OCCRA
Go to Post I think this thread just won "ChiefDelphi is terrible Bingo". - Karthik [more]
Unread 10-12-2017, 09:23 PM
Pomcho613 Pomcho613 is offline
Pomcho613 is an unknown quantity at this point
Vex versa drop issues
OK so my team takes part in a local competition called crc and we have a strange rule which does not allow us to use pneumatics. To simplify the creation of our robot I looked into the vex versa drop system and it looked great. (I'm thinking of using butterfly or octocanum) but there is 1 problem. It relies on pneumatics. So, I was wondering if there was any way of getting rid of the pneumatics system and replacing it with something like a rack and pinion system. Could this work?
Unread 10-12-2017, 09:57 PM
messer5740's Avatar
messer5740 messer5740 is offline
AKA: Matt
FRC #5740 (Trojanators)
Rookie Year: 2015
messer5740 has a spectacular aura aboutmesser5740 has a spectacular aura about
Re: Vex versa drop issues
You could use linear actuators! I havent used them since 2015 (DART actuators I think), but they basically resemble the linear movement of a pneumatic cylinder, but it uses a motor instead.
A good driver is always better than a good robot.
2015: Winner of the Rookie Inspiration Award
2016: Quarterfinalists at Greater Pittsburgh Regional and Buckeye Regional
2017: Dean's List Finalist
Unread 10-12-2017, 10:04 PM
Type's Avatar
Type Type is offline
AKA: AJ
FRC #3452 (GreengineerZ)
Rookie Year: 2016
Type is a splendid one to beholdType is a splendid one to beholdType is a splendid one to beholdType is a splendid one to beholdType is a splendid one to beholdType is a splendid one to beholdType is a splendid one to behold
We used the DART linear actuators in 2016 and we had so many issues with them. It got to the point where as soon as it got into the pit, we would take them off and replace them with another just because we knew without testing something was failing. In 2017 we created our own linear actuators, working so much better. You can look on McMaster for lead screws, we used 3/8" ACME, but you may want to go larger if it will be supporting the weight of a robot (depending on size).
3452- Lead Builder/ Pit Boss
*My posts do not reflect the opinion of my team*
Unread 10-12-2017, 10:35 PM
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
I think the simplest solution would be a motor and a cam.
Unread 10-12-2017, 11:08 PM
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
If you use any sort of electrical solution to actuating wheels, you will almost certainly want to have some sort of "lock" that does not require a constant current flow in order to maintain the force against the wheels normally off the floor.
There are lots of ways to do this; one of the more elegant is to use the "air brake" method in which a brake is engaged UNLESS force is applied to release it. Use this not on your wheels, but on your vertical travel. You may want to supplement this with some sort of pawl/ratchet or other high-grip system.
Unread 10-13-2017, 08:42 AM
Thank you all for your wonderful responses, where exactly could I find linear actuators or parts to build some?
Unread 10-13-2017, 08:52 AM
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Certainly many others out there, but those are the first two I thought of.
Unread 10-13-2017, 09:09 AM
InFlight's Avatar
InFlight InFlight is offline
3574 - The King's of Bling
AKA: Jim
FRC #3574 (High Tekerz)
InFlight has much to be proud ofInFlight has much to be proud ofInFlight has much to be proud ofInFlight has much to be proud ofInFlight has much to be proud ofInFlight has much to be proud ofInFlight has much to be proud ofInFlight has much to be proud ofInFlight has much to be proud ofInFlight has much to be proud of
The advantage of pneumatics is that you have a small distributed force at each module. You now to recreate adequate force at each module in the simplest and most reliable method possible.
If your not using FIRST rules, there are solenoids with more than adequate power. (The R32 - 10 Watt limit on solenoids makes them effectively not very useful)
The other option mentioned is a CAM. One of the AndyMark PG188 series & 775 with the built in encoder would be absolutely overkill with 33 foot*pounds of stall torque.
An other option is to have one central motor gearbox to actuate the modules, and use something like bicycle brake cable to position each module. The typical tension adjusters would allow you to individually adjust the position of each module.
Unread 10-13-2017, 09:42 AM
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
And maybe in a way you didn't intend to say! The gearing would make you think it was capable of about 44 ft-lb of torque, but the output shaft shears at about 33. Unless you're going to monitor torque (or current as a fair proxy) you would be better off using the PG71 and (if you really did want that much torque) a post-gearbox ~2:1 reduction.
Unread 10-13-2017, 07:13 PM
messer5740's Avatar
AKA: Matt
Rookie Year: 2015
We used the ones from 2015, never had any issues, given it was lightish load. The one thing about them is it cant be forced back, which is good in an application like this.
Unread 10-15-2017, 08:20 PM
fargus111111111's Avatar
fargus111111111 fargus111111111 is offline
ME who pretends to code
AKA: Tim W
FRC #0343 (Metal in Motion)
fargus111111111 is a splendid one to beholdfargus111111111 is a splendid one to beholdfargus111111111 is a splendid one to beholdfargus111111111 is a splendid one to beholdfargus111111111 is a splendid one to beholdfargus111111111 is a splendid one to behold
If you do a motor with a cam you could have it set to stop in the down position where the cam is not quite to the max forced travel and put a ratchet system on the cam, this way the weight of the robot would hold it against the ratchet and the ratchet would allow the motor to not put force into holding the robot in the up position
I didn't break it... this time.
play is the highest form of research-Einstein
Unread 10-15-2017, 08:37 PM
AdamHeard's Avatar
Lead Mentor
Why not pneumatics?
973 shirts for sale!
2x1 and 2x2 1/16" wall tubing for sale!
Need help? Check out 973 Remote Assistance and Mentorship Program.
Like our Robots? Check out the CAD files of MOST of our robots!
2017 "World Champions"
2014 Galileo Champions
2011 World Champions
Unread 10-15-2017, 08:43 PM
Why not pneumatics?
Already answered.
I think the simplest solution might be to use a window motor, one on each end of the bot (or maybe one total?). Have that rotate a common shaft that handles both pods on that end. BUT, you'll need to do the math on that: will any given motor have the required speed and torque, and will the shaft (and its mounts) stay intact under the loads?
2003-2007: FRC0330 BeachBots; 2008: FRC1135 Shmoebotics; 2012: FRC4046 Schroedinger's Dragons
Unread 10-15-2017, 09:04 PM
SPang SPang is offline
Stephen Pang
FRC #1124 (The ÜberBots)
SPang has much to be proud ofSPang has much to be proud ofSPang has much to be proud ofSPang has much to be proud ofSPang has much to be proud ofSPang has much to be proud ofSPang has much to be proud ofSPang has much to be proud ofSPang has much to be proud of
Definitely look into the cam option that other people have mentioned or the rod option that allows you to conserve the amount of motors you dedicate to this task. If you need help with the math involved the people here would be glad to help. Using linear actuators for this would significantly increase the price tag on your project, which I'd imagine isn't desirable.
ÜberBots (FRC 1124) | 2014 - 2017 | Student
NE FIRST Volunteer | 2016 - ????
Unread 10-16-2017, 12:19 AM
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Maybe a window motor driving an over-center linkage, so that shock loads are not transferred back to the gears? Lock the linkage against a hard stop after it passes over center.
Richard Wallace
since 2003
