OCCRA
Go to Post Question: How can you tell the difference between an engineer and a programmer? Answer: You ask them to count. Engineers start counting from 1. Programmers start counting from 0. - Ed Law [more]
CD-Media
Unread 11-14-2018, 06:17 PM
CRobinson's Avatar
CRobinson CRobinson is offline
FRC #1723 (The FBI - The FIRST Bots of Independence)
Team Role: Human Player
Rookie Year: 2017
CRobinson will become famous soon enough
Beginning Pneumatics
Currently, on my team, no one knows how to do pneumatics, the people that did, graduated years ago, and we've gotten by without pneumatics. However, to prepare for this upcoming season we'd really like to know them in case they're needed.
Is there anywhere to start when beginning pneumatics? Is a pneumatics board a thing that can be created? (like a wiring board) We have no clue where to start or begin. What does your team do to teach pneumatics?
Unread 11-14-2018, 06:23 PM
Re: Beginning Pneumatics
Here are a couple of guides:
We are what we repeatedly do. Excellence, then, is not an act, but a habit. -Aristotle
Unread 11-14-2018, 08:09 PM
Zem's Avatar
Zem Zem is offline
AKA: Braeden (I speak for myself, not for my team)
FRC #3461 (Operation P.E.A.C.C.E.)
Zem will become famous soon enough
This will probably help:
https://www.thecompassalliance.org/pneumatics
2016: Match Observer
Operator : )
My views and opinions do not necessarily reflect that of my team.
Programming is not hard, its a different way of thinking.
Unread 11-15-2018, 09:53 AM
ngreen ngreen is online now
AKA: Nelson Green
FRC #1108 (Panther Robotics)
ngreen has a reputation beyond reputengreen has a reputation beyond reputengreen has a reputation beyond reputengreen has a reputation beyond reputengreen has a reputation beyond reputengreen has a reputation beyond reputengreen has a reputation beyond reputengreen has a reputation beyond reputengreen has a reputation beyond reputengreen has a reputation beyond reputengreen has a reputation beyond repute
Our team does a board but it needs to rebuilt for this year. I'd like to setup a couple hours sometime in December for training our students doing this but more would be welcome to join. I'd talked about but wasn't able to put together the workshop in time for Massive Mini. Usually we do classes on Sunday afternoon but my preferred date on the 16th is probably too close to finals. Its easiest to coordinate through emails, ours is pantherrobotics1108@gmail.com.
Most of the above resources will get you off on the right foot. I'd look to stock up on pneumatics parts through first choice. We tend to go with cheaper valve option, like the automation direct valves. Sizing and purchasing the right actuators is probably one of the bigger challenges. I'd probably defer some on that to our mechanical mentor about how he incorporate actuators into designs, for example in CAD modeling. We have used various sources for cylinders, from the official suppliers, eBay, free ones through KoP, built up stock from previous years, etc.
Unread 12-06-2018, 12:13 PM
ONeill6330 ONeill6330 is offline
no team (Arc Angels)
ONeill6330 is an unknown quantity at this point
How to Off Board the Compressor...listing steps on event queuing???
Based on 2018 Manual...since we do not have 2019 FRC Manual...
Can you please describe by a picture and text steps to load air into the cylinders before a match compliant with the event rules...
Example:
1)Robot in the Cue for the next event
2)task 2??? .....
nth) last task close outside air valve and swap robot battery???
Missing the exact steps to do this both safely and correctly....
Otherwise I would love to just run an air compressor off its own battery FRC compliant, by a separate battery and have the relief value not allow the pressure beyond the allowed 120PSI limit...both easy and safe....The compressor would simply run through a power on off mechanical switch...."I don't think this is allowed???"
So how it the proper way to use Pneumatics without an aircompressor on board, and without using any of the new batteries power for the 2 minute - ish event match???
Unread 12-06-2018, 12:58 PM
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
You've studied Figure 8-15 in the 2018 game manual?
1 put a battery in the robot
2 connect compressor wires to PCM (hopefully using a connector such as Anderson Powerpole).
3 connect tube from offboard compressor, to robot manual valve fitting
4. close manual valve on compressor, open manual valve on robot
5 turn on robot power and enable, it will run the compressor until it reaches operating pressure, then compressor will shut off automatically
6 turn off robot power
7 close manual valve on robot, open manual valve on compressor, this will relaase pressure in tube
8 disconnect tube, and unplug compressor wire
9. replace robot battery with a fresh competition battery
10 go out and win a match
Unread 12-06-2018, 01:06 PM
AKA: Nelson Green
Re: How to Off Board the Compressor...listing steps on event queuing???
Example:
2)task 2??? .....
1) Return from match.
2) Connect Ethernet cable between RoboRIO and controlling laptop
3) Turn on robot (with battery from previous match)
4) Connect off-board compressor to robot. The Pnuematic Control Module (PCM) is on the robot and should have a short length of wires for compressor power with a quick connectors (for example, anderson powerpoles), and those should also be on compressor wires so that it can be plugged in easily. The pneumatic tubing from the compressor should connect to a quick connect fitting on the robot. So only two connections to make. Optionally, if you have the pressure switch off-board, in the second off-board configuration, you will have two extra wires to connect to quick connects coming from the PCM.
5) Enable the robot and run until the compressor shuts off.
6) Disable and turn off robot.
7) Disconnect all compressor connections and ethernet connection (after any other testing you want to do.
8) Switch battery and be ready to go to queue.
** It is best to leave the previous battery in place and use it to recharge your tanks. Also, it goes without saying that with off-board operation that you want your on-robot pneumatics to be air tight. If there is a tiny leak (1 psi loss in a few minutes), you want to recharge as late as possible so you don't lose too much pressure waiting
edit: forgot some of the valve steps, but covered above
Powered by vBulletin®
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
