OCCRA
Go to Post CNC machine, Something every FIRST kid wants in their bedroom :) - David Kelly [more]
CD-Media
Unread 02-11-2018, 08:42 PM
pKlopp pKlopp is offline
FRC #0100 (The WildHats)
Team Role: Mechanical
Rookie Year: 2017
pKlopp is on a distinguished road
Climbing with elevator
We are coming upon the last week of build season and our robot it CAD is drastically overweight. At this rate we will come out at least 10 lbs over, maybe much more than that. Right now we have a separate climber subsystem and elevator subsystem. The easiest way to come out underweight is completely scrap the climber. Any thoughts on the strategic viability of this? The original thoughts behind climbing with a separate subsystem to the elevator was that we didn't want to tweak our elevator and remove our ability to score on the scale, which is a major part of our strategy. At this point however, Iím skeptical that we are actually risking much of anything by climbing with the elevator. I can see where some of my team members are coming from, eliminating the climber, our most problematic subsystem would free up a bunch of time to finish up fabrication on other subsystems. Our options the way that I see it are, kill the climb, forget about the climber for now and hope we come out enough underweight to bring it to your first competition, or climb with the elevator. In a minute I will post a picture of our elevator bearing setup in CAD. The two side bearings, which take most of the load are mounted on ľ-20s. The other bearings are mounted on a 10-32. To me, this seems robust enough to withstand the forces of a climbing robot, but others on my team have expressed some concern. The elevator itself is made out of 2 x 1 1/16th wall aluminum extrusion.
Unread 02-11-2018, 09:10 PM
Ethan Pui
Posts: n/a
Re: Climbing with elevator
The only concern that I would have in terms of having your elevator mech the same as your climber, is if you damaged your bot during climb your main mech will probably be affected resulting in your bot being useless, this can be thought as happening the other way also( if you damaged your elevator you can't climb.)
Unread 02-11-2018, 09:38 PM
Billfred's Avatar
Billfred Billfred is offline
Never look back, no, never say die
AKA: Always attack with the warrior's cry...
FRC #1293 (Pandamaniacs); FTC #11444 (Garnet Squadron) (Also, CD mod.)
I don't know the particulars of your design, but if you aren't sure why risk it if you don't have to? Letting the elevator secure a hook that detaches (think velcro) and then gets winched in lets the load go through your cable/rope/strap instead. And while that adds some weight compared to using the elevator, a DeCIMate-to-Toughbox-Micro setup on the winch* should still shave some weight off compared to a full separate climber system.
*Yes, there are alternatives I'm sure you can concoct. Yes, our winch was specced out by someone who used to work at AndyMark. But we didn't trust a dual-775-to-VersaPlanetary arrangement for something with loads this high, and AndyMark doesn't rate the 57 Sport for a DeCIMate. The TB Micro is bigger in two dimensions and heavier, but it's well-characterized and that counts for a lot.
William "Billfred" Leverette - Gamecock/Jessica Boucher victim/Owner/Director of Bricks 4 Kidz in Columbia, SC.
2017: FRC 5402 (Iron Kings) - Mentor, Coach (oh, and I worked at AndyMark during this time)
2018-: FRC 1293 (Pandamaniacs) - Mentor
114 events (more than will fit in a ChiefDelphi signature), 15 seasons, over 74,500 miles, and still on a mission from Bob.
Unread 02-11-2018, 09:53 PM
mrnoble's Avatar
mrnoble mrnoble is offline
teacher/coach
FRC #1339 (Angelbotics)
Team Role: Coach
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
Billfred, the main issue my team ended up with for the velcroed carabineer idea was keeping the slack cable out of the way before engaging in the climbing winch. We ended up (for now) attaching our climbing hook to our carriage and intake, knowing that the connection point is robust and that loads will travel nearly straight down. We will see if any grand ideas come to light after our week one event, and maybe implement them for week four. I don't know the OP's design at all, but sometimes this idea is the simplest solution.
http://www.angelbotics.com
Remember why you're doing this.
Unread 02-11-2018, 10:18 PM
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
A word of caution on the use of Velcro to secure the hook to the elevator:
Yes, it's been used before.
Yes, I've seen some successful implementations.
Yes, I have seen the hook detach from the robot frame and drag all over the field on other implementations. See also: G05 and/or other possible rules violations.
Your setup sounds similar to an old robot I worked on... or one before that that I don't have a photo of. (Thicker aluminum on the pictured bot--1/8" thick channels instead of 1/16".) I would think that you could get by with a large hook bolted to the top of the lift--exact design up to you.
Past teams:
2003-2007: FRC0330 BeachBots; 2008: FRC1135 Shmoebotics; 2012: FRC4046 Schroedinger's Dragons
Unread 02-11-2018, 10:45 PM
Rookie Year: 2017
We looked at attaching hooks to the elevator, but we ran into the rope slack issues as mentioned above. Right now what we have is an arm that swings up of the back of our elevator to deliver a velcroed hook to the rung. It’s a robust concept but we need to lose weight and fast.
Sent from my iPhone using Tapatalk
Unread 02-12-2018, 12:11 AM
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
Originally Posted by pKlopp View Post
We looked at attaching hooks to the elevator, but we ran into the rope slack issues as mentioned above. Right now what we have is an arm that swings up of the back of our elevator to deliver a velcroed hook to the rung. It's a robust concept but we need to lose weight and fast.
What about using the elevator itself to climb? Don't release the hook, build it into the elevator.
Past teams:
Unread 02-12-2018, 07:53 AM
edm918 edm918 is offline
FRC #5945 (Absolute Control)
Team Role: Driver
Rookie Year: 2014
edm918 is an unknown quantity at this point
How heavy is your climber?
Unread 02-12-2018, 09:43 AM
OwenD's Avatar
OwenD OwenD is offline
AKA: Owen Dray
FRC #2067 (Apple Pi)
Team Role: CAD
Rookie Year: 2016
OwenD is a splendid one to beholdOwenD is a splendid one to beholdOwenD is a splendid one to beholdOwenD is a splendid one to beholdOwenD is a splendid one to beholdOwenD is a splendid one to behold
Unless you want a pretty slow lift, you will probably want a two speed gearbox. I do think it is a good idea to reduce weight.
Unread 02-12-2018, 09:56 AM
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is offline
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Daniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond repute
Send a message via MSN to Daniel_LaFleur
Why a 2 speed gearbox?
You can get a good sub-5 second start-to-finish climb with a single speed gearbox.
"We are not now that strength which in old days moved earth and heaven; that which we are, we are;
One equal temper of heroic hearts, Made weak by time and fate, but strong in will
To strive, to seek, to find, and not to yield. "
- Tennyson, Ulysses
Unread 02-12-2018, 10:00 AM
OwenD's Avatar
AKA: Owen Dray
Team Role: CAD
Rookie Year: 2016
You can lift the cubes with a much lower ratio compared to climbing, so in order to not limit yourself to only the higher ratio that climbing requires, you would want a two speed. If you are fine with lifting the cubes slower then you can get away with a single speed.
Unread 02-12-2018, 02:29 PM
s-neff's Avatar
s-neff s-neff is offline
AKA: Sam
FRC #0841 (Biomechs)
s-neff has a reputation beyond reputes-neff has a reputation beyond reputes-neff has a reputation beyond reputes-neff has a reputation beyond reputes-neff has a reputation beyond reputes-neff has a reputation beyond reputes-neff has a reputation beyond reputes-neff has a reputation beyond reputes-neff has a reputation beyond reputes-neff has a reputation beyond reputes-neff has a reputation beyond repute
You can keep independent gearboxes and still mount the hook on the elevator.
Here's one method:
Last year... Did you see how 254 & others took up slack in their climbing ropes?
There would be a ~10-12" section of flat climbing webbing, sewed to a 6"-8" section of flat elastic. When slack, the loop would be pulled together. When taut, the climbing rope would stretch out to full length before taking load.
You could put a hook on your elevator, and run an elastic + climbing webbing system like that to keep your slack out of the way during ordinary operations. Once you're ready to climb, place the hook, deactivate your regular elevator motor & winch up on your climbing gearbox.
You'll still want a thin lexan shield or something to keep it from flapping into your elevator, but it all still sounds a lot lighter than an entire second arm...
If you want to disconnect the hook from the elevator during climbing... consider an active (pneumatically driven) release...
(841 is currently running a 2-speed elevator gearbox with the hope of climbing on our elevator without losing 1-second cube placement. We'll see how it goes.)
Mentor - Team 841 (2015 - ? )
Mentor - Team 4 (2013 - 2014)
Student - Team 192 (2009 - 2010)
"Remember why you're doing this." -mrnoble
Unread 02-12-2018, 02:34 PM
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
In high gear we can go bottom-to-top with a cube in (theory) about a second.
In low gear we can hold the robot indefinitely, stalling the 775's at somewhere between 1.5V and 2V.
That is why we chose a 2-speed (2x775's through a decimate to a AM SS) for ours.
1885: YouTube | CAD Library
Unread 02-12-2018, 02:51 PM
s-neff's Avatar
AKA: Sam
That'll work great until the robots are disabled at the end of the match... are you putting a mechanical lock somewhere on it too?
  #15   Spotlight this post!
Unread 02-12-2018, 02:54 PM
JohnFogarty's Avatar
JohnFogarty JohnFogarty is offline
R I P Georgia Dome
FRC #1102 (M'Aiken Magic & Team FUN)
JohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond repute
You don't have to stay above the line after T-0.
John Fogarty - 13 Years in FIRST - http://cceti.com
FLL 1102 -> FTC 3864/1102 | FRC 1102 -> FRC 1772 -> FRC 4901 -> FRC 5632 | FTC 11444 -> FRC 1102 | VRC 5817
Head Coach - FRC Team 1102 M'Aiken Magic
"By teaching students the power of STEM, we're M'Aiken Magic happen!"
2010 FTC World Championship Winner - FTC Team 3864 Driver/Captain
Powered by vBulletin®
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
