Go to Post There were no heroes on the team, just everyone doing their part. - nuggetsyl [more]
Unread 03-10-2018, 09:38 PM
ChilliNerd's Avatar
ChilliNerd ChilliNerd is offline
AKA: Matt Gallant
FRC #6153 (Blue Crew)
Team Role: Leadership
Rookie Year: 2016
ChilliNerd is an unknown quantity at this point
Shuffleboard Crashing
My team is currently at a competition and we are having issue where Shuffleboard stops responding as soon as we plug in the FMS Ethernet. Does anybody know anything about this and potentially how to fix it?
Unread 03-10-2018, 10:10 PM
Peter Johnson Peter Johnson is offline
WPILib Developer
FRC #0294 (Beach Cities Robotics)
Peter Johnson has a brilliant futurePeter Johnson has a brilliant futurePeter Johnson has a brilliant futurePeter Johnson has a brilliant futurePeter Johnson has a brilliant futurePeter Johnson has a brilliant futurePeter Johnson has a brilliant futurePeter Johnson has a brilliant futurePeter Johnson has a brilliant futurePeter Johnson has a brilliant futurePeter Johnson has a brilliant future
Re: Shuffleboard Crashing
Things to try: remove graphs, turn off recording, restart it before you connect it. Grab the $HOME/shuffleboard/shuffleboard.log file when the problem happens (but before you restart Shuffleboard, as it’s overwrriten each run) and post it here. Since you’re at a competition, get a CSA to help!
Author of cscore - WPILib CameraServer for 2017+
Author of ntcore - WPILib NetworkTables for 2016+
Creator of RobotPy - Python for FRC
2010 FRC World Champions (294, 67, 177)
2007 FTC World Champions (30, 74, 23)
2001 FRC National Champions (71, 294, 125, 365, 279)
Unread 03-10-2018, 10:12 PM
SamCarlberg's Avatar
SamCarlberg SamCarlberg is offline
GRIP/Shuffleboard/WPILib. 2084 alum
FRC #2084
Rookie Year: 2010
SamCarlberg has much to be proud ofSamCarlberg has much to be proud ofSamCarlberg has much to be proud ofSamCarlberg has much to be proud ofSamCarlberg has much to be proud ofSamCarlberg has much to be proud ofSamCarlberg has much to be proud ofSamCarlberg has much to be proud ofSamCarlberg has much to be proud ofSamCarlberg has much to be proud of
Please post the contents of the log file at C:\Users\<username>\Shuffleboard\shuffleboard.log after connecting to the FMS
WPILib developer
GRIP, RobotBuilder, Shuffleboard
Unread 03-13-2018, 12:26 PM
ChilliNerd's Avatar
AKA: Matt Gallant
Rookie Year: 2016
Thank you all for your help.
We managed to figure out that our Shuffleboard configuration was corrupted. We deleted it and started from scratch. It now no longer crashes.
Unread 03-13-2018, 12:48 PM
rlance's Avatar
rlance rlance is offline
FRC #5550
rlance has a reputation beyond reputerlance has a reputation beyond reputerlance has a reputation beyond reputerlance has a reputation beyond reputerlance has a reputation beyond reputerlance has a reputation beyond reputerlance has a reputation beyond reputerlance has a reputation beyond reputerlance has a reputation beyond reputerlance has a reputation beyond reputerlance has a reputation beyond repute
When you get a chance can you post the steps you took to delete and start from scratch. We may need to do that also.
Unread 03-13-2018, 10:05 PM
cpapplefamily's Avatar
cpapplefamily cpapplefamily is offline
FRC #3244 (Granite City Gearheads)
Rookie Year: 2015
cpapplefamily is a name known to allcpapplefamily is a name known to allcpapplefamily is a name known to allcpapplefamily is a name known to allcpapplefamily is a name known to allcpapplefamily is a name known to all
Yes i would like to put these steps in my box of tricks. Please share the steps taken.
It makes sense in my mind.
Unread 03-14-2018, 12:02 PM
ChilliNerd's Avatar
AKA: Matt Gallant
Rookie Year: 2016
The save in located in your home folder/shuffleboard. I believe it is called shuffleboard.json. Just delete it and open Shuffleboard again. Now you should be able to add new widgets and save a new save file.
I also noticed that during my testing, cameras would lock up Shuffleboard for quite a while. If you wait it out though, they should eventually show up.
I hope this helps some other teams!
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
