OCCRA
Go to Post Who says engineers can't be poets? - Wayne TenBrink [more]
Unread 06-05-2018, 08:15 PM
jcpeng jcpeng is offline
FRC #0846 (Banana Breakers)
Team Role: Mechanical
Rookie Year: 2015
jcpeng is an unknown quantity at this point
Question about the Robonauts' 2017 drivetrain
Hi! I had a question about Team 118's drivetrain from 2017 (Steamworks) and I was wondering if anyone here could help me figure this out.
From looking at their CAD files (https://ccisdrobonauts.org/?p=robots) it looks like they're using chain (or belt?) in tube with a 2x1 tube, but the exact drive method isn't modeled in CAD. I also can't figure out how you could fit two chains/belts next to each other in such a tight space (unless they're only driving the rear omniwheels?)
Any information is much appreciated!
Thanks,
-Jing-Chen
Unread 06-05-2018, 09:07 PM
n.ion's Avatar
n.ion n.ion is offline
FRC #3735 (VorTX)
Team Role: Leadership
Rookie Year: 2015
n.ion is an unknown quantity at this point
Re: Question about the Robonauts' 2017 drivetrain
Looking at their CAD, like you said, they dont have it modeled. My team, 3735, in this PowerUp season took on the challenge of creating a chain in tube drivetrain configuration similar to that of 118's 2017 robot. We found that using double sprockets simply doesnt give enough room for the chain to sit inside the tube. (also the fact that VexPro only sells double sprockets for #35 chain where we wanted to use #25H) To get around this issue, we basically used two single sprockets (16T) from VexPro which we lathed off part of one side giving just barely enough clearance to fit the chain in the tube. Then on each other side, we were able to use normal single sprockets just making sure that we had proper spacing between the inside walls of the 2X1.
Just a warning, I wouldnt try this for the first time during the season. It would be best to test it out sometime during the offseason so you have time to iterate if need be. Its a tedious process that requires patience and a steady hand.
Nathan Ion
Robot Captain
VorTX 3735
Unread 06-05-2018, 09:12 PM
Billfred's Avatar
Billfred Billfred is offline
Never look back, no, never say die
AKA: Always attack with the warrior's cry...
FRC #1293 (Pandamaniacs); FTC #11444 (Garnet Squadron)
I'm not in a position to look at CAD easily, but I could hypothesize it's some version of the now-unavailable 221 17T double sprocket, which was great for tucking into 2x1 tubing. Anthony Lapp from 221 has worked closely with Robonauts in the past, so it's certainly convenient.
William "Billfred" Leverette - Gamecock/Jessica Boucher victim/Owner/Director of Bricks 4 Kidz in Columbia, SC.
2017: FRC 5402 (Iron Kings) - Mentor, Coach (oh, and I worked at AndyMark during this time)
2018-: FRC 1293 (Pandamaniacs) - Mentor
113 events (more than will fit in a ChiefDelphi signature), 15 seasons, over 74,500 miles, and still on a mission from Bob.
Unread 06-06-2018, 03:21 AM
waialua359's Avatar
waialua359 waialua359 is offline
Friends of Waialua Robotics, Inc.
AKA: Glenn
FRC #0359 (Hawaiian Kids)
Rookie Year: 2000
waialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond repute
Anthony was with the Robonauts in the past, not sure about now. A great one of the many that they have had over the years.
*Nvm, I just read a post that he’s moving.
2018 Canadian Rockies Regional Champions, #1 seed
2018 Hawaii Regional Champions, #1 seed, Quality Award
2018 Festival de Robotique-Montreal Regional Champions, #1 seed, Industrial Design Award
2017 World Championship Woodie Flowers Award Winner
2017 World Championship Darwin Division Finalist Award
2017 Greater Pittsburgh Regional Champions, #1 seed, Safety Award, Entrepreneurship Award
2017 Palmetto Regional Champions, #2 seed, Safety Award
2016 Hawaii Regional #1 seed, IDesign, Safety Award
2016 NY Tech Valley Regional Champions, #1 seed, Innovation in Controls Award
2016 Lake Superior Regional Champions, #1 seed, Quality Award, Dean's List
2015 FRC Worlds-Carver Division Champions
2015 Hawaii Regional Champions, #1 seed.
2015 Australia Regional Champions, #2 seed, Engineering Excellence Award
2015 Inland Empire Regional Champions, #1 seed, Industrial Design Award
2014 Hawaii Regional Champions, #1 seed, UL Safety Award
Unread 06-06-2018, 10:05 AM
Justin Ridley Justin Ridley is offline
FRC #0118 (Robonauts)
Rookie Year: 1998
Justin Ridley has a reputation beyond reputeJustin Ridley has a reputation beyond reputeJustin Ridley has a reputation beyond reputeJustin Ridley has a reputation beyond reputeJustin Ridley has a reputation beyond reputeJustin Ridley has a reputation beyond reputeJustin Ridley has a reputation beyond reputeJustin Ridley has a reputation beyond reputeJustin Ridley has a reputation beyond reputeJustin Ridley has a reputation beyond reputeJustin Ridley has a reputation beyond repute
Send a message via AIM to Justin Ridley
Yeah, we've used Anthony's 221 double sprockets in the past (which he's no longer making). We've also made them ourselves by waterjetting blanks and then turning down the middle on a lathe.
We've been doing chain in tube using double #25 sprockets like this since 2013 and have really been happy with it.
-- Justin Ridley --
21 years
27 --> 221 --> 857 --> 118
Unread 06-06-2018, 10:07 AM
notmattlythgoe's Avatar
notmattlythgoe notmattlythgoe is offline
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
notmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond repute
Since the 221 sprockets are no longer available, another alternative that teams have shifted towards is using 2x1.5 tube instead. This allows 2 unmodified vex sprockets to fit in the tube side by side.
Unread 06-06-2018, 01:39 PM
Michael Hill's Avatar
Michael Hill Michael Hill is offline
FRC #3138 (Innovators Robotics)
Michael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond repute
How do you chuck that in the lathe?
softjaws?
'12-'xx: Mentor FRC 3138 - Innovators Robotics
'07-'07: Mentor FRC 1646 - Precision Guessworks
'04-'06: Student FRC 45 - TechnoKats
Unread 06-06-2018, 02:05 PM
Chadfrom308's Avatar
Chadfrom308 Chadfrom308 is offline
Slave to the bot
AKA: Chad Krause
FRC #7226 (Error 404)
Rookie Year: 2011
Chadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to behold
softjaws?
If the shaft is a hex shaft, you can just put it on a hex shaft, drill and tap a hole at the end of the hex shaft and use a washer and bolt to hold it on.
//TODO: make signature
Unread 06-06-2018, 02:46 PM
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
This is a great method, we've used it for several different things each of the past few years.
LRI: North Star 2012-2016; Lake Superior 2013-2014; MN State Tournament 2013-2014, 2016-2018; Iowa 2017; Northern Lights 2018; Great Northern 2018
Division LRI: Galileo 2016; Tesla 2017; Archimedes 2018
2015: North Star Regional Volunteer of the Year
2016: Lake Superior WFFA
Unread 06-06-2018, 03:56 PM
RoboChair's Avatar
RoboChair RoboChair is offline
He who fixes with hammers #tsimfd
AKA: Devin Castellucci
FRC #1678 (Citrus Circuits and 5458 Digital Minds)
RoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond repute
softjaws?
Behold the power of the mandrel!
An expanding arbor is always nice. I have made many expanding hex shafts by drilling and tapping the end followed by a very aggressive countersink, then sawing grooves on the same end so when you tighten a CS bolt it forces the hex to expand.
12 Years and counting! Over a third of my life has been spent with FRC.
Unread 06-07-2018, 11:46 AM
Rookie Year: 2015
I guess I'm just confused how two chains can even fit in the .75" gap. According to VexPro, the #25 master links are .381" across each, and you'd have to fit two of them (? unless I'm missing something)
I've also heard that you can just press chain links back together but never tried it myself...
Unread 06-07-2018, 11:47 AM
Rookie Year: 2015
Nathan Ion
Robot Captain
VorTX 3735
Our team (846, Funky Monkeys) has experience doing chain in tube (for the past three years now), but we've always had to use larger tube. I was just wondering how they got everything to fit in a 2x1.
Unread 06-07-2018, 12:27 PM
deltafief deltafief is offline
AKA: David Liu
FRC #1540 (Flaming Chickens)
Rookie Year: 2016
deltafief is an unknown quantity at this point
While I'm not the robonauts, what many teams do with chain in tube is use #25 chain and just stack two sprockets for the middle axle. In order to get everything to fit, you want to machine out a pocket in the 2x1 in the middle so you can fit the two sprockets, the hex hub part will be sticking out towards the inside
Unread 06-07-2018, 12:32 PM
Flywheel Police
I think more teams used a double sprocket that team221 used to sell like the one pictured below, but for #25 chain.
  #15   Spotlight this post!
Unread 06-07-2018, 02:28 PM
Billfred's Avatar
(image snipped)
That's what 4901 did in 2016. The 221 sprocket was set up to fit two chain runs within the 1" wide tubing, as long as there weren't any odd clippy things on your chain run (like a half link with the wire you bend around). It would've fit in 2x1, though 4901 ran 3x1 so they could get a bigger-than-usually-desirable drop on the center wheel to account for the pneumatic wheels. The result didn't make playoffs, but for my money it was the coolest robot I've had a hand in over the last 15 years.
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
