OCCRA
Go to Post If you have a problem with a team, go to that team and address it with them. Don't air your slanderous opinions here for all to see. - Andy Baker [more]
Unread 08-11-2018, 12:11 PM
AmoryG AmoryG is offline
FRC #2423 (KwarQs)
AmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud of
Uses of the kalman filter in FRC
I'm studying the kalman filter and I'm wondering if teams can provide examples of how they used it in competition as well as the code if you're willing to share. I'm primarily interested in seeing examples of how it was used for estimating the position of the robot, although other use cases are welcome too.
KwarQs 2423
2008 Boston Regional Rookie Allstars
http://whsrobot.blogspot.com/
Unread 08-11-2018, 01:32 PM
calcmogul's Avatar
calcmogul calcmogul is offline
WPILib Developer
AKA: Tyler Veness
FRC #3512 (Spartatroniks)
calcmogul has much to be proud ofcalcmogul has much to be proud ofcalcmogul has much to be proud ofcalcmogul has much to be proud ofcalcmogul has much to be proud ofcalcmogul has much to be proud ofcalcmogul has much to be proud ofcalcmogul has much to be proud ofcalcmogul has much to be proud ofcalcmogul has much to be proud of
Re: Uses of the kalman filter in FRC
I actually wrote a thing recently that paraphrases the course I took at university on Kalman filter theory. See the "Stochastic control theory" chapter of https://file.tavsys.net/control/state-space-guide.pdf. Basically all the things I would have written here are already there. It has an example of a robot driving between two walls. The Kalman filter estimates the position of the robot from noisy range measurements ahead of and behind the robot.
The plots of the robot position etc. over time are generated using Python and the relevant Kalman filter equations. The Python source is in https://github.com/calcmogul/state-s...ee/master/code.
For FRC purposes, you typically find the steady-state Kalman gain and plug the matrices into a Luenberger observer instead, so it estimates states for a state-space controller. The controller isn't necessary though if you just want odometry.
Unread 08-11-2018, 02:35 PM
CarlosGJ CarlosGJ is offline
418 alumnus, 696 mentor
AKA: Carlos Gross Jones
FRC #0696 (Circuit Breakers)
CarlosGJ is a splendid one to beholdCarlosGJ is a splendid one to beholdCarlosGJ is a splendid one to beholdCarlosGJ is a splendid one to beholdCarlosGJ is a splendid one to beholdCarlosGJ is a splendid one to beholdCarlosGJ is a splendid one to behold
If you want to jump on the ROS train, there are existing nodes which implement Kalman filters to estimate robot position and orientation: http://wiki.ros.org/robot_pose_ekf
Unread 08-11-2018, 05:22 PM
kylelanman's Avatar
kylelanman kylelanman is offline
Programming Mentor
AKA: Kyle
FRC #2481 (Roboteers)
kylelanman is a splendid one to beholdkylelanman is a splendid one to beholdkylelanman is a splendid one to beholdkylelanman is a splendid one to beholdkylelanman is a splendid one to beholdkylelanman is a splendid one to beholdkylelanman is a splendid one to beholdkylelanman is a splendid one to behold
I've been dabbling in kfs this off season and have found this open source book to be a really easy read. The interactive nature of the notebooks is also a beneficial.
https://github.com/rlabbe/Kalman-and...ters-in-Python
The Udacity Artificial Intelligence for Robots is also a good free resource and has an entire unit on kfs.
https://www.udacity.com/course/artif...obotics--cs373
"May the coms be with you"
Is this a "programming error" or a "programmer error"?
Unread 08-13-2018, 02:25 PM
Citrus Dad's Avatar
Citrus Dad Citrus Dad is offline
Business and Scouting Mentor
AKA: Richard McCann
FRC #1678 (Citrus Circuits)
Citrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond repute
There's an extensive discuss of the use of Kalman filters for control in this thread: https://www.chiefdelphi.com/forums/s...d.php?t=165579
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
