OCCRA
Go to Post When is comes down to it, remember what FIRST is really about, it is about those students and helping to inspire them - E3 Robotics Ctr [more]
Go Back   Chief Delphi > Technical > Sensors
CD-Media
Unread 12-05-2018, 09:34 AM
jimfl014 jimfl014 is offline
FRC #5000 (HammerHeads)
jimfl014 is an unknown quantity at this point
Rev Robotics 2m Sensor
Has anyone had any experience with this distance sensor? Although this sensor is inexpensive, for us it might be technically expensive as the API is C only and we are a Java shop.
Unread 12-05-2018, 10:17 AM
tjf tjf is offline
AKA: Tim Flynn
FRC #1257 (Parallel Universe), #1228 (RoboTribe)
Rookie Year: 2016
tjf has a reputation beyond reputetjf has a reputation beyond reputetjf has a reputation beyond reputetjf has a reputation beyond reputetjf has a reputation beyond reputetjf has a reputation beyond reputetjf has a reputation beyond reputetjf has a reputation beyond reputetjf has a reputation beyond reputetjf has a reputation beyond reputetjf has a reputation beyond repute
Re: Rev Robotics 2m Sensor
If you're indeed referring to the "2m Distance Sensor", it should work essentially regardless of language. WPILib has built-in functionality to read i2c devices off of the RoboRIO's i2c bus, even if a base-library REV made for convenience isn't available (not that I'm aware of any existing). You'd just need to use the address REV lists on the product page, being 0x52.
1257 (2016) - Student
1257 (2017-Present) - Overactive Alumnus | 1228 (2017-Present) - I do stuff
KD2KRT
Papers: Encyclopedia Robotica v2 | An FRC Anthology
Unread 12-05-2018, 02:42 PM
Thanks! We'll order one and try it out on our test robot.
Unread 12-05-2018, 04:42 PM
dyanoshak dyanoshak is offline
AKA: David Yanoshak
FRC #2158 (ausTIN CANs)
dyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond repute
The C API is provided by ST, the sensor chip's manufacturer. In FTC, this API is simplified and ported into the Java SDK by the FTC developers. Using this sensor in FRC would require porting the library to Java, LabVIEW, or C++. We do not have ported FRC libraries at this time, but here are some resources that can get you started:
For the FTC SDK, you would need to unpack the Hardware-release-sources.jar file. You will find the sensor related Java file in the following path:
ftc_app\libs\Hardware-release-sources.jar\com\qualcomm\hardware\stmicroelectroni cs\
An alternative to connecting the sensor directly to the roboRIO and porting the libraries would be to use the sensor with a co-processor, like an Arduino, and use the libraries that already exist.
David Yanoshak
Co-founder REV Robotics | www.revrobotics.com
Powered by vBulletin®
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
