OCCRA
Go to Post If it's the loss of American lives that concerns the nation, why not campaign aggressively against smoking, or improve automobile safety? At least then, the benefits will be tangible, and substantially more significant to the well being of the locals. - Tristan Lall [more]
CD-Media
  #31   Spotlight this post!
Unread 05-09-2018, 07:28 AM
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
Re: Proposals for 2018 IRI Rule Changes?
Originally Posted by cscottm View Post
Opposing Switch is worth 1 point every 2 seconds.
That way, you know, the switches have a point.
ooh I like this.
Also -
During alliance selections, if a team representative Graciously Accepts, that alliance carries a yellow card with them through playoffs.
Hi!
  #32   Spotlight this post!
Unread 05-09-2018, 07:40 AM
Loose Screw's Avatar
Loose Screw Loose Screw is offline
A Loose Screw
AKA: Chris
FTC #5237 (Loose Screws)
Loose Screw has much to be proud ofLoose Screw has much to be proud ofLoose Screw has much to be proud ofLoose Screw has much to be proud ofLoose Screw has much to be proud ofLoose Screw has much to be proud ofLoose Screw has much to be proud ofLoose Screw has much to be proud ofLoose Screw has much to be proud of
I think whatever IRI does it needs to stop the snowballing. So the ideas of bonuses for winning the Scale in auto may sound cool, but will only make that issue worse. Same goes for gaining points for controlling an opponent's Switch.
I would say lessen the weight of the Scale by making the Switches grant 2pts/second.
The Force Power Up needs a buff as well. I would keep Lv1 the same, make Lv2 control both your Switch and Scale, and then make Lv3 control both Switches and the Scale.
While I'm buffing Power Ups, why not make it so you can use both Force and Boost at the same time? This wouldn't benefit teams in the lead (they have both Switch/Scale so Force would be unnecessary), but could help teams behind make a comeback.
  #33   Spotlight this post!
Unread 05-09-2018, 08:17 AM
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191
Originally Posted by Taylor View Post
ooh I like this.
Also -
Just sic Carolyn Nobel on them. After she's done with them they will probably ban the word graciously from their vocabulary.
Koko Ed's 2018 FIRST Power Up Tour!
EVENTS: 25 MILES TRAVELED:23,246 miles NEXT EVENT SEASON OVER: Deep Space Launch in January
  #34   Spotlight this post!
Unread 05-09-2018, 08:23 AM
Taylor's Avatar
AKA: @taylorstem
She was the inspiration for the rule.
Hi!
  #35   Spotlight this post!
Unread 05-09-2018, 08:26 AM
Koko Ed's Avatar
Serial Volunteer
AKA: Ed Patterson
FRC #0191
They should give an award (or a roasted corn on the cob) to the most creative acceptance.
  #36   Spotlight this post!
Unread 05-09-2018, 08:49 AM
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Have a weighted Companion Cube for each alliance, with 2-4x the mass of a normal power cube. Keeps with the video game aesthetic, and adds an interesting strategic element.
(I think someone on 2370 mentioned a weighted cube as an interesting rules twist)
  #37   Spotlight this post!
Unread 05-09-2018, 08:55 AM
Jarren Harkema's Avatar
Jarren Harkema Jarren Harkema is offline
Fuel Advocate
FRC #4967 (That ONE Team)
Jarren Harkema has a reputation beyond reputeJarren Harkema has a reputation beyond reputeJarren Harkema has a reputation beyond reputeJarren Harkema has a reputation beyond reputeJarren Harkema has a reputation beyond reputeJarren Harkema has a reputation beyond reputeJarren Harkema has a reputation beyond reputeJarren Harkema has a reputation beyond reputeJarren Harkema has a reputation beyond reputeJarren Harkema has a reputation beyond reputeJarren Harkema has a reputation beyond repute
If you really want to make it interesting, stick it in the center of the Cube Zone pile.
  #38   Spotlight this post!
Unread 05-09-2018, 09:03 AM
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
  #39   Spotlight this post!
Unread 05-09-2018, 09:22 AM
[FF]: QwEST
Any changes to the number of cubes or positioning of cubes would drastically change the effects of cube starvation IMO, so those should be off-the-table.
I'd say finding ways to relax annoying penalties, like touching the scale, cube launching, and maybe endgame platform zone extensions is the only real "change" I'd want to see to the game.
Otherwise, let the egos play
College Mentor of Team 5254, HYPE - Helping Youth Pursue Excellence (2015-2018)
Looking for full-time mechanical engineering positions starting May 2019
  #40   Spotlight this post!
Unread 05-09-2018, 10:09 AM
Billfred's Avatar
Billfred Billfred is offline
Never look back, no, never say die
AKA: Always attack with the warrior's cry...
FRC #1293 (Pandamaniacs); FTC #11444 (Garnet Squadron) (Also, CD mod.)
Two things to add based off what I read:
1) Yeah, flagrantly immaterial scale touching, or touching that hurts the alliance doing the touching (like bumping it the other way without removing cubes), should be a no-call.
2) Anyone that drops wings or lifters before endgame can use them as long as no alliance partner starts climbing on before T=15. Right now, attempting to use them at all is a red card, which feels a little strong.
William "Billfred" Leverette - Gamecock/Jessica Boucher victim/Owner/Director of Bricks 4 Kidz in Columbia, SC.
2017: FRC 5402 (Iron Kings) - Mentor, Coach (oh, and I worked at AndyMark during this time)
2018-: FRC 1293 (Pandamaniacs) - Mentor
114 events (more than will fit in a ChiefDelphi signature), 15 seasons, over 74,500 miles, and still on a mission from Bob.
  #41   Spotlight this post!
Unread 05-09-2018, 10:29 AM
efoote868 efoote868 is offline
foote stepped in
AKA: E. Foote
FRC #0868
efoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond repute
See if you can figure out how to pilot trial an Auton stop. Tech foul for using it.
  #42   Spotlight this post!
Unread 05-09-2018, 10:30 AM
bkahl bkahl is offline
Unregistered User
AKA: Bailey Kahl
FRC #0195
bkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond repute
Auto RP requires a cube in the switch AND scale
add me on snap: baykahl
  #43   Spotlight this post!
Unread 05-09-2018, 10:49 AM
tickspe15's Avatar
Purdue University
AKA: Spencer Tickman
tickspe15 has a reputation beyond reputetickspe15 has a reputation beyond reputetickspe15 has a reputation beyond reputetickspe15 has a reputation beyond reputetickspe15 has a reputation beyond reputetickspe15 has a reputation beyond reputetickspe15 has a reputation beyond reputetickspe15 has a reputation beyond reputetickspe15 has a reputation beyond reputetickspe15 has a reputation beyond reputetickspe15 has a reputation beyond repute
I like this idea. Ownership or just a cube placement? If ownership is it ownership at the end of auto or just at some point?
Team 1318: 2011-2015
Team 1747: 2015-Present
  #44   Spotlight this post!
Unread 05-09-2018, 10:59 AM
maxxman maxxman is offline
maxxman is a jewel in the roughmaxxman is a jewel in the roughmaxxman is a jewel in the rough
Make this happen please.
Have it so that you need to own at the end of th auto period. This way the RP isn't basically a gauretee.
This would help teams that have 4 and 3 cube autos climb to the top of the rankings which we would want.
  #45   Spotlight this post!
Unread 05-09-2018, 11:23 AM
Jared Russell's Avatar
4933T15
These are probably too ambitious (would require field PLC changes), but I'd love to see this version of Power Up be played somewhere:
1. Replace the "Levitate" power-up with a 3 cube "Swap" power-up. This permanently switches the plate assignment on the scale (until/unless the other alliance plays theirs) and locks out any other power ups from being played for 10s. This immediately switches the assignment of null territory as well, but robots already in the null territory when the power-up is played have 10s to vacate before fouls are called (i.e. any new robot from the previous alliance entering the null territory at this time does not benefit from this grace period).
Rationale: Opens the door for a team to recover from an early scale deficit through the exchange. Yes, it can be countered, but this requires putting someone on exchange duty early in the match.
2. A "Levitate" bonus (30 points plus credit for a free climb) is earned by whichever alliance has control of the scale at the end of teleop. This is the only way to get the free climb.
Rationale: Provides an incentive to continue to play for the scale even late in the match, and makes for more end-game drama. Let's see those towering stacks of cubes.
3. Either alliance can earn points on either switch.
Rationale: Gives switch bots a prayer against scale bots and ensures the previous change isn't OP.
4. Eliminate launching penalties for launches unless unsafe. Use common sense for reffing this.
Rationale: Realistically nobody comes close to this except in very weird, obviously non-intentional cases.
5. Eliminate scale touching penalties unless it gives your alliance an advantage.
Rationale: Eliminates the double whammy of tipping the scale towards your opponent AND being penalized for it.
6. Any contact in protected areas in auto results in the opposing alliance being awarded a free auto quest RP.
Rationale: This fixes a straight up hole in the original rules.
Powered by vBulletin®
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
