OCCRA
Go to Post FIRST is doing a great job, it's me who needs to do the hard work now. - Bomberofdoom [more]
  #31   Spotlight this post!
Unread 08-27-2018, 12:51 PM
Andrew Schreiber Andrew Schreiber is offline
Petitioning the UN to ban Lythgoe
Rookie Year: 2000
Andrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond repute
Re: pic: Pseudo-Differential Swerve
Originally Posted by AriMB View Post
It's not just after a collision though. Anything that would cause one wheel to slip and not the other would cause the same problem, even if the wheel isn't completely raised off the ground. This could happen in autonomous by driving over a small bump* or a slippery/sticky piece of field tape**, for example. If the wheel that's slipping is the one you're measuring, you may know that the wheel slipped (because the module turned unexpectedly), but you don't know how much distance you lost from slipping.
* flat fields often have unexpected 1/4" bumps (see 2017)
** FTAs do their best to keep all the tape lines intact and smooth, but you know as well as I that they get messed up by the end of a long competition
Understood. As I've said I'd likely do a 3 sensor approach at the minimum. But I think the Internally Indexed Differential Swerve would be less susceptible to the error being described.
  #32   Spotlight this post!
Unread 08-27-2018, 01:02 PM
AriMB's Avatar
AriMB AriMB is offline
The Philadelphian emigrant
AKA: Ari Meles-Braverman
FRC #5987 (Galaxia)
Rookie Year: 2012
AriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond repute
Agree all around
Studying MechE at the Technion - Israel Institute of Technology
2017-present: FIRST Israel CSA/FTAA
2017-present: FRC 5987 Technical Mentor 18isr2 18isr4 18isrcmp 18carv
2012-2016: FRC 423 Member 15njtab 15padre 16paphi
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
