Go to Post Scientists ask Why, Engineers ask Why not. - Rohith Surampudi [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 02-04-2017, 03:52 PM
duane's Avatar
duane duane is offline
FRC #0701 (RoboVikes)
duane is an unknown quantity at this point
Send a message via AIM to duane
CAN Bitrate?
What is the bitrate for the RoboRio CAN bus?
We are endeavoring to connect a Raspberry Pi to the RoboRio via the CAN bus.
We are using a CAN shield on the Pi to communicate to the bus. When initializing the driver for CAN on the Raspberry Pi we are using a bit rate of 500000. This value causes the connected TalonSRX devices to periodically blink red. I believe that indicates some kind of bus fault. We have also noticed that the commands will be interrupted (as motors will stop working for a moment and then resume).
Perhaps there is something else we are doing incorrectly, but I thought I would start and getting the device to exist silently on the bus.
So, what bitrate is the RoboRio CAN bus operating?
Thanks for the help.
...Duane
Duane Murphy
Mentor - Software
Vanden Vikings FIRST Team 701
http://www.vandenrobotics.com
Unread 02-04-2017, 09:12 PM
J. Tumavitch J. Tumavitch is offline
FRC #2832
J. Tumavitch is an unknown quantity at this point
Re: CAN Bitrate?
The roboRIO CAN bus is 1000000 or 1 Mbps not 500000.
Unread 02-04-2017, 09:28 PM
duane's Avatar
Re: CAN Bitrate?
Thank you! We managed to work that out! Quite successful to see candump work on the Pi! Lots of fun traffic.
Duane Murphy
Mentor - Software
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
