Go to Post Checklist: Robot on, thinkamajig set, autonomous set, safety bar pulled. - DonRotolo [more]
Unread 02-13-2018, 08:31 PM
lucas.alvarez96's Avatar
lucas.alvarez96 lucas.alvarez96 is offline
AKA: Lucas Alvarez
FRC #6955 (Los Chilis)
Team Role: Coach
Rookie Year: 2013
lucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to all
AMT Encodedrs: Faulty Output Voltage
We're using the AMT102 encoders mounted on the mini Toughboxes on our drivetrain. One of the encoders is outputting the correct voltage through the B channel, however the A voltage is giving off ~100 mV. I would assume the channel is busted, but when the students hooked it up to an oscilloscope, the correct waveform could be seen. Is there any reason for which one of the channels could be working but at a much lower voltage than VDD - 0.8 (according to the datasheet)?
Los Chilis #6955 Santiago, Chile
FRC 6955 2017-Present: Lead Mentor
FRC 2576 2015-2016: Mentor
FRC 2576 2013-2015: Programmer & Chairman's Presenter
Los Angeles Regional 2014: Regional Chairman's Award
Unread 02-13-2018, 08:39 PM
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
Re: AMT Encodedrs: Faulty Output Voltage
The outputs are only rated for 2ma, so if the pin or wire is shorted to ground, that would drag the voltage down a ton. I'd check for a short in your cable or swarf in the pins. Other option could be a bad input on the Rio.
Unread 02-14-2018, 05:53 AM
electroken's Avatar
electroken electroken is offline
Electron Tamer
AKA: Ken Pontbriant
FRC #0230 (Gaelhawks)
Rookie Year: 2012
electroken is a jewel in the roughelectroken is a jewel in the roughelectroken is a jewel in the roughelectroken is a jewel in the rough
Add to the list the possibility of the DIO pin being configured as an output, set low in software.
Unread 02-15-2018, 06:15 AM
AKA: Lucas Alvarez
Team Role: Coach
Rookie Year: 2013
I tested all the pins on the encoder and there aren't shorts. Both channels on both encoders measure ~724 ohms to ground (if I remember correctly). I'll tell the students to try using another DIO port, but I don't think it'll change much, seeing as the problem is with the encoder's output voltage. In the meanwhile, we're working on a voltage amp with a MOSFET to jump the voltage up the 5V.
Any other ideas on what could be the issue?
Unread 02-15-2018, 07:35 AM
electroken's Avatar
Electron Tamer
AKA: Ken Pontbriant
Rookie Year: 2012
We've used a bunch of these encoders and no amplification has ever been necessary.
Unread 02-15-2018, 08:53 AM
David Lame David Lame is offline
FRC #0247
David Lame has a reputation beyond reputeDavid Lame has a reputation beyond reputeDavid Lame has a reputation beyond reputeDavid Lame has a reputation beyond reputeDavid Lame has a reputation beyond reputeDavid Lame has a reputation beyond reputeDavid Lame has a reputation beyond reputeDavid Lame has a reputation beyond reputeDavid Lame has a reputation beyond reputeDavid Lame has a reputation beyond reputeDavid Lame has a reputation beyond repute
If it spits out the correct voltage when it is measured open circuit (which is what I assume you were doing with the oscilloscope), but it is low when connected in circuit, then the problem is almost certainly what the output is connected to.
It could be a short circuit in the wiring. It could be a software error, not putting the DIO port as an output, like someone suggested.
Back in ancient days, (i.e. when I was young) I was a teaching assistant for a digital electronics class. (EE 249. I wonder if the class is still taught) Students were constantly coming to me with "broken chips", and I would always tell them that perhaps I could take a look at it. The problem, every single time, was always that two outputs were wired together.
I would say if the device works correctly when measured on the scope, then the device works. I don't know of any failure mode of such a device that would allow it to work there but not in circuit. I would look first to the software, and then make sure that the only connection of the A channel is to the signal pin of the DIO port.
Unread 02-15-2018, 09:07 AM
karin.gill123 karin.gill123 is offline
FRC #5863
karin.gill123 is an unknown quantity at this point
Is it the AMT 102-V? We're looking for an encoder and I don't know much about them, Thanks!
Unread 02-15-2018, 09:58 AM
FRC #0247
That's the type we have used in the past, and are using this year. I've been testing with them, and they are easy to use and have worked well for us so far.
I don't have enough expertise with other styles to do a meaningful comparison with other encoders. I just know that when I tell the robot to go six feet and stop, it goes six feet, and stops.
Unread 02-15-2018, 10:34 AM
AKA: Lucas Alvarez
Team Role: Coach
Rookie Year: 2013
I'm sorry, I wasn't too clear. I measured the 500 mV while connected to the scope, so the problem isn't the connection. I would consider it busted, but the waveform is ok (but 10x lower).
Unread 02-15-2018, 11:21 AM
FRC #0247
Ah. Ok.
If you were measuring it open-circuit, and it was outputting a low voltage, that's definitely odd, and could suggest something wrong with the encoder itself. If it was connected to anything else at the time, it could still have a waveform of the right shape, but wrong voltage.
I would suspect a bad input voltage, except that channel B apparently works.
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
