OCCRA
Go to Post Just like it is not all about the robots, it is not all about winning the Chairman's Award. - Paul Copioli [more]
Go Back   Chief Delphi > Technical > Programming > Python
Unread 04-04-2018, 07:38 AM
kylelanman's Avatar
kylelanman kylelanman is offline
Programming Mentor
AKA: Kyle
FRC #2481 (Roboteers)
Rookie Year: 2007
kylelanman is a splendid one to beholdkylelanman is a splendid one to beholdkylelanman is a splendid one to beholdkylelanman is a splendid one to beholdkylelanman is a splendid one to beholdkylelanman is a splendid one to beholdkylelanman is a splendid one to beholdkylelanman is a splendid one to behold
PyNetworkTables custom dashboard help
We are trying and not not having luck with a custom dashboard. The attached code renders a field and then renders 2 locations on top of the field. The x,y,yaw of the robot, and the x,y,yaw of the path the robot is trying to follow.
Also attached is a script that generates dummy data and publishes it over network tables for testing. When using this script it works as expected.
When changing the IP address that the liveObserverPlotter connects to to be the robot (10.24.81.2) it doesn't work. When debugging and stepping through the code NetworkTables appears to be empty as if it didn't connect.
To help further debug the problem we took a Wireshark trace. It is clear that the connection is being established because we see all the keys being sent from the robot to the laptop running our custom dashboard.
Given this works when the network tables server is hosted locally on the same laptop we are at a loss as to why this isn't working.
We are using network tables 2018.1 via `pip install pynetworktables`
Any help would be greatly appreciated.
"May the coms be with you"
Is this a "programming error" or a "programmer error"?
Unread 04-04-2018, 09:13 AM
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
FRC #6367 (), FRC #7240 ()
virtuald has a reputation beyond reputevirtuald has a reputation beyond reputevirtuald has a reputation beyond reputevirtuald has a reputation beyond reputevirtuald has a reputation beyond reputevirtuald has a reputation beyond reputevirtuald has a reputation beyond reputevirtuald has a reputation beyond reputevirtuald has a reputation beyond reputevirtuald has a reputation beyond reputevirtuald has a reputation beyond repute
Re: PyNetworkTables custom dashboard help
NetworkTables doesn't connect instantaneously, so the methodology you're using to do this won't work (and shouldn't have worked locally).
To wait for the connection, add the following after your initialize call:
Code:
import threading
cond = threading.Condition()
notified = [False]
def connectionListener(connected, info):
    print(info, '; Connected=%s' % connected)
    with cond:
        notified[0] = True
        cond.notify()
NetworkTables.addConnectionListener(connectionListener, immediateNotify=True)
with cond:
    print("Waiting")
    if not notified[0]:
        cond.wait()
print("Wait finished")
Maintainer of RobotPy (Python for FRC) & WPILib Contributor
Creator of pyfrc (Robot Simulator + utilities for Python), pynetworktables/pynetworktables2js (NetworkTables for Python & Javascript), and lots more...
Team #1418 (remote mentor): Newton Quarterfinalists, 2016 Chesapeake District Champion, 2x Innovation in Control award, 2x district event winner
Team #1418: 2015 DC Regional Innovation In Control Award, #2 seed; 2014 VA Industrial Design Award; 2014 Finalists in DC & VA
Team #2423: 2012 & 2013 Boston Regional Innovation in Control Award
Resources: FIRSTWiki (relaunched!) | My Software Stuff
Unread 04-04-2018, 09:23 AM
virtuald's Avatar
RobotPy Guy
Also added to the documentation (once it the doc build finishes):
http://robotpy.readthedocs.io/en/lat...on-coprocessor
Unread 04-04-2018, 09:42 AM
kylelanman's Avatar
Programming Mentor
AKA: Kyle
Rookie Year: 2007
Code:
import threading
    with cond:
        cond.notify()
with cond:
    print("Waiting")
    cond.wait()
print("Connected!")
We understand that the connection takes time. `updatePoint` is called repeatedly by `animation.FuncAnimation`. We expected for the connection to not yet have been established for the first few calls but assumed that once the connection was established that the get number calls would start working. We assumed this is why it works with the local `ntServer.py` script running. Given that `updatePoint` is called periodically would you still expect us to be having problems?
We will give your suggestion a try tomorrow or Friday.
Thanks!!!
Unread 04-04-2018, 10:06 AM
virtuald's Avatar
RobotPy Guy
Thanks!!!
Sorry, I missed the animation bit... yes, I would expect that to work then, assuming the connection is successfully made. I would recommend enabling debug logging then to see if the connection is successful:
Code:
import logging
logging.basicConfig(level=logging.DEBUG)
Unread 04-04-2018, 10:09 AM
kylelanman's Avatar
Programming Mentor
AKA: Kyle
Rookie Year: 2007
Code:
import logging
No worries. We will enable logging too and see if that reveals anything.
Thanks again for the help!!
Unread 04-04-2018, 06:13 PM
gcperk20's Avatar
gcperk20 gcperk20 is offline
AKA: Grant Perkins
FRC #1100
Rookie Year: 2016
gcperk20 is on a distinguished road
Code:
import threading
    with cond:
        cond.notify()
with cond:
    print("Waiting")
    cond.wait()
print("Connected!")
I'm a beginner when it comes to threads. When does cond.notify() run? When the robot is connected? When is the info and status outputted from that same function?
Unread 04-04-2018, 07:05 PM
virtuald's Avatar
RobotPy Guy
The connectionListener function is called after NetworkTables connects to a server.
Unread 04-04-2018, 07:10 PM
virtuald's Avatar
RobotPy Guy
Actually, the original code I published had a race condition in it. I edited it with a fix.
Unread 04-04-2018, 07:23 PM
gcperk20's Avatar
AKA: Grant Perkins
FRC #1100
Rookie Year: 2016
Why, in your new code, is the variable "notified" a list? Would it not be easier to just assign it to False, not [False] and refer to the item by index?
Unread 04-04-2018, 07:24 PM
gcperk20's Avatar
AKA: Grant Perkins
FRC #1100
Rookie Year: 2016
I'm dumb. Forgot about scope!
Unread 04-04-2018, 07:26 PM
gcperk20's Avatar
AKA: Grant Perkins
FRC #1100
Rookie Year: 2016
Is this code necessary if the client is only attempting to put, not get, numbers? Will exceptions be raised?
Unread 04-04-2018, 07:55 PM
virtuald's Avatar
RobotPy Guy
The code won't help you if you try to put variables, it's only useful for momentary get. To put variables, you would need to use this AND add a 1-second sleep at the end of your code.
The reality is that networktables isn't designed to be used with fire and forget scripts, but rather it's designed to be used with a continuously running thing.
Unread 04-05-2018, 08:35 PM
kylelanman's Avatar
Programming Mentor
AKA: Kyle
Rookie Year: 2007
Okay...we enabled logging. We are seeing the following errors.
Code:
INFO:nt:NetworkTables initialized in client mode
DEBUG:nt.th:Started thread nt-dispatch-thread-0
DEBUG:nt.th:Started thread nt-client-thread-0
INFO:matplotlib.backends._backend_tk:Could not load matplotlib icon: bad option "foobar": must be aspect, attributes, client, colormapwindows, command, deiconify, focusmodel, forget, frame, geometry, grid, group, iconbitmap, iconify, iconmask, iconname, iconphoto, iconposition, iconwindow, manage, maxsize, minsize, overrideredirect, positionfrom, protocol, resizable, sizefrom, stackorder, state, title, transient, or withdraw
DEBUG:nt:client connected
DEBUG:nt.th:Started thread nt-net-write-0
DEBUG:nt.th:Started thread nt-net-read-0
ERROR:nt:Unhandled exception during handshake
Traceback (most recent call last):
  File "/Users/kyle/src/frc-2018/venv/lib/python2.7/site-packages/ntcore/network_connection.py", line 248, in _readThreadMain
    handshake_success = self.m_handshake(self, _getMessage, self._sendMessages)
  File "/Users/kyle/src/frc-2018/venv/lib/python2.7/site-packages/ntcore/dispatcher.py", line 571, in _clientHandshake
    msg = get_msg()
  File "/Users/kyle/src/frc-2018/venv/lib/python2.7/site-packages/ntcore/network_connection.py", line 236, in _getMessage
    return Message.read(self.m_stream, decoder, self.m_get_entry_type)
  File "/Users/kyle/src/frc-2018/venv/lib/python2.7/site-packages/ntcore/message.py", line 123, in read
    value = codec.read_value(value_type, rstream)
  File "/Users/kyle/src/frc-2018/venv/lib/python2.7/site-packages/ntcore/wire.py", line 114, in read_value
    return Value.makeString(self.read_string(rstream))
  File "/Users/kyle/src/frc-2018/venv/lib/python2.7/site-packages/ntcore/wire.py", line 199, in read_string_v3
    return rstream.read(slen).decode('utf-8')
  File "/Users/kyle/src/frc-2018/venv/lib/python2.7/encodings/utf_8.py", line 16, in decode
    return codecs.utf_8_decode(input, errors, True)
UnicodeDecodeError: 'utf8' codec can't decode byte 0xd8 in position 0: invalid continuation byte
INFO:nt:DISCONNECTED 10.24.81.2 port 1735 (Robot)
DEBUG:matplotlib.font_manager:findfont: Matching :family=sans-serif:style=normal:variant=normal:weight=normal:stretch=normal:size=10.0 to DejaVu Sans (u'/Users/kyle/Documents/talon_controller/venv/lib/python2.7/site-packages/matplotlib/mpl-data/fonts/ttf/DejaVuSans.ttf') with score of 0.050000
DEBUG:nt.th:Thread nt-net-read-0 exited
DEBUG:nt.th:Thread nt-net-write-0 exited
0.0 0.0 0.0 0.0
0.0 0.0 0.0 0.0
DEBUG:nt:NetworkConnection stopping (<NetworkConnection 0x113dd41d0 ConnectionInfo(remote_id=u'Robot', remote_ip='10.24.81.2', remote_port=1735, last_update=0, protocol_version=768)>)
DEBUG:nt.th:Started thread nt-net-write-1
DEBUG:nt.th:Started thread nt-net-read-1
    msg = get_msg()
UnicodeDecodeError: 'utf8' codec can't decode byte 0xc0 in position 0: invalid start byte
DEBUG:nt.th:Thread nt-net-read-1 exited
DEBUG:nt.th:Thread nt-net-write-1 exited
  #15   Spotlight this post!
Unread 04-05-2018, 10:45 PM
virtuald's Avatar
RobotPy Guy
Awesome! This is the a similar bug to that which was reported at https://github.com/robotpy/pynetwork...ment-376410216 ... I assume it happens every time?
If you can check out the handshake-2018 branch, install it, run it against your robot, if you get that error then there should be a file called 'file.bin' in the directory you launched your script from. Send me that file and I can probably push a fix for you relatively quickly.
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
