OCCRA
Go to Post I would say FIRST is quite an addiction.............but one of the BEST addictions you'll ever have. - RoboMadi [more]
Unread 03-21-2018, 06:19 PM
cpapplefamily's Avatar
cpapplefamily cpapplefamily is offline
FRC #3244 (Granite City Gearheads)
Rookie Year: 2015
cpapplefamily is a splendid one to beholdcpapplefamily is a splendid one to beholdcpapplefamily is a splendid one to beholdcpapplefamily is a splendid one to beholdcpapplefamily is a splendid one to beholdcpapplefamily is a splendid one to beholdcpapplefamily is a splendid one to behold
ShuffleBoard Update
Suffleboard is not updating with in the app. Using the menu to Check for updates or selecting the install and restart both seem to download the update but the install never happens. The app closes and nothing....... If I open the app back up its still 1.2.2
It makes sense in my mind.
Unread 03-21-2018, 06:34 PM
SamCarlberg's Avatar
SamCarlberg SamCarlberg is offline
GRIP/Shuffleboard/WPILib. 2084 alum
FRC #2084
SamCarlberg has a brilliant futureSamCarlberg has a brilliant futureSamCarlberg has a brilliant futureSamCarlberg has a brilliant futureSamCarlberg has a brilliant futureSamCarlberg has a brilliant futureSamCarlberg has a brilliant futureSamCarlberg has a brilliant futureSamCarlberg has a brilliant futureSamCarlberg has a brilliant futureSamCarlberg has a brilliant future
Re: ShuffleBoard Update
Is there a space in your username?
WPILib developer
GRIP, RobotBuilder, Shuffleboard
Unread 03-21-2018, 06:36 PM
Rookie Year: 2015
No I seen that in the list of issues of on git
here is our path
C:\Users\Owner\wpilib\tools
yes Owner is the name
Unread 03-21-2018, 06:47 PM
FRC #2084
Shuffleboard might be closing too late for the copy scripts to overwrite the jar file. Does it work if you run the update right after opening, or with an empty layout?
You can download the jar file manually here if it still won't update. You'll have to manually download it to C:\Users\Owner\wpilib\tools\Shuffleboard.jar
WPILib developer
Unread 03-21-2018, 06:50 PM
Rookie Year: 2015
I try to clear the tabs. First I'll tell you the same thing is happening on our second driverstation that is currently at 1.3.0
Path is:
C:\Users\Gearheads3244\wpilib\tools
Unread 03-21-2018, 07:04 PM
Rookie Year: 2015
I renamed the C:\Users\Owner\Shuffleboard\Shuffleboard.json to Shuffleboard_bck.json
opened Shuffleboard
install and restart
it downloaded... shutdown......... nothing
What i did notice is I can't manipulate the save file unless i restart the computer. seems the file is still locked even with the app closed.
Unread 03-21-2018, 07:39 PM
Rookie Year: 2015
Ok So on my "Gearheads3244" laptop I downloaded from the link and replaced the file but again I had to restart the computer because I could not remove or rename the shuffleboard.jar
I left the "Owner" laptop as is if you wish for me to gather other details and test things out. We can continue to chat in this thread or PM.
Unread 03-21-2018, 07:53 PM
FRC #2084
Shuffleboard is definitely not shutting down properly. The window is gone, but some non-daemon thread is still alive. I've only seen this happen when the application or render threads are at high CPU use, or when the garbage collector is particularly busy on those threads
WPILib developer
Unread 03-21-2018, 07:58 PM
Rookie Year: 2015
Owner is an i5 Windows7 dedicated driverstation / Eclipse Java Programing Laptop
Gearheads3244 is fresh install i7 windows7 8G ram. Only software installed is the required Java and driverstation software.
Unread 10-09-2018, 04:14 PM
Crossle86's Avatar
Crossle86 Crossle86 is offline
Software Engineer
AKA: Richard Corn
FRC #4450 (Olympia Robotics Federation)
Crossle86 is an unknown quantity at this point
So this was broken in March and now its October and its still broken...as I can't get the auto update to work. I'm trying to understand what the level of maintenance is on SB...
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
