OCCRA
Go to Post Gotta bring your own TP to champs. Rookie mistake - AdamHeard [more]
CD-Media
Unread 12-04-2017, 06:08 PM
mjbergman92's Avatar
mjbergman92 mjbergman92 is offline
AKA: Malachi
FRC #3534 (House of Cards)
Rookie Year: 2016
mjbergman92 is an unknown quantity at this point
Exclamation Adafruit BNO055 Library Problem
I have downloaded the driver for the Adafruit_BNO055 from https://learn.adafruit.com/adafruit-...r/arduino-code. I just have no clue where to put the file on my Mac and I don't know what I need to do as far as adding a library to my robot eclipse project. I have tried to look through the folder but there is no jar files. Please help!
Unread 12-04-2017, 10:23 PM
MuskieProgramme MuskieProgramme is offline
FRC #6420 (Fire Island Robotics)
MuskieProgramme is a glorious beacon of lightMuskieProgramme is a glorious beacon of lightMuskieProgramme is a glorious beacon of lightMuskieProgramme is a glorious beacon of lightMuskieProgramme is a glorious beacon of lightMuskieProgramme is a glorious beacon of light
Re: Adafruit BNO055 Library Problem
The driver is written in C++. C++ is not Java.
To use the driver in Java you'll have to do some things. Actually, a lot of things. It may be easier to literally re-write the library in Java.
Unread 12-05-2017, 11:38 AM
nullmainmethod's Avatar
nullmainmethod nullmainmethod is offline
FRC #6502 (DARC Side)
Rookie Year: 2017
nullmainmethod has a brilliant futurenullmainmethod has a brilliant futurenullmainmethod has a brilliant futurenullmainmethod has a brilliant futurenullmainmethod has a brilliant futurenullmainmethod has a brilliant futurenullmainmethod has a brilliant futurenullmainmethod has a brilliant futurenullmainmethod has a brilliant futurenullmainmethod has a brilliant futurenullmainmethod has a brilliant future
Little off topic, but be careful if using the BNO055 on a robot. I heard it has bad drift issues when moving- the onboard AHRS is nice, but only if it works.
"Remember to hacksaw off the rest of the quick grips to give yourself more room" - /u/Tapego
Unread 12-07-2017, 11:19 AM
Maxcr1's Avatar
Maxcr1 Maxcr1 is offline
AKA: Max D "Code Boy"
FRC #2169 (KING TeC)
Rookie Year: 2016
Maxcr1 has a brilliant futureMaxcr1 has a brilliant futureMaxcr1 has a brilliant futureMaxcr1 has a brilliant futureMaxcr1 has a brilliant futureMaxcr1 has a brilliant futureMaxcr1 has a brilliant futureMaxcr1 has a brilliant futureMaxcr1 has a brilliant futureMaxcr1 has a brilliant futureMaxcr1 has a brilliant future
I can second this, but I will extend the issue to the AHRS as well. We had large drift issues with the AHRS and have had great success with the NavX and it's incredible 9-way sensor fusion, as well as CTRE's brand new Pigeon IMU which works just as well, if not marginally better.
Powered by vBulletin®
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
