OCCRA
Go to Post Don't Canadians spell it that way? Someone should cheque on that.... - Travis Hoffman [more]
CD-Media
Unread 02-13-2018, 07:38 PM
AnshulDalua AnshulDalua is offline
FRC #0193
AnshulDalua is an unknown quantity at this point
Limelight updating help
Help!Today, I updated the limelight to the newest update(Version 2), and I cannot connect to the website interface! Does anyone know what to do?
Unread 02-14-2018, 02:53 PM
Brandon_Hjelstrom Brandon_Hjelstrom is offline
AKA: Brandon Hjelstrom
FRC #0987 (High Rollers)
Rookie Year: 2012
Brandon_Hjelstrom has a brilliant futureBrandon_Hjelstrom has a brilliant futureBrandon_Hjelstrom has a brilliant futureBrandon_Hjelstrom has a brilliant futureBrandon_Hjelstrom has a brilliant futureBrandon_Hjelstrom has a brilliant futureBrandon_Hjelstrom has a brilliant futureBrandon_Hjelstrom has a brilliant futureBrandon_Hjelstrom has a brilliant futureBrandon_Hjelstrom has a brilliant futureBrandon_Hjelstrom has a brilliant future
Re: Limelight updating help
Are you connecting using http://limelight.local:5801 ? Can you try to access the stream alone at http://limelight.local:5800 ?
More tips:
Make sure your microUSB cable is disconnected.
Make sure both your laptop and your Limelight are connected to your robot's network. If you are using static IPs anywhere, you may be using conflicting IP addresses.
Let me know if you need more help!
Powered by vBulletin®
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
