OCCRA
Go to Post It's not hard, it just requires thought. - Matt Leese [more]
Unread 02-12-2018, 11:04 PM
ozdave ozdave is offline
FRC #6072 (Triton Tech)
Rookie Year: 2017
ozdave is an unknown quantity at this point
Using Talon closed loop position mode
Hi
We are using motion profiling to move elevator to position, but then want to hold position once there.
We are setting the Talon into ControlMode.Position, using this code:
Code:
        double curPosn = mTalon.getSelectedSensorPosition(0);
        mTalon.set(ControlMode.Position, curPosn);
The talon seems to be holding, but we can move the elevator away from this point and it does *not* go back.
Have we misunderstood the Position mode, or are we doing soemthing incorrect?
Regards
David
Unread 02-12-2018, 11:13 PM
nickbrickmaster nickbrickmaster is online now
AKA: Nick Schatz
no team (3184 Alum)
Rookie Year: 2014
nickbrickmaster has a reputation beyond reputenickbrickmaster has a reputation beyond reputenickbrickmaster has a reputation beyond reputenickbrickmaster has a reputation beyond reputenickbrickmaster has a reputation beyond reputenickbrickmaster has a reputation beyond reputenickbrickmaster has a reputation beyond reputenickbrickmaster has a reputation beyond reputenickbrickmaster has a reputation beyond reputenickbrickmaster has a reputation beyond reputenickbrickmaster has a reputation beyond repute
Re: Using Talon closed loop position mode
Have you tuned the PID constants? It won't apply any gain to reduce the error from that position if your PID constants are zero.
The Talon SRX Software Reference Manual has a guide on tuning position PID. You should also get a little bit of theoretical background on PID before you jump into it. The FRC-PDR site has a good intro here.
This is a postmodern signature.
Unread 02-13-2018, 12:29 AM
soundfx's Avatar
soundfx soundfx is offline
AKA: Aaron J
FRC #3238 (Cyborg Ferrets)
Rookie Year: 2014
soundfx will become famous soon enough
Code:
Assuming that this code is called in some forum of periodic loop, your code is repeatedly setting the target position at whatever the current position is, meaning that there is never any error calculated. You need to set one position that you calculate as your target, store it as a variable, and don't change it until you want to move again.
"I got 99 problems but 0.999 ain't 1."
~Orteil
Unread 02-13-2018, 12:49 AM
Rookie Year: 2017
Thanks for the responses
@nick - yes, we have been playing with kP, other params are 0. Possible we have not moved kP far enough - will be more adventurous tomorrow.
@soundfx - good thought, but the code is only being called once, when the motion profile is completed. We are attempting to switch form motion profile mode to hold position mode. Should we in fact be calling the set repeatedly?
Unread 02-13-2018, 08:45 AM
rlance's Avatar
rlance rlance is offline
FRC #5550
rlance has a reputation beyond reputerlance has a reputation beyond reputerlance has a reputation beyond reputerlance has a reputation beyond reputerlance has a reputation beyond reputerlance has a reputation beyond reputerlance has a reputation beyond reputerlance has a reputation beyond reputerlance has a reputation beyond reputerlance has a reputation beyond reputerlance has a reputation beyond repute
We are using the Talon Magic Motion feature to get our elevator to a position. I'm pretty sure we have the P and K set to .2 and I and D set to 0 and it seems to work pretty well. We have a CIM with a 25:1 versaplanetary gearbox moving it.
Unread 02-13-2018, 11:48 AM
Rookie Year: 2017
@rlance - thanks for the reply
Does the system hold position once it reaches it?
The issue we are concerned with is holding the position of the elevator steady once the target position is reached.
Unread 02-13-2018, 11:54 AM
firecrafty's Avatar
firecrafty firecrafty is offline
AKA: Ryan Blue
FRC #1018 (Pike RoboDevils)
Rookie Year: 2016
firecrafty is a splendid one to beholdfirecrafty is a splendid one to beholdfirecrafty is a splendid one to beholdfirecrafty is a splendid one to beholdfirecrafty is a splendid one to beholdfirecrafty is a splendid one to beholdfirecrafty is a splendid one to beholdfirecrafty is a splendid one to behold
Does the last point in your motion profile have isLast set to true? Setting isLast to true will make the Talon hold the final point (the point marked isLast) until you tell it not to.
"Programming is a science. Writing beautiful code is an art."
Any views I express are my own and do not necessarily reflect those of my team.
Unread 02-13-2018, 11:57 AM
Rookie Year: 2017
That is interesting - did not realize that. Yes, we have it marked as isLast.
Following the examples on GitHub, we had been changing the mode of the talon at the end of the profile. So do you just leave it alone?
We will test this later today.
Unread 02-13-2018, 12:19 PM
AKA: Nick Schatz
no team (3184 Alum)
Rookie Year: 2014
Have you looked at the Talon self-test mode to determine if it is in fact in position mode, what error it is seeing, and what, if at all, output it is giving?
Unread 02-13-2018, 12:21 PM
Rookie Year: 2017
You mean via the web interface? No had not tried that - will do so. Thanks
So your understanding is that it should maintain position against disturbance, without us repeatedly calling?
Unread 02-13-2018, 01:54 PM
rlance's Avatar
FRC #5550
Yes, it holds the position. It is possible that our elevator weight or gearing or friction helps with that because when power is cut to the system it lowers on its own at a fairly slow pace.
Unread 02-13-2018, 01:59 PM
Rookie Year: 2017
Thanks - will let you know how we go
Unread 02-15-2018, 02:18 PM
tonypan tonypan is offline
AKA: Minxing Pan
FRC #3175 (Knight Vision)
Rookie Year: 2016
tonypan is an unknown quantity at this point
My team is trying to use Talon SRX and manetic Encoder to control the scissor lift in a position close loop. The encoder can send the position correctly through the smart dashboard and the talon can drive normally as well. But the set(ControlMode.position, targetPosition) function will not move.
Code:
		 * Scissor lift on POV levels POV 0: loweest (pick up, vault running) POV 90:
		 * switch level POV 180: scale (highest 6ft) POV 270: climb
		if (operator.getPOV() == 0) {
			leftScissor.set(ControlMode.Position, 0);
			SmartDashboard.putString("Scissor Lift", "Ground Level");
		} else if (operator.getPOV() == 90) {
			leftScissor.set(ControlMode.Position, SWITCH * 4096.0);
			SmartDashboard.putString("Scissor Lift", "Switch Level");
		} else if (operator.getPOV() == 180) {
			leftScissor.set(ControlMode.Position, SCALE * 4096.0);
			SmartDashboard.putString("Scissor Lift", "Scale Level");
		} else if (operator.getPOV() == 270) {
			leftScissor.set(ControlMode.Position, CLIMB * 4096.0);
			SmartDashboard.putString("Scissor Lift", "Climb Level");
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
