OCCRA
Go to Post Id have to say, that is probably one of the most creative floats i have ever seen. then again, this is coming from a guy who hasn't seen many floats (disregarding the 32-bit ones). - Uberbots [more]
CD-Media
Unread 08-29-2018, 04:14 AM
Danielm55t Danielm55t is offline
FRC #7427 (ProtocolX Robotics)
Team Role: Mechanical
Rookie Year: 2014
Danielm55t will become famous soon enough
pic: 3d printable swerve
Unread 08-29-2018, 04:34 AM
AriMB's Avatar
AriMB AriMB is offline
The Philadelphian emigrant
AKA: Ari Meles-Braverman
FRC #5987 (Galaxia)
Rookie Year: 2012
AriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond repute
Re: pic: 3d printable swerve
I understand the 1:1 absolute encoder for steering, but the Mini CIM also appears to have a 1:1 absolute encoder. I'm pretty sure you're going to want to change that.
First of all, absolute encoders tell you what angle they're at, not how fast they're turning. You don't ever care about what angle your Mini CIM shaft is pointing at, you only care about how fast it's spinning. For that reason, you really want to use an incremental encoder.
Second, that Mini CIM shaft will be spinning very fast (max 5840 rpm). If you choose an encoder with a low CPR, it can be okay to measure the speed 1:1 with the motor. However, it may make more sense to use a higher-CPR encoder and place it after some reduction so that you don't have to worry about your ABS gears meshing at 6 ft/sec.
All-in-all, I'm not sure how well the ABS gears will hold up in testing, but that's what testing is for after all. I'm assuming you're using this with a very underweight chassis, so it might be able to hold it. I certainly wouldn't trust ABS gears with a competition robot, but I expect you know that already. I'm most concerned about the spur gear reduction, which appears to be between a metal pinion and a plastic gear. If this is the case, I would expect that plastic gear to degrade pretty quickly due to the difference in the hardnesses between the materials, but I guess you will find out how big of a problem that is during testing.
Good luck!
Studying MechE at the Technion - Israel Institute of Technology
2017-present: FIRST Israel CSA/FTAA
2017-present: FRC 5987 Technical Mentor 18isr2 18isr4 18isrcmp 18carv
2012-2016: FRC 423 Member 15njtab 15padre 16paphi
Unread 08-29-2018, 11:27 AM
Rookie Year: 2014
Do you have an example of an incremental encoder that would work? I don’t have a lot of experience with using encoders and the various types and what to look for when choosing one.
For gearing the encoder slower I should be able to just swap out the dark grey gears for something that gives me a 3:1 or 2:1.
Based of the testing I have done with an older version the gears hold up fine for testing but I wouldn’t trust them for competition use. All of the gears are plastic so there shouldn’t be any metal on plastic rubbing.
Unread 08-29-2018, 12:16 PM
AriMB's Avatar
FRC #5987 (Galaxia)
Rookie Year: 2012
Really any incremental encoder will work. The best I can recommend in general are the SRX magnetic encoders from CTRE. They can be either incremental or absolute encoders depending on how you configure them, and I've only heard good reviews. We use them pretty much whenever we need an encoder. These were also in FIRST Choice the past few years, and AndyMark sells these and these.
That said, based on your design it seems like you would want an encoder with a built-in shaft instead of one that has a thru-hole for a shaft or reads a magnet that attaches to a separate shaft. You're best bet will probably be looking at a website like DigiKey or Mouser for a incremental encoder that suits your needs.
Unread 08-29-2018, 05:16 PM
Brian Michell's Avatar
Brian Michell Brian Michell is offline
FRC #1817 (Llano Estacado RoboRaiders)
Rookie Year: 2015
Brian Michell is just really niceBrian Michell is just really niceBrian Michell is just really niceBrian Michell is just really niceBrian Michell is just really nice
I don't know how much adaptation, if any, would be needed to make these work, but this season my team used these encoders (or some similar incarnation) from USDigital without much *headache. As configured it would run you about $130 USD for 4 of them (the cables aren't included)
*The encoders we had on the robot were old, sitting in a drawer, and had had a long life. One was dead at our first competition, the other had a disc that slipped off the output shaft and was mangled inside the robot in the offseason. Your mileage may vary.
*Any views I express are my own and do not reflect those of any organization I am currently or formerly associated with unless stated.
5416
2015-2016: Programming, Drive Coach
6488
2017: Programming, Drive Mentor
1817
2018-?: Programming Mentor
Unread 09-06-2018, 07:35 AM
baconbot's Avatar
baconbot baconbot is offline
Do the CAD, save the world.
AKA: James
FRC #3506 (YETI Robotics)
Team Role: CAD
Rookie Year: 2017
baconbot is on a distinguished road
the only thing I can see resulting from this is a broken swerve drive in the middle of a match
reason why is that there is no way those gears will hold up under the high loads that a dirvetrain is put under
Unread 09-06-2018, 10:15 AM
GeeTwo GeeTwo is offline
Somebody Else
AKA: Gus Michel II
Rookie Year: 2013
Not if used as designed (emphasis mine):
designed to be printed out of ABS or PETG on a cheap printer as a prototype
[Quoting brennonbrimhall]: We design a new robot every year, but we can't forget that we also design a new team every year as folks come and go.
Powered by vBulletin®
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
