Go to Post And then have FIRST throw a copy of the Atkins diet book in with each kit... - dlavery [more]
Unread 03-12-2018, 06:37 PM
kennethMiura kennethMiura is offline
FRC #1389
kennethMiura is an unknown quantity at this point
Current Limiting Victor SP
At our last event, we experienced frequent brownouts during matches, and would like to regulate current draw in order to stay out of brownout range. Currently, we are using the provided current limiting options for our Talon SRXs, and simply capping voltage application to our victors. Do you have any suggestions on a cleaner solution to regulate current draw on the victors?
Unread 03-13-2018, 08:12 PM
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Current Limiting Victor SP
You can read the current on each branch circuit from the PDP. If you react quickly enough, you can effectively limit the current supplied by any motor controller.
Unread 03-13-2018, 10:16 PM
Gabe5406's Avatar
Gabe5406 Gabe5406 is offline
AKA: Gabe Casciano
FRC #7013 (Techtronix)
Rookie Year: 2015
Gabe5406 will become famous soon enough
Just use a smaller auto reset fuse.
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
