Go to Post Blowing out the transmission on your mini-van while hauling a trailer 700 miles from home is not fun. Trust me on this. - dlavery [more]
Unread 01-10-2018, 03:21 PM
FredyK200 FredyK200 is offline
FRC #0240
FredyK200 is an unknown quantity at this point
Question Record and Play Motor Movements
This year we are planning on making a robotic arm like the ones used in manufacturing to grab and move the power cubes.We are also planning on having set positions for the arm to move to (One for grabbing a cube, one for placing it in the switch and one for the scale)
We are wondering what your ideas where for how to do this, My current plan is to use encoders to track distance and maybe save the output of the motors somewhere so that the code can read it back later.
Any input would be appreciated as past years we have had trouble with precise encoder readings and have no experience saving and reading data for FRC.
Thank you
Unread 01-10-2018, 03:33 PM
JeffB JeffB is offline
FRC #5052 (RoboLobos)
JeffB has a reputation beyond reputeJeffB has a reputation beyond reputeJeffB has a reputation beyond reputeJeffB has a reputation beyond reputeJeffB has a reputation beyond reputeJeffB has a reputation beyond reputeJeffB has a reputation beyond reputeJeffB has a reputation beyond reputeJeffB has a reputation beyond reputeJeffB has a reputation beyond reputeJeffB has a reputation beyond repute
Re: Record and Play Motor Movements
As a serious question, are you mad at yourselves?
I'm not sure of any way to record those motor movements. But, if you do decide this is the route you want to take (and can do so without extending beyond 16" from your frame perimeter), you'll probably have more sustained success looking into working with encoders and PID than you will trying to play things back as if there aren't any variables that can change the way you'd want things to play out.
Unread 01-10-2018, 04:09 PM
MuskieProgramme MuskieProgramme is offline
FRC #6420 (Fire Island Robotics)
MuskieProgramme is a glorious beacon of lightMuskieProgramme is a glorious beacon of lightMuskieProgramme is a glorious beacon of lightMuskieProgramme is a glorious beacon of lightMuskieProgramme is a glorious beacon of lightMuskieProgramme is a glorious beacon of light
This manipulator ticks all of my DO NOT PUT ON ROBOT boxes. It is mechanically, electrically, and programatically difficult.
Unread 01-10-2018, 04:17 PM
Add one more tick to "difficult for the driver to maneuver"
Unread 01-11-2018, 06:45 PM
FRC #0240
I'm an alum and I agree it's a terrible idea, But part of me also feels like it'd be a fun programming challenge. If we stick with this idea I'll let you guys know how it turned out
Unread 01-11-2018, 07:07 PM
Mitch Stokes's Avatar
Mitch Stokes Mitch Stokes is online now
Berkeley Engineering
AKA: Mitchel Stokes
FRC #5817
Mitch Stokes has a reputation beyond reputeMitch Stokes has a reputation beyond reputeMitch Stokes has a reputation beyond reputeMitch Stokes has a reputation beyond reputeMitch Stokes has a reputation beyond reputeMitch Stokes has a reputation beyond reputeMitch Stokes has a reputation beyond reputeMitch Stokes has a reputation beyond reputeMitch Stokes has a reputation beyond reputeMitch Stokes has a reputation beyond reputeMitch Stokes has a reputation beyond repute
Thank you
So first off if you decide that that is what you REALLY want to do, you're going to need to save the data onto a text file on the roborio and read it back later. But if you are going to put an encoder on your arm anyway, I have no idea why you would want to record motor movements when you can just use the encoder data and a PID to do a position controller anyway. Since it seems like your idea is to have some sort of a smooth movement between arm locations, you'd be better off writing a motion profiling system for the arm to follow, i.e. write a function that creates a motion profile to follow when you give it a start and end point.
Unread 01-11-2018, 08:14 PM
Owen Makin Owen Makin is offline
FRC #1972
Owen Makin is an unknown quantity at this point
1717 did something like this during Lunacy, which was i think 2009. Its mentioned in the book A New Cool. Follow what the other people were saying move to a set point dont try to record the movements. If you truly want to do it though, do it the easy way first then once you have some practice attempt the hard way. Maybe you can contact someone from 1717 to help you. I know they used java that year
Unread 01-12-2018, 09:00 AM
3310 struggled through it in 2015's Recycle Rush as well.
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
