Go to Post Be thankful for what you have, not frustrated with it because it doesn't exactly suit your needs. - sanddrag [more]
Unread 02-10-2018, 02:00 PM
csulzbach's Avatar
csulzbach csulzbach is offline
FRC #2404 (tnt)
Rookie Year: 2015
csulzbach is an unknown quantity at this point
Has anyone found a good scouting app for iPhone ?
Has anyone found a good, updated scouting app for the 2018 Powerup game that works on iPhones or a good scouting sheet ?
Unread 02-12-2018, 08:12 AM
cassirole4103's Avatar
cassirole4103 cassirole4103 is offline
FRC #4103 (Roborioles)
Team Role: Scout
Rookie Year: 2016
cassirole4103 is a splendid one to beholdcassirole4103 is a splendid one to beholdcassirole4103 is a splendid one to beholdcassirole4103 is a splendid one to beholdcassirole4103 is a splendid one to beholdcassirole4103 is a splendid one to behold
Re: Has anyone found a good scouting app for iPhone ?
FRC Spyder? It's not an app that you can input values into, but it will show the schedule and the teams within each competition. I found it really helpful to use if for scouting setup before competition begins. It will also update and show score and other info. I don't know if it is updated for 2018 yet (or if it will), but I used it last year for set up!
If you have the resources, you could create an app for your self. We are using Kindle Fires and Android Studio to do scouting this year. We have a paper/pencil version. If you want to see it, just DM me!
Unread 02-12-2018, 10:00 AM
Yossarian's Avatar
Yossarian Yossarian is offline
"Anything can happen"- 2708, 2018
AKA: Jordan
FRC #2708 (Lake Effect Robotics)
Rookie Year: 2015
Yossarian is a jewel in the roughYossarian is a jewel in the roughYossarian is a jewel in the rough
We make our own app every year, although it's on android. I recommend making an excel template for all the information you want, then print it out for the scouts to fill out during the match.
Unread 02-12-2018, 10:57 AM
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
Team Role: Teacher
Rookie Year: 2011
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
We've done Excel sheets during competition before. Bit of a pain copying over data from one computer to another at the end of the day.
Paper is easiest to set up, but a real pain to consolidate.
Last year we used AppSheet to turn google forms into on-device apps. Works with Android and iOS.
CD search for appsheet: https://www.chiefdelphi.com/forums/s...archid=8791312
You can set up the app to allow for photos (great for pit scouting), live summaries of certain data, and download it all as a spreadsheet later.
Issue: it uses data to update live (But you can set the app up to do a delayed synch), and it costs money (think it was $10/month for unlimited users)
2013-present: FRC Team 4276, Surf City Vikings
2011-2012: FRC Team 3677, The Don Bots
Unread 02-12-2018, 05:43 PM
ScoutingFRC ScoutingFRC is offline
ScoutingFRC is an unknown quantity at this point
We have a website called ScoutingFRC.com where you can export data in a CSV format for analysis in Excel. We also have a page where you can see live stats for teams(useful for drive team strategies!).
Unread 02-13-2018, 12:39 PM
darajaco's Avatar
darajaco darajaco is offline
Just a College Kid
AKA: Jacob Dara
FRC #7226 (Error 404)
Rookie Year: 2012
darajaco is a jewel in the roughdarajaco is a jewel in the roughdarajaco is a jewel in the roughdarajaco is a jewel in the rough
Personally I've found that paper scouting sheets are almost always easier than an app. Apps I've used in the past have ended up having sharing issues with files and don't have much in the way of flexibility when it comes to pit scouting notes and what not. With paper sheet you can design them in excel however you want, and can write notes in the margins. The printing process can be a bit of a pain but it's half an hour to an hour of prep for each event (if you do it right) and then you're good to go.
Unread 02-13-2018, 02:13 PM
jlmcmchl jlmcmchl is offline
FF - The Breakfast Company
AKA: Jordan McMichael
FRC #0027 (Team RUSH 27)
Rookie Year: 2011
jlmcmchl has much to be proud ofjlmcmchl has much to be proud ofjlmcmchl has much to be proud ofjlmcmchl has much to be proud ofjlmcmchl has much to be proud ofjlmcmchl has much to be proud ofjlmcmchl has much to be proud ofjlmcmchl has much to be proud of
If you literally just need a scouting system, paper -> manual input into an excel sheet is about as rudimentary as it gets, but you might lose some reliability with manually inputting every robot's performance over and over. (it's tedious).
But, that's not your goal here. The more you automate the system, the more consistent it's going to be, and the better the data that you'll get.
Apps like FRC Spyder + The Blue Alliance's website will give you a lot of information about the field and matches at a high level, but nothing in by-robot detail. For a rudimentary pick list, you can't do much better.
I'd recommend looking into a platform-independent scouting app (e.g. a webpage) that creates a csv or other file that you can import into excel. There's a few that have been advertised in the Scouting subform that should fit your use case
Good luck!
Field reset: '13 - '16, Einstein '16!
Referee: '15 - '18
2018: Kettering #1, Centerline, Lincoln/Milford, Midland, Troy, Marysville, MICMP, Houston, Detroit!
Unread 02-13-2018, 02:17 PM
michaelwm's Avatar
michaelwm michaelwm is offline
UWRi3D | uwri3d.com
AKA: Michael Midura
FRC #4976 (Revolt Robotics)
Rookie Year: 2010
michaelwm is just really nicemichaelwm is just really nicemichaelwm is just really nicemichaelwm is just really nicemichaelwm is just really nice
I'll be making a version of my old team's scouting app, https://github.com/michaelwm/scoutworks-forms for FIRST POWER UP. It's written in Xamarin Forms so it's available iOS and Android version. It's not the prettiest app but my team loved using it, and hopefully you find the POWER UP version useful (once it's out!)
Unread 02-16-2018, 11:15 PM
csulzbach's Avatar
FRC #2404 (tnt)
Rookie Year: 2015
Thank you for all the reply's but we are just gonna use paper scouting sheet we are way behind and dont have time.https://docs.google.com/document/d/1...it?usp=sharing
Unread 03-01-2018, 09:56 PM
RedLeader342's Avatar
RedLeader342 RedLeader342 is offline
Fabrication/Drive Coach
AKA: Justin White
FRC #0342 (Burning Magnetos)
RedLeader342 is just really niceRedLeader342 is just really niceRedLeader342 is just really niceRedLeader342 is just really niceRedLeader342 is just really nice
i usually like the frc tracker by idle loop software. however they have said 2018's is having some technical difficulties that may prevent it from coming out until even week 2 this year.
but it allows you to have all the blue alliance scouting data and add pictures through the photo share. also has match schedules and such.
this app is only on ios however
2009-Mechanical and Scouting student,342
2010~12-Mechanical, Fabrication, Operator,342
2012~13- Fabrication Mentor,3196
2013~Present- Fabrication/Drive Coach, 342
Unread 03-04-2018, 04:53 PM
Oreste's Avatar
Oreste Oreste is offline
AKA: Jonathan Oreste Maruca
FRC #3990 (Tech 4 Kids)
Rookie Year: 2014
Oreste is an unknown quantity at this point
We have an app called Tech Scouting where you can do Pit Scouting and normal scouting. It then gives you a QR code that represents all the info entered. You can then pair this with an Excel spreadsheet to quickly analyse all your information.
Unread 03-04-2018, 06:51 PM
samthesnake's Avatar
samthesnake samthesnake is offline
SamD4256
AKA: Sam Dare
Team Role: CAD
Rookie Year: 2015
samthesnake has much to be proud ofsamthesnake has much to be proud ofsamthesnake has much to be proud ofsamthesnake has much to be proud ofsamthesnake has much to be proud ofsamthesnake has much to be proud ofsamthesnake has much to be proud ofsamthesnake has much to be proud ofsamthesnake has much to be proud of
FAST is available for beta testing. We will be using it over the next two weeks at competition.
"Perfection is not attainable, but if we chase perfection we can catch excellence." - Vince Lombardi
2015 - 2018 FRC Team 4256, Cyborg Cats
CAD and Strategy lead, drive coach
Unread 03-07-2018, 04:53 PM
mswhite60's Avatar
mswhite60 mswhite60 is offline
AKA: Matt
FRC #5675 (WiredCats)
Rookie Year: 2016
mswhite60 is a name known to allmswhite60 is a name known to allmswhite60 is a name known to allmswhite60 is a name known to allmswhite60 is a name known to allmswhite60 is a name known to all
Another vote for AppSheet! It is very easy to use to create iPhone and Android apps and it automatically assembles all your student's data in one Google Sheet. Basically you create a Google Sheet with all the columns of data needed, point AppSheet at it and it makes the app. You can then tweak it to add buttons, drop-downs, etc.
For use at competitions we use the Premium version which queues up data and loads it to the cloud when each phone has a signal...very important!
This premium license costs $5 per month per user, but if you ask appsheet for the Nonprofit discount it is only $2.50 per month per user. We use it for March and April only.
A partial peek at ours: If Y is tapped on the climb questions, for instance, a 2nd question comes up asking HOW they did it.
Matt
Unread 03-07-2018, 06:03 PM
BordomBeThyName's Avatar
BordomBeThyName BordomBeThyName is offline
AKA: Matt Golman
FRC #2102 (Team Paradox)
Rookie Year: 2007
BordomBeThyName has a reputation beyond reputeBordomBeThyName has a reputation beyond reputeBordomBeThyName has a reputation beyond reputeBordomBeThyName has a reputation beyond reputeBordomBeThyName has a reputation beyond reputeBordomBeThyName has a reputation beyond reputeBordomBeThyName has a reputation beyond reputeBordomBeThyName has a reputation beyond reputeBordomBeThyName has a reputation beyond reputeBordomBeThyName has a reputation beyond reputeBordomBeThyName has a reputation beyond repute
I know the OP has already opted for paper scouting, but 2102 has an app called RoboRecon that's being presented at Houston Champs for the second time this year.
Here's the link to our site, which has downloads and instructions.
It can compile pit scouting, scouting from the stands, and Blue Alliance data into whatever tables and graphs you want, and it's compatible with computers, tablets, and phones.
Founder -> Build VP -> President -> Drive Team Mentor -> Strategy and Mechanical Mentor
  #15   Spotlight this post!
Unread 03-12-2018, 05:19 PM
SpookyWire's Avatar
SpookyWire SpookyWire is offline
I only ride segways.
AKA: Callie
FRC #5498 (Wired Devils)
Team Role: Leadership
Rookie Year: 2016
SpookyWire is a jewel in the roughSpookyWire is a jewel in the roughSpookyWire is a jewel in the roughSpookyWire is a jewel in the rough
IMO, paper is always the solid way to go. Pit scouting sheets are a nice way to assess robot ability before competition, and match scouting sheets are great for analyzing future alliances/final partnerships. This year we're trying out a new method with the match sheets where we'll have one scout watch one robot every round, and have them all bring it back to our scout lead every few matches to put in a spreadsheet. This way we get a nice set of data on our robot and others to see where we compliment one another or if we're just loading up on more of the same skill. We're hoping to see how well this will work at this week's Lincoln competition.
Paper + Excel = Easy and Efficient
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
