Go to Post Don't worry about where you will be. Just consider youself lucky for being where you have been. - sanddrag [more]
Unread 03-20-2017, 05:01 PM
dardeshna's Avatar
dardeshna dardeshna is offline
Team Captain
AKA: Devin Ardeshna
FRC #0008 (Paly Robotics | Team 8)
Team Role: Mechanical
Rookie Year: 2015
dardeshna is a splendid one to beholddardeshna is a splendid one to beholddardeshna is a splendid one to beholddardeshna is a splendid one to beholddardeshna is a splendid one to beholddardeshna is a splendid one to behold
Removing gunk from colson wheels
This year Team 8 decided to use 4" colson wheels for our drivetrain (8 wheel WCD). After a few matches down at Ventura we noticed black gunk had begun to build up on the wheels. On closer inspection, we noticed it was fused to the wheel and had to be scraped off with a knife. Looked kind of like melted plastic.
Our bot is pretty quick and we were skidding around the field when shuttling gears, so this may have been part of the problem. We are thinking it might be the field tape melting on the wheels. Anyone else face this issue? Better way to remove it rather than scraping with a knife (which marks up the colson itself)? I'll try to get a picture soon.
(It's also only on the back two wheels, but our robot does tend to rock backwards)
Unread 03-20-2017, 05:07 PM
Dylan179's Avatar
Dylan179 Dylan179 is offline
FRC #0179 (Children of the Swamp)
Dylan179 has much to be proud ofDylan179 has much to be proud ofDylan179 has much to be proud ofDylan179 has much to be proud ofDylan179 has much to be proud ofDylan179 has much to be proud ofDylan179 has much to be proud ofDylan179 has much to be proud ofDylan179 has much to be proud ofDylan179 has much to be proud of
Re: Removing gunk from colson wheels
use like 60 grit sand paper and run the wheel with the sandpaper held on it
Unread 03-20-2017, 08:40 PM
dirtbikerxz's Avatar
dirtbikerxz dirtbikerxz is offline
Captain | Driver | Senior
AKA: Rohit Gondi
FRC #3991 (KnightVision)
Team Role: Driver
Rookie Year: 2012
dirtbikerxz has a reputation beyond reputedirtbikerxz has a reputation beyond reputedirtbikerxz has a reputation beyond reputedirtbikerxz has a reputation beyond reputedirtbikerxz has a reputation beyond reputedirtbikerxz has a reputation beyond reputedirtbikerxz has a reputation beyond reputedirtbikerxz has a reputation beyond reputedirtbikerxz has a reputation beyond reputedirtbikerxz has a reputation beyond reputedirtbikerxz has a reputation beyond repute
Huh. We are running the same config, 4in (2in wide) 8wd colsons. No gunk build up or anything after rock city. And we are definitely one of the faster bots.
Team 3991: Driver (2014-), Captain (2016-)
"The human condition is not perfect. We are not perfect specimens, any of us. We're not robots." - Michael Ovitz
My posts may or may not reflect the views of my team, they are my opinions, and mine alone.
Unread 03-20-2017, 08:45 PM
edesirim's Avatar
edesirim edesirim is offline
Engineering Director, Team 701
AKA: Edesiri Mushale
FRC #0701 (Robovikes)
Rookie Year: 2011
edesirim will become famous soon enough
With a 6WD, West Coast Drive Train with 4 inch Colsons, our robot also drives on the back 4 as most of the weight is there. We are thinking of rotating the wheels and replacing them, which would mean taking the front 2 wheels and replacing the middle wheels with those and but the middle wheels up front. This would happen every so often, so like every 7-10 matches. I think it as also been suggested to use acetone to wipe off the Colsons, but someone please check my words here.
Unread 03-20-2017, 08:49 PM
qscgy's Avatar
qscgy qscgy is offline
Minister of Zip Ties
AKA: Sam Ehrenstein
FRC #0449 (The Blair Robot Project)
Rookie Year: 2014
qscgy has a reputation beyond reputeqscgy has a reputation beyond reputeqscgy has a reputation beyond reputeqscgy has a reputation beyond reputeqscgy has a reputation beyond reputeqscgy has a reputation beyond reputeqscgy has a reputation beyond reputeqscgy has a reputation beyond reputeqscgy has a reputation beyond reputeqscgy has a reputation beyond reputeqscgy has a reputation beyond repute
This is how we cleaned off the green residue that formed on our shooter.
FRC Team 449, 2014-Present
Case Western Reserve University Class of 2021
Unread 03-20-2017, 08:55 PM
Fusion_Clint's Avatar
Fusion_Clint Fusion_Clint is offline
AKA: Clint Brawley
FRC #0364 (Fusion)
Rookie Year: 2013
Fusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond repute
No gunk from Arkansas here either, but we plan on putting brand new wheels on and checking chain tension for Bayou anyway.
This is the main reason we switched to WCD this year, ease of wheel/tire maintenance.
In the expenses of FIRST, $90 for six new wheels for each ($4000) competition is pretty low on the worry list.
Clint Brawley
USAF 1992-2013
Fusion 364, 2014 Season to present
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
