Go to Post People do amazing things for stuff the have a passion for. - Foster [more]
Unread 02-06-2018, 01:55 AM
cogbrained3244 cogbrained3244 is offline
D'Lux Cru
FRC #3244 (Granite City Gearheads)
Team Role: Webmaster
Rookie Year: 2012
cogbrained3244 is an unknown quantity at this point
Question Using Network Tables with Arduino?
My team is considering adding some LEDs this year. We have an Arduino Ethernet and an individually addressable LED strip controlled by FastLED, but we are fairly new to Arduino development and anything beyond Java in general.
We'd like to consider using Network Tables to control our lights so that they can easily respond to various conditions on our robot or on the field. However, I can't find any examples of how to do this, other than a few passing mentions on Cheif Delphi itself. Has anyone done it this way who has an example code that works?
If not, I'm curious what it would take to port the Network Tables library from WPILib to work on Arduino, or might it even work out of the box? Failing that we would fall back to something like I2C communication with the Arduino.
Unread 02-06-2018, 09:47 AM
codetheweb's Avatar
codetheweb codetheweb is offline
AKA: Max Isom
FRC #3299 (The Warehouse Crew)
Rookie Year: 2014
codetheweb is an unknown quantity at this point
Re: Using Network Tables with Arduino?
I don't have a ton of experience with Network Tables, but I would discourage you from trying to use them on an Arduino. Porting the code would likely take a while, and my team personally has had many issues with Network Tables in the past. I2C works really well.
Unread 02-11-2018, 07:07 PM
auscompgeek's Avatar
auscompgeek auscompgeek is offline
AKA: David Vo
FRC #4774 (The Drop Bears)
Rookie Year: 2017
auscompgeek is an unknown quantity at this point
Given that Arduinos don't have a full TCP/IP stack (and even then, you need one of those networking modules), you're going to have a really bad time trying to port NetworkTables to an Arduino.
Unread 02-12-2018, 07:58 PM
Sky Captain's Avatar
Sky Captain Sky Captain is offline
Software Mentor and FIRST Volunteer
AKA: Will
FRC #0386 (Voltage)
Sky Captain is an unknown quantity at this point
Check out this thread. I tackled the same issue this season.
When in doubt, RTFM.
Unread 02-13-2018, 03:16 PM
fovea1959's Avatar
fovea1959 fovea1959 is offline
Herder of programmers
AKA: Doug Wegscheid
FRC #3620 (The Average Joes)
Rookie Year: 2011
fovea1959 will become famous soon enough
If you really want to use the Arduino ethernet, doing UDP between the roboRIO and the Arduino should be straightforward.
You will probably want to go to static IP addresses, though!
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
