Go to Post I don't remember ever having "attack of the jumbo ball" in FRC! - Beth Sweet [more]
Unread 03-13-2018, 01:00 AM
chrisrin chrisrin is offline
FRC #4915 (Spartronics)
Rookie Year: 2016
chrisrin is a splendid one to beholdchrisrin is a splendid one to beholdchrisrin is a splendid one to beholdchrisrin is a splendid one to beholdchrisrin is a splendid one to beholdchrisrin is a splendid one to beholdchrisrin is a splendid one to behold
how to introduce CNC & train the team?
Our team has a new mentor who is interested in expanding CAM on the team beyond the minimal 3D printing we do. We improve at CAD each year & have a full assortment of manual manufacturing machines + students who know how to use them. We even built our first fully functional 2nd robot this year (yes!).
As a fifth year team trying to continuously improve, it seems time to broaden our horizons to CNC. We have read through the excellent threads covering which machines are good - thanks to all who contributed to those.
My question here is not about what machine to buy. It is... What are some effective approaches, techniques, lesson plans, etc. for introducing a CNC machine to students and teaching them to use it? Step 1 clearly seems to be having a mentor who is willing to blaze the trail by being the first to learn, and we have that. What do teams who introduced CNC have to share about how to effectively get the team going with it?
Time on the machine seems like it could be important - would it be useful to have a couple inexpensive little CNCs to practice on with plastic? (for example)
Thanks in advance for your advice & suggestions.
Chris
Unread 03-13-2018, 01:12 AM
sanddrag sanddrag is offline
On to my 18th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Re: how to introduce CNC & train the team?
Not super useful to have smaller different machines. Small machines often bring more frustration than success. Stick to one machine and setup process.
Check out the Titans of CNC Academy. I think it's just what you need. There's a Facebook group as well.
Unread 03-13-2018, 08:16 AM
Cyberphil's Avatar
Cyberphil Cyberphil is offline
That Guy
FRC #0103 (Cybersonics), FRC 5666 (Purple Lightning)
Rookie Year: 2007
Cyberphil has a reputation beyond reputeCyberphil has a reputation beyond reputeCyberphil has a reputation beyond reputeCyberphil has a reputation beyond reputeCyberphil has a reputation beyond reputeCyberphil has a reputation beyond reputeCyberphil has a reputation beyond reputeCyberphil has a reputation beyond reputeCyberphil has a reputation beyond reputeCyberphil has a reputation beyond reputeCyberphil has a reputation beyond repute
It seems like you have already taken the first step: make sure students know how to setup and use conventional manual machines. This background and understanding will help immensely when making the step to a CNC machine. No machine shop I know throws a greenhorn right onto a 50K+ CNC machine, and your team should consider the same.
You may even want to create a training course and some kind of certification for the machine and only allow those with the certification to setup (non-certified students can maybe still run programs). The machine manufacturer may even have some of these courses at the ready and could possibly be willing to provide you with the material if you ask nicely.
A significant portion of your time is going to be spent determining the right speeds and feeds for your different tooling. There are many calculators online, as well as phone apps and dedicated software (some of them free as well). If you have a mentor familiar with CNC/CAM, you will be way ahead of the curve.
As a general rule (and something we have been slowly trying to teach our kids), use the shortest, most rigid tool you can for each application. Yeah, you may be able to get a lightening pattern on both sides of your 2 x 1 in one setup if you use a long endmill, but the tool will scream for mercy the entire time no matter what speeds and feeds you use. That vibration, known as chattering, is also absolutely horrible for tool life.
This should be known if your students already know how to use a manual machine, but if you are making repeated parts, rather than finding your zero after every part, use a vice stop. Over the course of the season this will likely save you hundreds of hours.
If you need a pattern on both sides of the part, consider using a program stop (M0) and having two separate parts of the program. Run one side, flip the part and push it against the endstop, and continue running. Be wary of the orientation of the part when you flip though.
My personal recommendation before jumping right into a CAM package like Fusion, HSM Works, or any of the others: Most machines have a conversational CAM portion to them where toolpaths are created on the machine itself. I highly recommend getting familiar with the machine using these conversational programs. Our team has found we can do about 75% of our milling and drilling using conversational, which saves a lot of time. Often we can more quickly write a conversational program and run it than we can make the piece on a manual mill.
Hope this helps a bit!
Unread 03-13-2018, 08:52 AM
mikeb3173's Avatar
mikeb3173 mikeb3173 is offline
AKA: Mike Buell
FRC #3173 (IgKnighters)
Rookie Year: 2011
mikeb3173 is an unknown quantity at this point
Thanks! Just the kind of resource I've been looking for.
Our team has a new Tormach mill which wasn't delivered in time for this seasons build. So it's still not completely assembled. I think that was actually fortunate because now we have a very high interest by the students in learning during the off season.
Unread 03-13-2018, 09:29 AM
Cyberphil's Avatar
That Guy
Rookie Year: 2007
We got our tormach last year and didn't use it during the 2017 season much either for similar reasons. Take some time in the offseason to figure it out a bit and then use the heck out of it next year. If you have any questions feel free to send me a PM.
Unread 03-13-2018, 11:24 AM
mikeb3173's Avatar
AKA: Mike Buell
Rookie Year: 2011
Cyberphil, Thanks I'll do that. I've taken your post and added that information to the post season review we'll be doing. Which ,unfortunately, will probably be ending this weekend at FLR.
Unread 03-13-2018, 11:44 AM
Kyle Warren's Avatar
Kyle Warren Kyle Warren is offline
FRC #2052 (knightkrawler)
Team Role: Mechanical
Rookie Year: 2017
Kyle Warren has a spectacular aura aboutKyle Warren has a spectacular aura about
we use the x carve CNC machine, it is good for cutting plates of aluminum and plastic because of the large work area.
Unread 03-13-2018, 12:26 PM
RoboChair's Avatar
RoboChair RoboChair is offline
He who fixes with hammers #tsimfd
AKA: Devin Castellucci
FRC #1678 (Citrus Circuits and 5458 Digital Minds)
RoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond repute
Seconded. I suggest Cut2D/Cut2DPro as a good starting point for CAM. Very cheap software with a good number of features and dirt simple to learn with.
And I swear I will be doing that video series on our router trainings this summer...
12 Years and counting! Over a third of my life has been spent with FRC.
Unread 03-13-2018, 12:31 PM
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
I tried running aluminum on my previous teams X-Carve but it had trouble getting it to hold a tolerance, plastic works pretty good though. Have you had any luck getting it to cut an actually round pocket on aluminum?
That said, I will concur with some of the other posters, knowing the manual versions of the machines is critical. Once you know that moving to CNC is much easier. Depending on your machine, if all you're doing is loading toolpaths from your CAD/CAM software, then learning the actual workflow should be quite simple, since you're basically taking the same steps as the manual machines and automating some of them. If you have a machine that allows manual input (creating toolpaths from the machine itself) and your goal is to teach that, then that can be a bit more of an involved process.
One thing you might try, if you have the budget, is get a "cheap" CNC like an X-Carve to practice on (since the consequences for screwing something up are much less) and once students are comfortable they can move up to a "big" CNC machine.
2005-2008: FRC 703 Phoenix - Robot Driver
2009-2016: FRC 703 Phoenix - Mentor
2017-????: FRC 5712 Gray Matter - Mentor
Unread 03-13-2018, 12:34 PM
asid61's Avatar
asid61 asid61 is offline
Design Simple
AKA: Anand Rajamani
FRC #1072 (Harker Robotics)
Rookie Year: 2013
Adding on to this, if you're looking at regular CNCs like the Tormach or a Haas, then Fusion 360 does pretty well. I lets you adjust almost all of the parameters that you want to and is very easy to get started with. Learning the basic g-codes before CAM is a good idea too; I went in without any g-code knowledge and it makes simple tasks like modifying code directly a lot harder.
Team 1072 2017-present
Team 299 2017
Team 115 2013-2016 (student)
2018 Davis Finalists (w/ 6474 and 3880), 2018 Roebling Winners (w/ 3476, 1323, and 1778)
Unread 03-13-2018, 12:45 PM
cbale2000's Avatar
AKA: Chris Bale
Inventor HSM also works quite well if you're already using Inventor, it's quite convenient to be able to make a model and then just change to a different tool tab and have all your CAM settings available in one place. It's also free for students.
Unread 03-13-2018, 12:56 PM
Big-b's Avatar
Big-b Big-b is offline
AKA: Bram
FRC #0900 (♞Zebracorns♞)
Team Role: CAD
Rookie Year: 2016
Big-b has a reputation beyond reputeBig-b has a reputation beyond reputeBig-b has a reputation beyond reputeBig-b has a reputation beyond reputeBig-b has a reputation beyond reputeBig-b has a reputation beyond reputeBig-b has a reputation beyond reputeBig-b has a reputation beyond reputeBig-b has a reputation beyond reputeBig-b has a reputation beyond reputeBig-b has a reputation beyond repute
Although I haven't used it much, so I can't say to its effectiveness, HSMWorks is the same software for Solidworks.
2018 NC District Forsyth Event Chairman's Award
2017 NC District Championship Winner
2017 NC District Raleigh Event Chairman's Award
"I've found from past experiences that the tighter your plan, the more likely you are to run into something unpredictable." - Angus MacGyver
Unread 03-13-2018, 01:02 PM
asid61's Avatar
Design Simple
AKA: Anand Rajamani
Rookie Year: 2013
It's not the same. I find Fusion to be much better than HSMworks for Solidworks. It recognizes inside/outside contours better, has a better 3D adaptive engine, and gives you access to some cut settings that HSMworks doesn't have (I forget exactly what though, it's been so long since I switched). Plus, no tabbing in the Solidworks version. Fusion > HSMworks for Solidworks, but I've heard the Inventor version is much better than the Solidworks one.
Team 299 2017
Unread 03-13-2018, 02:33 PM
72LML 72LML is offline
FRC #3184 (Blaze Robotics)
Rookie Year: 2015
72LML is on a distinguished road
Chris,
If you need (or anyone else for that matter) some help getting moving in the right direction or have any CNC questions feel free to send me a PM and Iíll send you my contact info. Iím located near Minneapolis, MN so I probably wonít be able to swing by your shop but I should be able to answer or at least find someone who knows the answer to most questions you have. I process and program parts on multiple CNC machines for my day job. We donít have any CNC equipment for our team (weíd love to just have a Bridgeport at this point) so I canít offer much advise on how to get the kids up to speed but all can say is take it slow. Prove out each program before cutting a part. Crashing a machine can be very expensive and it will happen sooner or later.
Nathan
Build Mentor
FRC Team #3184 Blaze Robotics
  #15   Spotlight this post!
Unread 03-13-2018, 09:37 PM
Rookie Year: 2016
Thanks all for the helpful responses. I have shared them with the mentor leading the CNC opportunity assessment effort.
Fingers crossed we end up going for it; we have a big group of highly engaged sophomores... if we invest in expanding CAM, by the time they're seniors, who knows what they'll be able to do.
--Chris
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
