OCCRA
Go to Post Saying that something cannot be done, is always good inspiration for someone to find a way to do it. - Josh Hambright [more]
Go Back   Chief Delphi > FIRST > Rumor Mill
Thread Tools Rating: Thread Rating: 14 votes, 4.93 average. Display Modes
  #256   Spotlight this post!
Unread 12-20-2017, 10:16 PM
qscgy's Avatar
qscgy qscgy is offline
Minister of Zip Ties
AKA: Sam Ehrenstein
FRC #0449 (The Blair Robot Project)
Rookie Year: 2014
qscgy has a reputation beyond reputeqscgy has a reputation beyond reputeqscgy has a reputation beyond reputeqscgy has a reputation beyond reputeqscgy has a reputation beyond reputeqscgy has a reputation beyond reputeqscgy has a reputation beyond reputeqscgy has a reputation beyond reputeqscgy has a reputation beyond reputeqscgy has a reputation beyond reputeqscgy has a reputation beyond repute
Re: 2018 Game Speculation
Originally Posted by GeeTwo View Post
Most tube manipulators I've seen exploit the hole, grabbing around the small diameter of the toroid. To handle coin-shaped objects, one would be more likely to model after at 2013 disc or 2017 gear manipulators.
Would they use the same type of game piece two years in a row?
FRC Team 449, 2014-Present
Case Western Reserve University Class of 2021
  #257   Spotlight this post!
Unread 12-20-2017, 11:42 PM
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Mentor
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
Other than balls, My history notes say FIRST has never used the same type of game piece two years in a row. If you define balls tightly enough to exclude stiff round shapes with with holes (2017 fuel and 2009 cells), the last time we had back-to-back ball games was 2000-2002.
That's why I don't really expect to manipulate "coins" - they're too much like gears.
[Quoting brennonbrimhall]: We design a new robot every year, but we can't forget that we also design a new team every year as folks come and go.
  #258   Spotlight this post!
Unread 12-20-2017, 11:53 PM
Ginger Power's Avatar
Ginger Power Ginger Power is offline
Founder of COR Robotics
AKA: Ryan Swanson
Rookie Year: 2013
Ginger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond repute
Placing an inflatable coin shaped tube through a vertical slot presents a significantly different challenge than manipulating a gear in 2017.
How do you manipulate a coin shaped tube so that you can insert it into a vertical slot? I've been thinking about it a little bit, and it doesn't seem to be trivial.
  #259   Spotlight this post!
Unread 12-21-2017, 12:07 AM
GeeTwo's Avatar
Mentor
AKA: Gus Michel II
Rookie Year: 2013
Forget manipulators; I'm having enough trouble wrapping my brain around what you mean by a coin shaped tube.
  #260   Spotlight this post!
Unread 12-21-2017, 12:26 AM
AKA: Ryan Swanson
Rookie Year: 2013
https://encrypted-tbn0.gstatic.com/i...pnafbc3Z-J4OXg
When I said tube I was envisioning a water tube with no hole in it. More or less coin shaped...
  #261   Spotlight this post!
Unread 12-21-2017, 07:17 AM
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is offline
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Daniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond repute
Send a message via MSN to Daniel_LaFleur
Manipulating that would not be too difficult, with a roller claw with rotatable wrist.
Now if the "coin" was much softer (like the Floppy I said before) it would be far more difficult to push through the coin slot.
"We are not now that strength which in old days moved earth and heaven; that which we are, we are;
One equal temper of heroic hearts, Made weak by time and fate, but strong in will
To strive, to seek, to find, and not to yield. "
- Tennyson, Ulysses
  #262   Spotlight this post!
Unread 12-21-2017, 09:37 AM
JKippy JKippy is offline
AKA: Jason
FRC #0548 (Robostangs)
Team Role: Leadership
Rookie Year: 2010
JKippy is an unknown quantity at this point
Hmm 5 person drive team.
  #263   Spotlight this post!
Unread 12-21-2017, 09:57 AM
pkrishna3082's Avatar
pkrishna3082 pkrishna3082 is offline
love/hate relationship with swerve
AKA: Parthiv Krishna
FRC #3082 (Chicken Bot Pie) and FTC #13471 Mentor (Minnetonka)
Rookie Year: 2016
pkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond repute
Originally Posted by Dan Waxman View Post
Neural networks are cool and all but it's hardly a fair playing field. Even for an SSD, a fairly lightweight CNN architecture, a Raspberry Pi would be very very slow for real time play. Teams that have the money to buy more expensive coprocessors (e.g. nVidia's stuff) would be at a huge advantage. It's one of those things where I don't think it's technical limitations, but money that really matters.
Fortunately, I'm on a team that could afford this technology, but I'd hate for there to be a strong incentive to implement tech that isn't affordable for a large number of teams.
I was mostly joking, but I agree, it's not a very accessible technology at this time. Perhaps in the future?
My posts constitute my opinions, and mine alone, and are not representative of the views held by my team.
2010-2011: FLL 11083, 13873 (Minnetonka Silver) - Programmer
2016-: FRC 3082 (Chicken Bot Pie) - Engineering Captain, fmr. Programming Lead, 2017&2018 Dean's List Finalist
2017-: FTC 13471 (Minnetonka) - Founding Mentor
  #264   Spotlight this post!
Unread 12-21-2017, 10:02 AM
Green Potato Green Potato is offline
AKA: Tory Farmer
FRC #0422 (Mech Tech Dragons)
Green Potato is a splendid one to beholdGreen Potato is a splendid one to beholdGreen Potato is a splendid one to beholdGreen Potato is a splendid one to beholdGreen Potato is a splendid one to beholdGreen Potato is a splendid one to beholdGreen Potato is a splendid one to behold
You see, I think we're thinking of the wrong type of coin.
Everything that can go wrong WILL go wrong, except the things we expect to go wrong and actually plan for.
  #265   Spotlight this post!
Unread 12-21-2017, 10:11 AM
Overlord6190's Avatar
Overlord6190 Overlord6190 is offline
AKA: Thomas K.
FRC #4561 (TerrorBytes)
Team Role: Driver
Rookie Year: 2016
Overlord6190 is an unknown quantity at this point
Last year had a five person drive team
  #266   Spotlight this post!
Unread 12-21-2017, 10:18 AM
GeeTwo's Avatar
Mentor
AKA: Gus Michel II
Rookie Year: 2013
Or perhaps eight Ningis.
Edit: Hmmm... makes me wonder if there will be a change machine as part of the field.
  #267   Spotlight this post!
Unread 12-21-2017, 10:28 AM
ctt956's Avatar
ctt956 ctt956 is offline
Mostly Legal Volunteer
Rookie Year: 2016
ctt956 has much to be proud ofctt956 has much to be proud ofctt956 has much to be proud ofctt956 has much to be proud ofctt956 has much to be proud ofctt956 has much to be proud ofctt956 has much to be proud ofctt956 has much to be proud ofctt956 has much to be proud of
What about green inflatable rectangular tubes as "dollar bills"? There could be different amount bills...
"You know, it's amazing how many things you can take apart with just one ordinary screwdriver!" - Calvin, from Calvin and Hobbes
"There's nothing a little duct tape and surgical tubing can't accomplish." - Sheldon J. Plankton
  #268   Spotlight this post!
Unread 12-21-2017, 10:36 AM
bduddy bduddy is offline
FRC #0840 (ART)
bduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond repute
According to Frank there will be "No place this year for team banners to be hung": https://www.firstinspires.org/roboti...-rules-updates
Does this mean that there will be some object on top of most/all of the alliance station wall? Surely there must be an alliance station wall, right...?
Does anyone else remember when TBA signatures actually worked?
  #269   Spotlight this post!
Unread 12-21-2017, 10:41 AM
AKA: Jason
Rookie Year: 2010
Not trying to say it was anything new, just pointing out that the new size of drive teams for future games could be 5 instead of 4.
Using what we know about how FIRST utilized the 5 member DT last year in the game could give us some insight into the roles of the members of the DT this year.
  #270   Spotlight this post!
Unread 12-21-2017, 11:30 AM
AKA: Thomas K.
Team Role: Driver
Rookie Year: 2016
I think that there are still going to be human players that will “process” game peices before they are scored this year. (Like piolts having to pull up gears)
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
