Go to Post YES! I am a MENTOR. Not a chaperone. I am busy all day, I don't want to deal with the stupidity that may or may not go on at night. Besides, I might see something as a cool physics experiment, where a chaperone might see someone dropping pop cans down the stair wells. - Not2B [more]
Unread 02-13-2018, 12:00 PM
Type's Avatar
Type Type is offline
AKA: AJ
FRC #3452 (GreengineerZ)
Team Role: Mechanical
Rookie Year: 2016
Type has much to be proud ofType has much to be proud ofType has much to be proud ofType has much to be proud ofType has much to be proud ofType has much to be proud ofType has much to be proud ofType has much to be proud ofType has much to be proud of
Snapping 775 Pro Shaft
So my team somehow was able to snap the shaft off while running a 775 Pro. We had an AM 12t Pinion on it when it snapped, connected to our drivetrain. For those teams that ran 775 drivetrains last year (2767, 2451, 3357, etc.), did you ever discover any failures similar to this?
We at first believed it was due to a lot of sudden forward and then reversing while driving but later we remembered our gearboxes became loose at one point and we are wondering if the sag of the motors put too much stress on the pinion, later causing it to fail. The pinion has an unusual wear pattern on it (flat teeth in a few spots but we have an enclosed gesrbox so could be due to getting wedged somewhere after failing).
And by the way, the motor still runs.
3452- Lead Builder/ Pit Boss
*My posts do not reflect the opinion of my team*
Unread 02-13-2018, 12:10 PM
FRC_498's Avatar
FRC_498 FRC_498 is offline
Lead Mentor - Drive Coach
AKA: Adam Shroyer
FRC #0498 (Cobra Commanders)
FRC_498 is a jewel in the roughFRC_498 is a jewel in the roughFRC_498 is a jewel in the rough
Re: Snapping 775 Pro Shaft
We blew through a Versa Planetary last night...
Unread 02-13-2018, 12:20 PM
BigTanBuilding's Avatar
BigTanBuilding BigTanBuilding is offline
FRC #1817 (Llano Estacado RoboRaiders)
Rookie Year: 2013
BigTanBuilding is an unknown quantity at this point
Can you post a close up picture of the end of the shaft while it is not spinning? From your description of the sagging motors, my guess is bending fatigue.
Richard Wallace's Avatar
Richard Wallace Richard Wallace is offline
I live for the details.
FRC #3620 (Average Joes)
Rookie Year: 1996
Was it running when that picture was taken? Most of the image is very clear, but the broken shaft surface looks blurry. A better look at that surface might help identify the failure mode.
When you said the gearboxes became loose, did you mean the motor screws?
Richard Wallace
since 2003
Unread 02-13-2018, 12:29 PM
Jon Jack's Avatar
Jon Jack Jon Jack is offline
VEX Robotics
no team (No Team)
Jon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond repute
Send a message via AIM to Jon Jack
Do you have a picture of your gearbox or at least how the gearing is laid out?
In the interest of full disclosure: I work for VEX Robotics a subsidiary of Innovation First International (IFI) Crown Supplier & Proud Supporter of FIRST
Team 1538 / The Holy Cows, 2005-2016
Unread 02-13-2018, 12:30 PM
Type's Avatar
AKA: AJ
Rookie Year: 2016
I'll take a picture later of it not spinning. I took some without it spinning but they were blurry so I screenshotted a video.
With our current setup, the screws holding the gearbox together holds the motors in, so technically the motor screws became loose.
Unread 02-13-2018, 12:32 PM
Nick Lawrence's Avatar
Happy Birthday! Nick Lawrence Nick Lawrence is offline
Commander Canada
FRC #3940 (CyberTooth, AndyMark)
Nick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond repute
Were these motors in a custom gearbox? Were the pinions double-loaded?
-Nick
Alumnus of 1503 Spartonics
Founding Mentor of 5406 Celt-X
Lead Mechanical Design Mentor of 3940 CyberTooth
Emceeing events since 2013 - come say hi!
Success doesn't always equate to match wins. It's about the wins off the field.
Unread 02-13-2018, 12:45 PM
Type's Avatar
AKA: AJ
Rookie Year: 2016
This is how the gearbox is currently setup. We are using AM DeCIMates connected to modified WCP SS (little smaller than normal configuration). If I can remember off the top of my head, we had a 26.775:1 reduction (total final reduction to the wheel, 6" wheel).
Since the picture was taken, plastic covers were added to keep grease in and dirt out.
Unread 02-13-2018, 12:46 PM
JamesCH95's Avatar
JamesCH95 JamesCH95 is offline
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
JamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond repute
It looks like either ductile torsional failure:
Or bending+rotating failure:
Possible that you got a motor without a heat-treated shaft, but perhaps more likely that the bending load from having the motor 'sag' induced a fracture that grew as the motor continued in use.
Edit: looks just like the fracture pattern for 'severe stress riser' in rotating+bending fatigue failure. Perhaps something to do with how the pinon was pressed on or made.
Theory is a nice place, I'd like to go there one day, I hear everything works there.
Maturity is knowing you were an idiot, common sense is trying to not be an idiot, wisdom is knowing that you will still be an idiot.
Unread 02-13-2018, 12:48 PM
kevin.li.rit's Avatar
kevin.li.rit kevin.li.rit is offline
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
kevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond repute
Send a message via Yahoo to kevin.li.rit
I've had a RS550 fail like this when the motor mount to the GB got loose.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 02-13-2018, 01:27 PM
InFlight's Avatar
InFlight InFlight is offline
3574 - The King's of Bling
AKA: Jim
FRC #3574 (High Tekerz)
Rookie Year: 2012
InFlight has a reputation beyond reputeInFlight has a reputation beyond reputeInFlight has a reputation beyond reputeInFlight has a reputation beyond reputeInFlight has a reputation beyond reputeInFlight has a reputation beyond reputeInFlight has a reputation beyond reputeInFlight has a reputation beyond reputeInFlight has a reputation beyond reputeInFlight has a reputation beyond reputeInFlight has a reputation beyond repute
In the first picture; the lower mounting screw location looked damaged, and turned to an angle. It appears this motor bolt could have been cross-threaded off center.
There is also no indication of any red or blue traces on the threads, indicating no Loctite was used.
Unread 02-13-2018, 02:47 PM
Kevin Ainsworth's Avatar
Kevin Ainsworth Kevin Ainsworth is offline
FRC #2451 (Pwnage)
Rookie Year: 2011
Kevin Ainsworth has a reputation beyond reputeKevin Ainsworth has a reputation beyond reputeKevin Ainsworth has a reputation beyond reputeKevin Ainsworth has a reputation beyond reputeKevin Ainsworth has a reputation beyond reputeKevin Ainsworth has a reputation beyond reputeKevin Ainsworth has a reputation beyond reputeKevin Ainsworth has a reputation beyond reputeKevin Ainsworth has a reputation beyond reputeKevin Ainsworth has a reputation beyond reputeKevin Ainsworth has a reputation beyond repute
I would venture to guess it was the side loading from the gearbox coming loose. You could also have picked something up between the spur and pinion gear. A screw, rivet, washer, etc. The motor just doesn't have the torque to snap a shaft like that. If you started and stopped super quick, the armature would reverse direction before you could snap a shaft. The only other thought that comes to mind is the pressing of the pinion onto the shaft might have damaged the shaft which then broke.
2451 has never had a 775Pro shaft failure.
The motors we installed at the beginning of last season are still on our comp bot.
Unread 02-13-2018, 03:26 PM
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Rookie Year: 2011
Mk.32 has a reputation beyond reputeMk.32 has a reputation beyond reputeMk.32 has a reputation beyond reputeMk.32 has a reputation beyond reputeMk.32 has a reputation beyond reputeMk.32 has a reputation beyond reputeMk.32 has a reputation beyond reputeMk.32 has a reputation beyond reputeMk.32 has a reputation beyond reputeMk.32 has a reputation beyond reputeMk.32 has a reputation beyond repute
Yeah in our off season 775pro drivetrain and in the history of abusing 775pros we've never seen a failure like that.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 02-13-2018, 10:48 PM
Type's Avatar
AKA: AJ
Rookie Year: 2016
Here is a picture of the shaft snapped while not moving. If it's blurry, I'll try to re-upload. CD didn't like the original pictures size.
  #15   Spotlight this post!
Unread 02-14-2018, 06:17 AM
electroken's Avatar
electroken electroken is offline
Electron Tamer
AKA: Ken Pontbriant
FRC #0230 (Gaelhawks)
Rookie Year: 2012
electroken is a jewel in the roughelectroken is a jewel in the roughelectroken is a jewel in the roughelectroken is a jewel in the rough
All of the flaked-off plating around the motor mounting holes makes me think that motor was moving around a lot.
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
