Go to Post We honor those who are unsung - those without a trophy or a plaque to show their efforts. Those who may or may not get those things... but will still be on the sidelines, helping to guide FIRST in all the right directions. - Amanda Morrison [more]
Unread 02-13-2018, 09:23 AM
TLHPoE TLHPoE is offline
AKA: Kavin Phan
FRC #6750 (Pack Attack)
Rookie Year: 2017
TLHPoE is an unknown quantity at this point
Theoretical Method For Tank Rotation
Our robot's chassis has 3 wheels on each side in a basic tank configuration (minus the treads). I'm trying to find the number of rotations the wheels would have to move to rotate the entire robot a certain angle, assuming both sides spin opposite of each other to do so. I know I could just count the rotations using an encoder by starting the counter and then rotate the robot manually, but I'm asking if there is a way to look for the number using math instead of trials.
I'm sure there's a simple method to my problem, but I'm having trouble wrapping my head around it.
Unread 02-13-2018, 09:29 AM
JamesCH95's Avatar
JamesCH95 JamesCH95 is offline
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
JamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond repute
Re: Theoretical Method For Tank Rotation
Each wheel is moving in an arc centered along your chassis rotational axis (affected by wheel type, weight distribution, and wheel location). You just need to calculate the arc length each wheel will move.
My guess is:
r=1/2*track
Θ=90
assuming your turning center is located midway between your center wheels.
Theory is a nice place, I'd like to go there one day, I hear everything works there.
Maturity is knowing you were an idiot, common sense is trying to not be an idiot, wisdom is knowing that you will still be an idiot.
Yossarian's Avatar
Yossarian Yossarian is offline
"Anything can happen"- 2708, 2018
AKA: Jordan
FRC #2708 (Lake Effect Robotics)
Rookie Year: 2015
Yossarian is a jewel in the roughYossarian is a jewel in the roughYossarian is a jewel in the rough
My team uses almost the exact same configuration.
However
We use a Gyroscope for the Rio to measure this sort of thing. There are many different kinds of gyros to buy for the Rio, with varying degrees of difficulty.
Unread 02-13-2018, 09:51 AM
BenBernard's Avatar
BenBernard BenBernard is offline
Programming and Controls Mentor
FRC #5687 (The Outliers)
Rookie Year: 2015
BenBernard will become famous soon enoughBenBernard will become famous soon enough
I strongly recommend using a gyro (eg, navX) for this. You'll get MUCH better results with a gyro, and they're not terribly hard to integrate.
If you really can't switch to a gyro at this point, you can get the values empirically by logging the encoder counts to smartdashboard and turning your robot as described. If you do the logging in periodic() you can turn manually without even enabling the robot.
AKA: Kavin Phan
Rookie Year: 2017
My guess is:
r=1/2*track
Θ=90
Ah, yeah I get it now. It's just the wheel circumference into the length of the arc, with the degrees desired equal to the arc length over the circumference of the circle between the two center wheels.
As for the gyros, that probably would have been a better idea.
Unread 02-13-2018, 10:52 AM
gerthworm's Avatar
gerthworm gerthworm is offline
Making the 1's and 0's
FRC #1736 (Robot Casserole)
Rookie Year: 2015
gerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond repute
The theory presented here presumes no wheel slip while rotating. It's good to use this to get a ballpark initial estimate, but in real-life would probably produce somewhat poor quality results (varies depending on robot).
Gyro would seem to be the way to go, in my mind. Directly measure the thing you care about.
I would say your solution would yield an intermediate-quality result. I can't recall where I saw it, but some teams did use this method to determine the feed-forward portion of rotation calculations.
Unread 02-13-2018, 10:56 AM
Oblarg Oblarg is offline
AKA: Eli Barnett
FRC #0449 (The Blair Robot Project)
Oblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond repute
Run a motion profile that spins the robot in place by turning the wheels a known distance. Do some division to calculate the robot's "effective trackwidth" from the resulting angular displacement (which you should measure, either with a gyro or otherwise).
The "effective trackwidth" stays pretty reliably constant, in our experience.
"Mmmmm, chain grease and aluminum shavings..."
"The breakfast of champions!"
Member, FRC Team 449: 2007-2010
Drive Mechanics Lead, FRC Team 449: 2009-2010
Alumnus/Technical Mentor, FRC Team 449: 2010-Present
Lead Technical Mentor, FRC Team 4464: 2012-2015
Technical Mentor, FRC Team 5830: 2015-2016
FRC Drivetrain Characterization
Unread 02-13-2018, 11:00 AM
MaGiC_PiKaChU's Avatar
MaGiC_PiKaChU MaGiC_PiKaChU is offline
Drive Coach
AKA: Antoine L.
FRC #3360 (Hyperion)
Rookie Year: 2012
MaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond repute
we use encoders with a PID. We convert encoders ticks to degrees with a variable that you have to find. Basically, we ask to robot to turn 360 degrees, then calculate the offset. If there was too much rotation, we tune it down a bit, and vice versa. We don't like the arc method, because it does not consider wheels spinning.
2012 - 3360 - Junior member
2013-2014 - 3360 - Lead Programmer, Human player
2015 - 3360 - Lead Programmer, Driver
2016-2018 - 3360 - Mentor, Drive coach
Unread 02-13-2018, 11:03 AM
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Are all three wheels on each side chained/belted together? Or are some of them not driven (or independently driven)?
Are all wheels traction or are some omni?
How much drop do you have on the center wheels?
Where's your center of mass?
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
