Go to Post Although it is tempting, try not to toot your own horn in this thread. While you may have an awesome bot, the real compliment should come from other teams. - Andy Baker [more]
Go Back   Chief Delphi > Technical > Programming > Python
Unread 03-30-2018, 03:17 PM
gcperk20's Avatar
gcperk20 gcperk20 is offline
AKA: Grant Perkins
FRC #1100
Rookie Year: 2016
gcperk20 is on a distinguished road
Install OpenCV for RobotPY-CScore
Hi all. I am trying to use RobotPY-CScore, and I am getting stuck at the error bellow while running: pip3 install robotpy-cscore
src/_cscore.cpp(11): fatal error C1083: Cannot open include file: 'opencv2/opencv.hpp': No such file or directory
error: command 'C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\BuildTools\\VC\\Tools\\MSVC\\14.13.2 6128\\bin\\HostX86\\x64\\cl.exe' failed with exit status 2
I have been following this tutorial. I have installed pybind11 already. I also installed opencv at C:\opencv\
Thank you!
Unread 03-30-2018, 10:27 PM
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
FRC #6367 (), FRC #7240 ()
virtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant future
Re: Install OpenCV for RobotPY-CScore
You will of course note the following:
robotpy-cscore has not been tested on Windows
First, you need to compile/install opencv on Windows (which you did). Second, you need to convince robotpy-cscore to find them. It's a bit challenging, and I'm not 100% sure of the steps you'll need to do for the second piece.
You may have better luck trying to install robotpy-cscore on msys2.
Maintainer of RobotPy (Python for FRC) & WPILib Contributor
Creator of pyfrc (Robot Simulator + utilities for Python), pynetworktables/pynetworktables2js (NetworkTables for Python & Javascript), and lots more...
Team #1418 (remote mentor): Newton Quarterfinalists, 2016 Chesapeake District Champion, 2x Innovation in Control award, 2x district event winner
Team #1418: 2015 DC Regional Innovation In Control Award, #2 seed; 2014 VA Industrial Design Award; 2014 Finalists in DC & VA
Team #2423: 2012 & 2013 Boston Regional Innovation in Control Award
Resources: FIRSTWiki (relaunched!) | My Software Stuff
Unread 03-30-2018, 10:29 PM
virtuald's Avatar
RobotPy Guy
Thinking about it, if you downloaded the source code for robotpy-cscore, you could modify setup.py's include paths part, and add a pointer to the correct C:\OpenCV\include\path...
Also, note that cscore isn't able to use USB cameras on Windows, it can only read from remote HTTP camera streams.
Unread 03-31-2018, 09:42 PM
auscompgeek's Avatar
auscompgeek auscompgeek is offline
AKA: David Vo
FRC #4774 (The Drop Bears)
Rookie Year: 2016
auscompgeek is an unknown quantity at this point
You might also be able to use the CL environment variable to add
Code:
/I C:\OpenCV\include
or similar to convince CL to find OpenCV's headers.
Good luck!
Unread 03-31-2018, 09:43 PM
virtuald's Avatar
RobotPy Guy
Also, if you do get it working, please post how you did it so we can update the instructions for Windows users! I just don't really use Windows these days...
Unread 04-02-2018, 03:20 PM
gcperk20's Avatar
AKA: Grant Perkins
FRC #1100
Rookie Year: 2016
Hi all. I was not able to get RobotPy-CSCore to work on Windows, although I only invested about another ~1 1/2 after the writing of this post. I was doing this to test code I was writing for my team's Raspberry Pi 3, which I did not have at my home at the time.
I spent A TON of time working on installing RobotPy-CScore onto the Pi3. Building OpenCV for the Pi was a huge hassle. I wrote some instructions on how to get a RobotPy Python file running here. Please check it out, and let me know if there's something better that I could've done.
Unread 04-02-2018, 03:21 PM
gcperk20's Avatar
AKA: Grant Perkins
FRC #1100
Rookie Year: 2016
Now I just need to finish implementing PyNetworkTables into the code found on the above repository, and write a script to init.d to run the Python files on start-up.
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
