Go to Post Kickoff features the joys of discovery. Ship date features the fear of utter failure. - Koko Ed [more]
Unread 03-13-2018, 06:50 PM
dragonriderx's Avatar
dragonriderx dragonriderx is offline
FRC #4611
dragonriderx is an unknown quantity at this point
Pigeon IMU Drift
Okay, so I know the pigeon experiences drift so we set up our rotate command to be based on relative degrees (If pigeon is at 250 degrees and we want to turn 90 then turn to 340). So there's some context now the problem.
Tell the pigeon to turn 180. Perfect. Rotate it back to the original orientation. Tell the pigeon to turn 180. Slightly left of where we want. Reset the bot.
Tell the pigeon to turn 180. Slightly more left. This continues and grows exponentially to the point where it becomes a problem. Any ideas what could be causing this?
Unread 03-13-2018, 07:13 PM
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
ozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond repute
Re: Pigeon IMU Drift
Please read section 8 - IMU Error Sources, in the Pigeon User's Guide. This will tell you how to diagnose which source of error and how to fix it.
Omar Zrien - CTR Electronics - Cross The Road Electronics - Chief Software/Owner
CTRE New products | CTRE/FRC Source Examples | FRC Installer (for Talon SRX and more)
Get Latest Updates on Facebook | Twitter
Unread 03-14-2018, 05:38 AM
thatnameistaken thatnameistaken is offline
AKA: Joshua Johnston
FRC #2191 (Flux Core)
Rookie Year: 2013
thatnameistaken has a brilliant futurethatnameistaken has a brilliant futurethatnameistaken has a brilliant futurethatnameistaken has a brilliant futurethatnameistaken has a brilliant futurethatnameistaken has a brilliant futurethatnameistaken has a brilliant futurethatnameistaken has a brilliant futurethatnameistaken has a brilliant futurethatnameistaken has a brilliant futurethatnameistaken has a brilliant future
In addition - while section 8 touches upon this, I highly recommend you go through the temperature calibration procedure if you haven't already. It helps eliminate most drift.
Unread 03-14-2018, 08:18 AM
JamesCH95's Avatar
JamesCH95 JamesCH95 is online now
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
JamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond repute
We measured 3 of drift over 5 minutes with our recently-installed IMUs, I don't think that drift is your issue.
Your turning routine no doubt has a tolerance on each turn. Say that's 1. Every time you reset the robot's position you can add up to 1 of error. I don't think that you should be resetting position over and over because you're accumulating this tolerance each time that you reset. Eventually it becomes too much to deal with.
Theory is a nice place, I'd like to go there one day, I hear everything works there.
Maturity is knowing you were an idiot, common sense is trying to not be an idiot, wisdom is knowing that you will still be an idiot.
Unread 03-14-2018, 09:13 AM
philso philso is offline
Mentor
philso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond repute
Is your bot returning to the starting position via software commands or are you moving it "by hand"? If you are moving it by hand, how consistent is your starting position?
Unread 03-14-2018, 04:07 PM
Rookie Year: 2013
This is almost definitely it. If you perform temperature calibration, the drift is small enough to ignore; this would be better than using relative coordinates.
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
