
Unread 01-06-2018, 01:00 PM
FRC #5994
By deactivated, I meant when the scale is balanced and no alliance has ownership of the scale.
  #80   Spotlight this post!
Unread 01-06-2018, 01:11 PM
AKA: Alex Tannahill
Yes, as I interpret Section 4.2 on page 37, you would have ownership of a balanced switch if you use the FORCE POWER UP with 2 or 3 blocks.
Originally Posted by FIRST POWER UP Manual Page 37 as of Kickoff
An ALLIANCE has OWNERSHIP of the SCALE when:
A. the SCALE is tilted in favor of their ALLIANCE colored PLATE, such that the outside edge of the ALLIANCE’S colored PLATE is at or lower than 4 ft. 8 in. (~142 cm) from the floor, or
B. they have played the FORCE POWER UP at level 2 or 3 (see Section 4.3 POWER UPS)
  #81   Spotlight this post!
Unread 01-06-2018, 02:06 PM
AmoryG AmoryG is offline
FRC #2423 (KwarQs)
AmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud of
So if the scale is tilted in favor of the red alliance and the blue alliance is playing their force power up, do both alliances have ownership of the scale and gain points, or does the blue alliance deny red points for 10 seconds?
KwarQs 2423
2008 Boston Regional Rookie Allstars
http://whsrobot.blogspot.com/
  #82   Spotlight this post!
Unread 01-06-2018, 02:09 PM
FRC #2423 (KwarQs)
Originally Posted by JR0405 View Post
This is definitely a recycling of Recycle Rush
FIFY
KwarQs 2423
  #83   Spotlight this post!
Unread 01-06-2018, 02:14 PM
AKA: Alex Tannahill
I interpret it as red being denied the points because only one alliance can own the scale at a time.
Originally Posted by FORST POWER UP Manual Section 3.3.1 page 19 as of Kickoff
During the MATCH, the SCALE is in one of three (3) states based on the magnitude of its tilt:
1. OWNERSHIP by the Red ALLIANCE, or
2. OWNERSHIP by the Blue ALLIANCE, or
3. neither ALLIANCE has OWNERSHIP
  #84   Spotlight this post!
Unread 01-06-2018, 02:34 PM
ksharma ksharma is offline
ksharma is an unknown quantity at this point
Regarding the FORCE Power-up, does anybody know if it affects both your SWITCH AND the opposing alliance's SWITCH?
Thanks!
  #85   Spotlight this post!
Unread 01-06-2018, 02:39 PM
AKA: Alex Tannahill
Thanks!
No, I am judging that based off the singularity of the word "the".
Originally Posted by FIRST POWER UP Manual Section 4.3 Page 39 as of Kickoff
ALLIANCE earns OWNERSHIP points from the SWITCH and the SCALE regardless of PLATE position
  #86   Spotlight this post!
Unread 01-06-2018, 02:45 PM
GeneralMit GeneralMit is offline
AKA: Reese
FRC #1746
GeneralMit is an unknown quantity at this point
Can you grab a power cube that is partially in another team's platform zone? The two power cubes on the edges
  #87   Spotlight this post!
Unread 01-06-2018, 02:53 PM
AKA: Alex Tannahill
I do not see a rule against it. I only see G18 but that is exclusively in the ENDGAME.
  #88   Spotlight this post!
Unread 01-06-2018, 03:26 PM
FRC #2423 (KwarQs)
I thought so too, but I feel like these parts of the manual made the rule confusing:
If getting the force power up denied the other alliance points I felt like the language of the second part to be more like:
A. the SCALE is tilted in favor of their ALLIANCE colored PLATE, such that the outside edge of the ALLIANCE’S colored PLATE is at or lower than 4 ft. 8 in. (~142 cm) from the floor AND the other alliance has not played the FORCE POWER UP at level 2 or 3, or
And this rule from the section on power ups:
Originally Posted by FIRST POWER UP Manual Page 39 as of Kickoff
FORCE
ALLIANCE earns OWNERSHIP points from their
SWITCH regardless of PLATE position
Does earning ownership points mean they have ownership?
KwarQs 2423
  #89   Spotlight this post!
Unread 01-06-2018, 03:39 PM
Drewit Drewit is offline
AKA: Andrew Weissman
Drewit is a splendid one to beholdDrewit is a splendid one to beholdDrewit is a splendid one to beholdDrewit is a splendid one to beholdDrewit is a splendid one to beholdDrewit is a splendid one to behold
Originally Posted by ctt956 View Post
Some of my reactions:
1. Dozer's back!
2. Chute door...sort of. More like a chute ram, I guess.
3. There's no retroreflective tape for vision tracking, though vision tracking doesn't seem all that practical this year except for maybe a 2-cube auto.
4. The ownership is interesting, and a nice change.
5. This game is well-designed. Challenging, but not too difficult for lower-resource teams.
3. This appears to be incorrect. Section 3.9 outlines the location of the vision targets on each SWITCH.
4&5. Agreed. This is a unique and potentially exciting game! I'm looking forward to seeing the teams play this game.
Something that stood out to me (and that I'm expecting many penalties from in the early weeks of competition) is G16, i.e. "The NULL TERRITORY is safe." The wording on this seems to make the null territory the loading zone/secret passage this year in terms of penalties. With the randomness of the lights, teams may find themselves quickly accruing Tech Fouls if they aren't aware of whose side they're on.
FIRST "Consultant" for local FRC/FTC/FLL teams [2017 - ]
FIRST Mid-Atlantic Volunteer [2016 - ]
FRC 1640 Mentor [2013 - 2017] (Lead CAD Mentor 2015-2017)
FRC 1640 Student [2010 - 2012] (Human Player 2010 & 2011, Driver & Co-captain 2012)
  #90   Spotlight this post!
Unread 01-06-2018, 04:11 PM
mathking's Avatar
mathking mathking is offline
Coach/Faculty Advisor
AKA: Greg King
FRC #1014 (Dublin Robotics aka "Bad Robots")
mathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond repute
Originally Posted by Drakxii View Post
Would be annoying to get on the platform and there is no protection at the portal stations.
I don't think mecanum robots would have any significant difficulty getting on the platform. In 2012 there were a lot of mecanum robots (our included) that were able to negotiate the ramps with not too much difficulty, so this platform should be no big deal. Getting pushed out of portal stations could be an issue, but as with most drive train decisions, I think it will come down much more to how well a team executes their design and drives their robot that the actual choice of drive trains.
Thank you Bad Robots for giving me the chance to coach this team.
Rookie All-Star Award: 2003 Buckeye
Engineering Inspiration Award: 2004 Pittsburgh, 2014 Crossroads
Chairman's Award: 2005 Pittsburgh, 2009 Buckeye, 2012 Queen City
Team Spirit Award: 2007 Buckeye, 2015 Queen City
Woodie Flowers Award: 2009 Buckeye
Dean's List Finalists: Phil Aufdencamp (2010), Lindsey Fox (2011), Kyle Torrico (2011), Alix Bernier (2013), Deepthi Thumuluri (2015)
Gracious Professionalism Award: 2013 Buckeye
Innovation in Controls Award: 2015 Pittsburgh
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
