OCCRA
Go to Post when I was a ball setter at PARC one year (6th grade?). As soon as I saw what High school students could do with thier own two hands and how they mingled with industry, I knew, at that moment, it was for me. - henryBsick [more]
Unread 09-05-2018, 05:43 AM
Zagar's Avatar
Zagar Zagar is offline
1506 Metal Muscle Electrical Team
AKA: Greg
FRC #1506 (Metal Muscle)
Team Role: Electrical
Rookie Year: 2015
Zagar is a name known to allZagar is a name known to allZagar is a name known to allZagar is a name known to allZagar is a name known to allZagar is a name known to all
Robot Signal Light
Hi all,
I have a question regarding the RSL. Is it allowable to have an intermediate connection point on the wiring to the RSL? Meaning, can I have something that plugs into the RIO and has a set of screw terminals for connection rather than splicing a 24AWG 2 pin connector to 20AWG to run out to the light?
Thanks
Unread 09-05-2018, 06:00 AM
marshall's Avatar
marshall marshall is offline
Online Stripe & Drape Sales
FRC #0900 (The Zebracorns)
Re: Robot Signal Light
Originally Posted by Zagar View Post
Hi all,
Thanks
I don’t see why not provided it is a connector only and does not interfere with the electrical signal being sent to the light.
That being said, I believe the port on the RoboRIO is sized for a 3pin .1” PWM connector (though only two of the pins are broken out) and you get a bunch in the kit every year so it makes it a bit easier.
Clarke's Laws
Unread 09-05-2018, 06:49 AM
AriMB's Avatar
AriMB AriMB is offline
The Philadelphian emigrant
AKA: Ari Meles-Braverman
FRC #5987 (Galaxia)
AriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond repute
The manual says:
Originally Posted by 2018 R71
Any RSL must be:
B. connected to the “RSL” supply terminals on the roboRIO,
It doesn't say "directly connected" or specify how it should be connected, simply "connected". I would interpret that to mean connectors are allowed between the roboRIO and RSL. As always, the final decision is up to your LRI, and rules are subject to change next season.
Studying MechE at the Technion - Israel Institute of Technology
2017-present: FIRST Israel CSA/FTAA
2017-present: FRC 5987 Technical Mentor 18isr2 18isr4 18isrcmp 18carv
2012-2016: FRC 423 Member 15njtab 15padre 16paphi
Unread 09-05-2018, 06:50 AM
cpapplefamily's Avatar
cpapplefamily cpapplefamily is online now
FRC #3244 (Granite City Gearheads)
Rookie Year: 2015
cpapplefamily is a splendid one to beholdcpapplefamily is a splendid one to beholdcpapplefamily is a splendid one to beholdcpapplefamily is a splendid one to beholdcpapplefamily is a splendid one to beholdcpapplefamily is a splendid one to beholdcpapplefamily is a splendid one to behold
I can count 3 connections between our RSL's and Roborio last year.
It makes sense in my mind.
Unread 09-05-2018, 08:27 AM
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
AKA: The Bearded ONe
FRC #2974 (WALT)
As an RI, I only look to see if your signal light is working. The inspection check list only requires that it be connected to the RSL signal port and work. The field people can disable you if the light stops working.
Unread 09-05-2018, 08:55 AM
GeeTwo's Avatar
GeeTwo GeeTwo is offline
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
We did something similar to this for 2016 STRONGHOLD because we needed to have two RSLs for full visibility.
[Quoting brennonbrimhall]: We design a new robot every year, but we can't forget that we also design a new team every year as folks come and go.
Unread 09-06-2018, 05:05 AM
Zagar's Avatar
AKA: Greg
Rookie Year: 2015
Thank you all for the replies.
This is as I thought. I didn't think it was an issue, but it was brought up in a discussion, and I wanted to get more opinions. As I read the rules myself, I see no variant of the interpretation as it stands. As long as the light works properly, consistently, securely and follows R71, it's up to you how to wire it.
Thanks!
Unread 09-06-2018, 10:22 PM
Chief Robot Inspector
Greg,
A few things to consider...
1. All electrical connections need to be insulated. That is a little more difficult with screw terminals.
2. A single run of wire has less chance for failure than multiple breaks/connections in the wire. Your mileage may vary.
Knowledge is power. Power UP!
Unread 09-07-2018, 05:34 AM
Zagar's Avatar
AKA: Greg
Rookie Year: 2015
Yeah, the screw terminals are insulated and take 26-20AWG, so definitely covered there, and with the screw terminals, I actually feel more confident with what I'm developing than the simple push on connector. Think of the power connector on the RIO, but not the terrible NI version.
Thanks Al,
Greg
Unread 09-09-2018, 11:33 AM
Greg,
The connector on the RoboRio is not an NI product. It however, approved for low voltage apps and the screw heads are recessed to provide some insulation. If your terminals are similar then that should be fine. However, these terminals are listed for specific wire size ranges. Often 14-18 gauge. Smaller wire will tend to pull out. You might try stripping the wire longer than normal, fold the excess back over itself to double or triple the diameter. This method in effect increases the wire size at the terminal and may give you amore reliable connection.
Unread 09-10-2018, 06:50 AM
Zagar's Avatar
AKA: Greg
Rookie Year: 2015
Yeah, I know. The power connector is a Phoenix product, which over my career, I've found to be a necessary evil in the controls world. I much prefer other manufacturer's equipment, but that's me.
And the block I was looking at is a Phoenix, and it's wire range is perfect for this application. Running 20AWG for the RSL is more than will ever be required.
Unread 09-10-2018, 10:07 AM
philso philso is online now
Greg,
Crimping a ferrule over the folded wire will ensure that it doesn't get squished and become "small" and slip out after the screw on the connector is tightened.
Unread 09-17-2018, 11:43 AM
David Ellers's Avatar
David Ellers David Ellers is offline
FRC #2451 (PWNAGE)
Rookie Year: 2016
David Ellers is an unknown quantity at this point
The Power Connector supplied on the rRio is not a Phoenix Contact product but rather a Sauro product. We replace the Power Connector with a Phoenix Contact Push-in Spring connector part number 1966091. We also ferrule the wire using a ferrule with a 12mm barrel length.
If you have found a plug connector for the RSI from Phoenix, I would be interested in the part number.
Unread Yesterday, 06:12 AM
Zagar's Avatar
AKA: Greg
Rookie Year: 2015
I do, and the next time I'm at the Center, I'll get it for you. I bought 5 or 10 of them, and I'm glad I did.
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
