Go to Post Because nothing says safety like carrying a 150lb robot across a field covered in golf balls. - Kevin Sevcik [more]
Unread 02-13-2018, 05:45 PM
asafh81020's Avatar
asafh81020 asafh81020 is offline
FRC #5614 (Team Sycamore)
Team Role: Mechanical
Rookie Year: 2014
asafh81020 is an unknown quantity at this point
How to function 9 motors without the RoboRio turning off
Our team uses 9 motors and we face a problem which shuts down the robot every time we run it.
We figured that the high number of motors consumption of voltage decreases the voltage of the RoboRio to under 10V which apparently shuts the robots voltage.
Any tips on how to solve this problem?
Sent from my SM-A520F using Tapatalk
Unread 02-13-2018, 06:34 PM
garyk garyk is offline
Programming Mentor, 972 and 2643
FRC #2643 (Dark Matter)
garyk has a brilliant futuregaryk has a brilliant futuregaryk has a brilliant futuregaryk has a brilliant futuregaryk has a brilliant futuregaryk has a brilliant futuregaryk has a brilliant futuregaryk has a brilliant futuregaryk has a brilliant futuregaryk has a brilliant futuregaryk has a brilliant future
Re: How to function 9 motors without the RoboRio turning off
How does it shut down the robot? Does the robotís main breaker (the main on/off switch) pop (Turn Off)? That switch is also a 120 amp circuit breaker.
Silicon Valley Regional 2005, 2006 972
Silicon Valley Regional 2007 668 Xerox Creativity Award
Championship Event 2007 668
Portland Regional 2008 668
Silicon Valley Regional 2008 668, 972
Beta Test Team 2008 668 (with 100 & 254)
Silicon Valley Regional 2009 668 Regional Chairman's Award; 2643
Sacramento Regional 2009 668 Winning Alliance (thanks, 1717 & 2473!), 2010 Winning Alliance 3256
CalGames 2006, 2007, 2008, 2009, 2010, 2011 Field Tech
NorCal FTC Regional 2008, 2009 Inspector
Championship Event 2009
San Diego, Silicon Valley Regionals; Champ. Event 2010 668, 2643, 3256
Silicon Valley, Madera Regional 2012 2643
WRRF Programming Instructor 2006-2016
Regional Woodie Flowers Award 2014 2643 Utah Regional
Unread 02-13-2018, 07:43 PM
Keefe2471's Avatar
Keefe2471 Keefe2471 is offline
FRC #2471 (Team Mean Machine)
Keefe2471 has much to be proud ofKeefe2471 has much to be proud ofKeefe2471 has much to be proud ofKeefe2471 has much to be proud ofKeefe2471 has much to be proud ofKeefe2471 has much to be proud ofKeefe2471 has much to be proud ofKeefe2471 has much to be proud of
I believe what's he referring to is that the roboRIO is browning out. Specifically described on page 7 of this pdf.
As for how to fix it, likely at least 4 (probably 6?) of those motors are drive train related, you can reduce the load that those motors are under when your turning by adding a or increasing your center wheel drop, or by switching from traction to something lower traction (Omni-wheels maybe?) on the outer wheels.
Describing which motors you are using and what they are doing would probably help others here help you more.
Unread 02-13-2018, 08:00 PM
philso philso is offline
Mentor
philso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond repute
You can start by going through the test procedure I outlined in Post #9 of this thread.
Unread 02-14-2018, 02:31 AM
asafh81020's Avatar
Rookie Year: 2014
We have 4 CIM motors for the drivetrain(west coast drive), 4 AM-775, two in a gearbox with 1:45 ratio for a lifring mechanism , two with 1:30 gear ratio each for a cube intake mechanism, and a snowblower motor for another lifter
Unread 02-14-2018, 02:53 AM
asafh81020's Avatar
Rookie Year: 2014
I may have not explained the situation properly.
each time we drive our robt and/or activate our mechanisems,the voltage drops to under 10v (which we figure) collapses the RoboRio and leads to a communication breakdown. the ampbraker does not pop.
we really need help!
Unread 02-14-2018, 03:17 AM
AriMB's Avatar
AriMB AriMB is offline
The Philadelphian emigrant
AKA: Ari Meles-Braverman
FRC #5987 (Galaxia)
Rookie Year: 2012
AriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond repute
If you have all of those motors geared correctly, that really should not brown out your roborio. Especially since you're probably not using all of those at once. If you post the gear ratios and expected loads you have for each motor, we can help you figure out if one is drawing too much current. Also check to make sure that all of your wiring is tight (especially the wires between your battery and PDP). If you can wiggle the connector, it's too loose. Also, feel free to PM me and I can send you my phone number if you would rather talk instead of writing online.
Studying MechE at the Technion - Israel Institute of Technology
2017-present: Technical Mentor FRC 5987
2017-present: CSA/FTAA for FIRST Israel
2012-2016: Member FRC 423 Captian, Programmer (LabVIEW), Electrical, CAD, Manipulator, Chassis, Business, Outreach (everything)
Unread 02-14-2018, 05:42 AM
rfolea's Avatar
rfolea rfolea is offline
AKA: Rick Folea
no team (Forsyth Alliance)
rfolea has a reputation beyond reputerfolea has a reputation beyond reputerfolea has a reputation beyond reputerfolea has a reputation beyond reputerfolea has a reputation beyond reputerfolea has a reputation beyond reputerfolea has a reputation beyond reputerfolea has a reputation beyond reputerfolea has a reputation beyond reputerfolea has a reputation beyond reputerfolea has a reputation beyond repute
Make sure one of the motors isn't wired backwards and fighting the others.
Remove all the PDP Breakers except one. Test that motor. Move the breaker to the next motor. Test that. Test each motor independently. This is easiest to do in the Shuffboard Live window under TEST mode on the driver station.
Make sure each motor is spinning in the right direction.
Unread 02-14-2018, 08:49 AM
kevin.li.rit's Avatar
kevin.li.rit kevin.li.rit is offline
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
kevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond repute
Send a message via Yahoo to kevin.li.rit
Can you confirm that the Roborio is wired to blue VBatt/Controller side on the PDP and not on the green/PCM/VRM side? The green side is not protected against voltage drops.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 02-14-2018, 08:56 AM
maccopacco's Avatar
maccopacco maccopacco is offline
AKA: maccopacco
FRC #3452 (GreengineerZ)
Rookie Year: 2016
maccopacco is an unknown quantity at this point
We've had far more motors than that on a robot before and we didn't have any voltage issues until the end of a heavily defensive match. My guess is a failing electrical component.
Unread 02-14-2018, 09:08 AM
Billfred's Avatar
Billfred Billfred is offline
needs to go to Bayou
AKA: New Orleans is rough on streaks.
FRC #1293 (Pandamaniacs); FTC #11444 (Garnet Squadron)
Another thing that isn't explored: how many motors are running at one time, and how much current are they drawing? If your strategy requires running a 6-motor drive while also running a really heavy worm-driven arm, maybe that's a problem.
That can be solved by going with a numerically higher gear (or sprocket, or pulley) reduction, which will allow the motor to work at a higher speed (which means less current draw) at the expense of time to accomplish the task.
I'd check those other things above first though. Hope you shake it out!
William "Billfred" Leverette - Gamecock/Jessica Boucher victim/Owner/Director of Bricks 4 Kidz in Columbia, SC.
2017: FRC 5402 (Iron Kings) - Mentor, Coach
2018-: FRC 1293 (Pandamaniacs) - Mentor
112 events (more than will fit in a ChiefDelphi signature), 15 seasons, over 72,000 miles, and still on a mission from Bob.
Unread 02-14-2018, 09:16 AM
AriMB's Avatar
FRC #5987 (Galaxia)
Rookie Year: 2012
FYI, neither is the blue side. The only difference between the blue and green sides is the blue side is on a 10A breaker and the green side is on a 20A breaker. The only regulated voltage in the control system comes from the VRM.
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Please follow the troubleshooting steps explained in this post.
Report back here what you find.
Unread 02-14-2018, 09:17 AM
Fields's Avatar
Fields Fields is offline
Classic
Rookie Year: 2015
Fields is a splendid one to beholdFields is a splendid one to beholdFields is a splendid one to beholdFields is a splendid one to beholdFields is a splendid one to beholdFields is a splendid one to beholdFields is a splendid one to behold
Another way to find the culprit is to put the robot on a block then run a few motors for 5 seconds. Which one(s) gets noticeably hotter?
If your battery is properly charged that energy is going somewhere.
A hot motor won't tell you what exactly is wrong, but it does narrow lens.
Wait... you built what now?
♪ 99 little bugs in the code
99 little bugs ♫
Take one down, patch it around
108 little bugs in the code ♫ ♪ ♫
  #15   Spotlight this post!
Unread 02-14-2018, 11:31 AM
Imaginary Friend
AKA: Kevin Li
Team Role: Student
It's possible I'm wrong. I was trouble shooting a brownout issue on our robot at competition. I had noticed that the Roborio was on the wrong side and the only change we made was to move the RoboRio from the green to blue side. I was standing next to one of the control systems people and he said that might be our issue. I had mentioned that the documentation doesn't say either side is regulated and that it shouldn't matter. He said let me find out and came back and said it was.
We had already eliminated loose wiring, poor connection and the radio as possible issues. In the end we never had an issue with the Roborio browning again.
Kevin Li
596 - Sciclones
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
